Fungerade igår - idag: "Type mismatch in expression"
7 svar · 321 visningar · startad av plelkes
Medlem sedan mars 2002823 inlägg
Igår fungerade sidan som listar vätskor
<%@LANGUAGE="VBSCRIPT" "%>
<HTML>
<HEAD>
<TITLE>Untitled Document</TITLE>
</HEAD>
If Request.QueryString("type") = "" Then
  intType = 1
Else
  intType = CInt(Request.QueryString("type"))
Set objConn = Server.CreateObject("ADODB.Connection")
objConn.Open "Provider=Microsoft.Jet.OLEDB.4.0;Data Source=" & Server.MapPath("\vatskebalans\db\vbalans.mdb")
strSQL = "SELECT tblFluids.FluidNamn, tblFluidTypes.TypeNamn, tblFluidTypes.TypeID, tblFluids.FluidID FROM " & _
         "tblFluidRelat, tblFluids, tblFluidTypes WHERE tblFluidRelat.FluidID = tblFluids.FluidID AND" & _
		 " tblFluidRelat.typeID = tblFluidTypes.typeID AND tblFluidTypes.TypeID = " & intType & " ORDER by tblFluidTypes.typeID"
[B]Set objRS = objConn.Execute(strSQL)[/B]
If NOT objRS.EOF Then
<table width="800" border="1">
		<tr>
		   <td>&nbsp;</td>
		   <td colspan="3"><%
			                Response.Write objRS("TypeNamn")
							objRS.Close
		    </td>
		 </tr>
  				<tr>
    				<td><%
					      intLast = objConn.Execute("SELECT Max(TypeID) FROM tblFluidTypes")(0)
							For i = 1 To intLast
  						  Set objRS = objConn.Execute("SELECT TypeNamn FROM tblFluidTypes WHERE TypeID = " & i)
							If NOT i = intType Then
    							Response.Write("<a href=""?type=" & i & """>" & objRS("TypeNamn") & "</a><BR> ")
						  objRS.Close
						  Next
				     </td>
    					<td><% strSQL = "SELECT f.FluidNamn, ft.TypeNamn, ft.TypeID, f.FluidID FROM tblFluidRelat fr, tblFluids f, tblFluidTypes ft WHERE fr.FluidID = f.FluidID AND fr.typeID = ft.typeID AND ft.TypeID = " & intType & " ORDER by ft.typeID"
<table width="400" border="1">
<form name="fylla" method="post" action="skrivtill_tblVetskebalans.asp">
Patientens personnummer:&nbsp;&nbsp;&nbsp;<input name="personnr" type="text">
Do While Not objRS.EOF
     Response.Write "<TR><TD><INPUT NAME=""leggatill" & objRS("FluidID") & """ TYPE=""checkbox"" VALUE="""& objRS("FluidID") &"""></TD>"
     Response.Write "<TD>" & objRS("FluidNamn") & "</TD>"
     Response.Write "<TD><INPUT NAME=""volym" & objRS("FluidID") & """ TYPE=""text""></TD></TR>"
     objRS.MoveNext
Loop
    objRS.Close
    Set objRS = Nothing
    objConn.Close
    Set objConn = Nothing
</table>
<input type="submit" value="Lägg till Vätskebalansen">
<br><br>
<br>
<a href="http://www12.brinkster.com/vatskebalans/tblvetskebalans.asp">Lista tblV&auml;tskebalans inneh&aring;ll</a>
</BODY>
</HTML>
Idag när jag kör sidan får jag
Microsoft JET Database Engine error '80004005'
Type mismatch in expression.
/vatskebalans/lista_fluids.asp, line 18 = bold
Sidan där själva skrivning till databasen sker:
Session.LCID = 1053
Set vatskeb = Server.CreateObject( "Adodb.Connection" )
vatskeb.Provider = "Microsoft.Jet.OLEDB.4.0"
MdbFilePath = Server.MapPath("\vatskebalans\db\vbalans.mdb")
vatskeb.ConnectionString = "Data Source='" & MdbFilePath & "'"
vatskeb.open
pnr= Request.Form("personnr")
d = FormatDateTime(Date, 2)
For each formObj in Request.Form
     If left(formObj,9) = "leggatill" Then
            lngFluidID = Replace(Request.Form(formObj), "leggatill", "")
            strSQL = "INSERT INTO tblVetskebalans(Dag, FluidID, Volym, PatID) VALUES(#" & d & "#,'" & lngFluidID & "'," & Request.Form("volym" & lngFluidID) & ", '" & pnr & "')"
 Response.Write strSQL
vatskeb.Execute strSQL, , 128
     End if
Next
vatskeb.close
Set vatskeb = Nothing
Response.Redirect "lista_fluids.asp"
dag är av typen datum
FluidID av typen text
volym av typen tal
PatiID av typen text
Är medveten om att jag dubbelpostar, men i överskådlighetens namn, tycker jag att det är försvarligt..
Det enda jag ser på en gång är att felet skulle kunna uppstå om intType är något annat än numeriskt, d.v.s. att felet uppstår i din QueryString.
Skriv ut SQL-frågan och kontrollera...
Just konstruktionen för "paging" har jag fått hjälp från wf - och fattar inte mycket av, så:
  • Hur skall jag ändra?
SELECT tblFluids.FluidNamn, tblFluidTypes.TypeNamn, tblFluidTypes.TypeID, tblFluids.FluidID FROM tblFluidRelat, tblFluids, tblFluidTypes WHERE tblFluidRelat.FluidID = tblFluids.FluidID AND tblFluidRelat.typeID = tblFluidTypes.typeID AND tblFluidTypes.TypeID = 1 ORDER by tblFluidTypes.typeID
/vatskebalans/lista_fluids.asp, line 19
Jämförbara typer?
Kan det vara så att det föreligger ett stavfel någonstans?
Om det inte hjälper med @nders förslag, så ser inte jag några fel ivarjefall. :l
Eftersom jag är förkyld så skickar jag med en variant på frågan
SELECT tF.FluidNamn, tFT.TypeNamn, tFT.TypeID, tF.FluidID
FROM (tblFluidRelat tFR
INNER JOIN tblFluids tF
  ON tF.FluidID = tFR.FluidID)
INNER JOIN tblFluidTypes tFT
  ON tFT.TypeID = tFR.TypeID
WHERE tFT.TypeID = 1
ORDER BY tFT.TypeID
Du kanske får ett annorlunda felmeddelande om inte annat :)
båda är av typen text
båda tal
  1. Nu verkar det funka:OO
  2. Finns det ngra nackdelar i att jag har ändrat så mänga av fälten till "text"?
  1. Det beror på vad du lagrar i fälten. Är det tal bör du använda taltyp, är det strängar så ska du använda text.
Men hur kan jag lösa det i mitt fall: i strSQL har jag bl. a,
tblFluids.FluidID = tblFluids.FluidNamn
tblFluids.FluidID = tal
tblFluids.FluidNamn = sträng
Nu ha rjag iof ändrat båda till sträng, men kunde hag ha skrivit min strSQL på annorlunda sätt?
267 ms totalt · 4 externa anrop · v20260731065814-full.a51de22e
129 ms — deklarationer (db)
127 ms — ändringar (db)
