uploadscript.
0 svar · 124 visningar · startad av maniac
maniacMedlem sedan feb. 200150 inlägg
jag använder uploadscriptet som jag hittade på wfscript...men det är en sak som jag vill ändra. jag vill att filnamet ska bytas ut till session("username").filändelse. såhär ser koden ut:
	Dim UPLOAD_PATH
		UPLOAD_PATH	= Server.MapPath("content/images/members")
	Dim g_oFso, g_oFolder, g_oFile
		Set g_oFso	= Server.CreateObject("Scripting.FileSystemObject")
		Set g_oFolder	= g_oFso.getFolder(UPLOAD_PATH)
	If (Request.ServerVariables("REQUEST_METHOD") = "POST") Then
		Dim g_oUpload
			Set g_oUpload	= get_upload_files()
		Dim fpos, fcontent
			fcontent	= g_oUpload("upload").Item("content")
		Set g_oFile	= g_oFso.CreateTextFile(UPLOAD_PATH & "\" & extract_filename(g_oUpload("upload").Item("filename")))
		For fpos = 1 to LenB(fcontent)
			g_oFile.Write chr(AscB(MidB(fcontent, fpos, 1)))
		Next
		g_oFile.Close: Set g_oFile	= Nothing
		Response.Redirect Request.ServerVariables("SCRIPT_NAME")
	Response.Write "<html><body><table>"
	Response.Write "<tr><td><hr size=""1"" noshade></td></tr>"
	Response.Write "<tr><td><span class=""text""><b>Current pictures:</b></span></td></tr>"
	For Each g_oFile In g_oFolder.Files
		Response.Write "<tr><td><span class=""text"">" & g_oFile.name & "</span></td></tr>"
	Next
	Response.Write "<tr><td align=""right""><form name=""frmUpload"" method=""post"" enctype=""multipart/form-data"" action=""" & Request.ServerVariables("SCRIPT_NAME") & """>"
	Response.Write "<input type=""file"" name=""upload""> &nbsp; <input type=""submit"" value=""upload""></td></tr>"
	Response.Write "</table></body></html>"
	Function get_upload_files()
		Dim	upload_object, request_binaries
		Dim position_start, position_end
		Dim boundary, boundary_pos
		Set upload_object	= Server.CreateObject("Scripting.Dictionary")
		request_binaries	= Request.BinaryRead(Request.TotalBytes)
		position_start		= 1
		position_end		= InstrB(position_start, request_binaries, get_byte_string(chr(13)))
		boundary			= MidB(request_binaries, position_start, (position_end - position_start))
		boundary_pos		= InstrB(1, request_binaries, boundary)
		Do Until (boundary_pos = InstrB(request_binaries, boundary & get_byte_string("--")))
			If Not(Response.IsClientConnected) Then Response.End
			Dim name, pos_file
			position_start	= (InstrB(InstrB(boundary_pos, request_binaries, get_byte_string("Content-Disposition")), request_binaries, get_byte_string("name=")) + 6)
			position_end	= InstrB(position_start, request_binaries, get_byte_string(chr(34)))
			name			= get_string(MidB(request_binaries, position_start, (position_end - position_start)))
			pos_file		= InstrB(boundary_pos, request_binaries, get_byte_string("filename="))
			If  ((pos_file <> 0) AND (pos_file < InstrB(position_end, request_binaries, boundary))) Then
				upload_object.Add name, Server.CreateObject("Scripting.Dictionary")
				position_start	= (pos_file + 10)
				upload_object.item(name).Add "filename", get_string(MidB(request_binaries, position_start, (position_end - position_start)))
				position_start	= (InstrB(position_end, request_binaries, get_byte_string("Content-Type:")) + 14)
				upload_object.item(name).Add "content-type", get_string(MidB(request_binaries, position_start, (position_end - position_start)))
				position_start	= (position_end + 4)
				position_end	= InstrB(position_start, request_binaries, boundary) - 2
				upload_object.item(name).Add "size", ((position_end - position_start))
				upload_object.item(name).Add "content", MidB(request_binaries, position_start, (position_end - position_start))
			boundary_pos	= InstrB(boundary_pos + LenB(boundary), request_binaries, boundary)
		Loop
		Set get_upload_files = upload_object
	End Function
	Function get_byte_string(str)
		Dim cnt
		For cnt = 1 to Len(str)
			get_byte_string	= get_byte_string & chrB(AscB(Mid(str, cnt, 1)))
		Next
	End Function
	Function get_string(str)
		Dim cnt
		For cnt = 1 to LenB(str)
			get_string	= get_string & chr(AscB(MidB(str, cnt, 1)))
		Next
	End Function
	Function extract_filename(filename)
		extract_filename	= Right(filename, Len(filename) - InStrRev(filename, "\", -1, 1))
	End Function
Genererad på 365 ms · cache AV · v20260730165559-full.f96bc7eb
