Har kollat lite på denna Getrows kod (http://www.dileno.hel.nu/asp/default.asp?id=3) och den funkar fint med Access men när jag vill koppla det till MySQL funkar det inte alls. Nån som kan ändra koden så den funkar?
Dim Cn, Rs, page, rowcount, pagecounter, arrRecs, i, Antal, pagecount, Pz
dInitTime = Timer()
page = Request.Querystring("page")
If page="" Then page=1
rowcount=0
Set Cn = Server.CreateObject("ADODB.Connection")
Cn.Open "Provider=Microsoft.Jet.OLEDB.4.0; Data Source=" & Server.MapPath("db.mdb")
Set Rs = Cn.Execute("Select id,falt1,falt2,falt3 From tbl_ Order By Id")
If Rs.EOF Then
Rs.Close : Set Rs = Nothing
Cn.Close : Set Cn = Nothing
Response.Write "Inga poster i databasen än.."
Else
Rs.Close
Rs.Cursortype=3
Rs.Open
Rs.Pagesize=200 'antalet poster per sida
Rs.Absolutepage=cInt(page)
Antal = Rs.Recordcount
Pz = Rs.Pagesize
pagecount = ((Antal-1) \ Pz) -- 1
arrRecs = Rs.GetRows(Pz)
Cn.Close : Set Cn = Nothing%>
<table border="1">
<%If IsArray(arrRecs) Then
For i = 0 To UBound(arrRecs,2) And rowcount < Pz
Response.Write "<tr><td>" & arrRecs(0,i) & "</td><td>" & arrRecs(1,i) & "</td><td>" & arrRecs(2,i) & "</td><td>" & arrRecs(3,i) & "</td></tr>"
Next
End If%>
</table>
<%If Antal > Pz Then
If Cint(page) > 1 Then
Response.Write "<A href=""?page=" & page - 1 & """>Bakåt</a> | "
For pagecounter = 1 to Pagecount
If Cint(page) = pagecounter Then
Response.Write "<b>" & pagecounter & "</b> "
Else
Response.Write "<a href=""?page=" & pagecounter & """>" & pagecounter & "</a> "
Next
If Cint(page) < Pagecount Then
Response.Write " | <A href=""?page=" & page + 1 & """>Framåt</a>"
fPeriod = FormatNumber(Timer() - dInitTime, 3)
Response.Write "<br>Laddningstid: <b>" & fPeriod & "</b> s."
