Dim mySmartUpload
Dim sendername,subject,body, fil, file
Set mySmartUpload = Server.CreateObject("aspSmartUpload.SmartUpload")
mySmartUpload.Upload
MySmartUpload.Save("E:\\bilaga")
sendername=mySmartUpload.Form("sendername")
subject=mySmartUpload.Form("subject")
body=mySmartUpload.Form("body")
skolan=mySmartUpload.Form("skola")
For each file In mySmartUpload.Files
fil=file.FileName
Next
On error resume next
Server.ScriptTimeOut = 180
Dim strSQL
Dim mySmartMail
Set mySmartMail = Server.CreateObject("aspSmartMail.SmartMail")
' Mail Server
mySmartMail.Server = "****"
' From
mySmartMail.SenderName = SenderName
mySmartMail.SenderAddress = "*******"
' Message
mySmartMail.Subject = Subject
mySmartMail.Body = Body
if not fil="" then
mySmartMail.Attachments.Add Server.MapPath("\bilaga\"&fil&""),, false
'sConn = "Provider=Microsoft.Jet.OLEDB.4.0;Data Source=E:\*******"
'Set Conn = Server.CreateObject("ADODB.Connection")
'Conn.Open sConn
if Err.Number <> 0 then
Response.Write "Can't connect to the DataBase, Please check value of Data Source in the HTML form."
' Create the RecordSet
strSQL = "SELECT MAIL FROM mail where skola=" & skolan
Set Rs = Server.CreateObject("ADODB.recordset")
Set Rs.ActiveConnection = Conn
Rs.Source = strSQL
Rs.Open
Do while not Rs.EOF
' To
if Rs("NAMN")<>"" Then
mySmartMail.Recipients.Add Rs("MAIL")
' Send the message
mySmartMail.SendMail
if err.number <> 0 then
response.write("<br>Error n°: " & err.number - vbobjecterror & "=" & err.description & "<br>")
Response.Write "<br>aspSmartMail has sent your message to " & mySmartMail.Recipients.Item(1).Address
mySmartMail.Recipients.Clear
Rs.MoveNext
Loop
' Destruction
Dim objFSO
Set objFSO = Server.CreateObject("Scripting.FileSystemObject")
objFSO.DeleteFile "****\bilaga\"&fil&"", False
Set objFSO = Nothing
response.redirect "../default.asp?kat=nyhetsbrev&sida=skriv.asp&status=ok"
Rs.Close
Conn.Close
Set Rs = Nothing
Set Conn = Nothing
set mySmartMail = nothing
När jag kör koden så tuggar den jättelänge och sen så skriver den att det inte finns några mottagare. I databasen ligger adresserna i tabellen mail och fältet mail. finns även ett fält som heter skola som kan vara samma bakom många mailadresser. Vad har jag gjort för fel?
