Oavslutad strängkonstant???
5 svar · 380 visningar · startad av wborg
Medlem sedan dec. 2003209 inlägg
Jag får följande felmess när jag klickar på en länk.
någon som kan säga vad felet är?
Feltyp:
Kompileringsfel i Microsoft VBScript (0x800A0409)
/sumpan/showall.asp, line 15, column 66
rs.open "SELECT * FROM varmara WHERE ID=" & Request("ID") &", conn
<%@LANGUAGE="VBSCRIPT" CODEPAGE="1252"%>
<html>
<title></title>
<body>
set conn=Server.CreateObject("ADODB.Connection")
conn.open "Provider=Microsoft.Jet.OLEDB.4.0;Data Source=" & server.mappath("db\2003b.mdb")
set rs=Server.CreateObject("ADODB.recordset")
rs.open "SELECT * FROM varmara WHERE ID=" & Request("ID") & ", conn
if rs.eof then
    response.write "<hr><center>Ingen data funnen</center><hr>"
<center>
<table border="1" style="border-collapse: collapse" bordercolor="#000000" cellspacing="0" cellpadding="2">
<tr bgcolor="#000000">
<td width="50" align="center"><b><font color="#FFFFFF">Pos</font></b></td>
<td width="140" align="left"><b><font color="#FFFFFF">Namn</font></b></td>
<td width="50" align="center"><b><font color="#FFFFFF">Hcp</font></b></td>
<td width="50" align="center"><b><font color="#FFFFFF">V1</font></b></td>
<td width="50" align="center"><b><font color="#FFFFFF">V2</font></b></td>
<td width="50" align="center"><b><font color="#FFFFFF">Tot</font></b></td>
<td width="50" align="center"><b><font color="#FFFFFF">Thcp</font></b></td>
<td width="50" align="center"><b><font color="#FFFFFF">P</font></b></td>
</tr>
dim background
    background="#cccccc"
<%do while not rs.eof %>
if background = "#ffffff" then
   background = "#cccccc"
<tr bgcolor="<%=background%>">
<td align="center"><%=rs.Fields("pos").Value%></td>
<td align="left"><%=rs.Fields("Fname").Value%>&nbsp;<%=rs.Fields("Lname").Value%></td>
<td align="center"><%=rs.Fields("hcp").Value%></td>
<td align="center"><%=rs.Fields("r1").Value%></td>
<td align="center"><%=rs.Fields("r2").Value%></td>
<td align="center"><%=rs.Fields("total").Value%></td>
<td align="center"><%=rs.Fields("Thcp").Value%></td>
<td align="center"><%=rs.Fields("Points").Value%></td>
</tr>
<%rs.movenext
Loop%>
</table>
</center>
</html>
set rs = nothing
Tack på förhand
/S
rs.open "SELECT * FROM varmara WHERE ID=" & Request("ID"), conn
Och du, välkommen hit. :)
Då fick jag följande fel istället :(
Feltyp:
Microsoft JET Database Engine (0x80040E14)
Syntaxfel (operator saknas) i frågeuttrycket 'ID='.
Tack för välkomnandet :)
/S
Det verkar som om Request("ID") inte innehåller något värde. :)
Stackars @nders, säkert tionde gången jag ser Sebbe svara några sekunder innan :e
260 ms totalt · 4 externa anrop · v20260731065814-full.86ec41c2
127 ms — deklarationer (db)
126 ms — ändringar (db)
