hjälp me kop den ger fell mess!
5 svar · 234 visningar · startad av silentworld
Medlem sedan nov. 200364 inlägg
fett fel när ja ska logga in på min admin i mitt forum! (men bara när ja kör lokalt!)
:OO
här har vi fel messet:
Response object error 'ASP 0156 : 80004005'
Header Error
/silentworld/forum3/admin.asp, line 64
The HTTP headers are already written to the client browser. Any HTTP header modifications must be made before writing page content.
oh här är koden
<body onLoad="<%=mess%>">
<%'admin funkotion
Function FixaTecken(str)
  FixaTecken  = Replace(Trim(str),"'","''")
End function
db = Server.MapPath("db/forum.mdb")        'Sökvägen till databasen
Admin1 = "admin"
Admin2 = "xxxxxxx"
Conn.Open "Provider=Microsoft.Jet.OLEDB.4.0;Data Source=" & db
If Request.QueryString("do") = "" Then%>
      <table width="450" align="center">
        <form name="loggain" method="post" action="admin.asp?do=check">
         <tr>
          <td colspan="2"><font size="2"><b>Admin:</b></font></td>
        </tr>
        <tr>
          <td height="14" colspan="2"><img src="bilder/dot2.gif"></td>
        </tr>
        <tr>
           <td><b>Adminnamn:</b></td>
           <td><input type="text" name="admin1" size="15">
        </tr>
        <tr>
            <td><b>Lösenord:</b></td>
            <td><input type="password" name="admin2" size="15">
        </tr>
        <tr>
             <td colspan="2" height="14"><img src="bilder/dot2.gif"></td>
        </tr>
        <tr>
            <td>&nbsp;</td>
            <td><input type="submit" value="Logga in"></td>
        </tr>
      </table>
<%End If
If Request.QueryString("do") = "check" Then
If Request.Form("admin1") = Admin1 AND Request.Form("admin2") = Admin2 Then
   login="ok"
Else
   Response.Redirect "admin.asp?mess=fel"
If login="ok" Then
     Session("admin") = "ok"
     Session.TimeOut = 40
     Response.Redirect "admin.asp?do=inne"
If Request.QueryString("do") = "inne" Then%>
         <tr>
          <td height="14"><font size="2"><b><a href="admin.asp?do=inne">Forumadmin:</a> </b></font></td>
          <td height="14" align="right"><font size="2"><b><a href="admin.asp?do=logut">Logga ut</a> </b></font></td>
        </tr>
        <tr>
           <td colspan="2"><img src="bilder/dot2.gif"></td>
        </tr>
</table>
<%If Request.Querystring("action")= "" AND Session("admin") = "ok" Then%>
<%Set RecSet = Server.CreateObject("ADODB.Recordset")
Const faps1 = 15
Sidan = Request.QueryString("sida")
If Sidan = "" then
    sida = 1
Else
    sida = Sidan
With RecSet
    .CursorLocation = 3
    .CacheSize = faps1
End With
SQL = "Select * From forum Order By datum desc"
RecSet.Open SQL, Conn
If RecSet.EOF Then%>
  <tr>
    <td height="14">Inga inlägg i forumet</td>
  </tr>
</table>
<%Else%>
  <tr bgcolor="<%=Color%>" width="14">
    <td width="150"><b>Rubrik:</b></td>
    <td width="95"><b>Datum:</b></td>
    <td width="90"><b>Namn:</b></td>
    <td align="right" width="50">&nbsp;</td>
  </tr>
    <tr>
       <td colspan="4"><img src="bilder/dot2.gif"></td>
    </tr>
<%With RecSet
     .MoveFirst
     .PageSize = faps1
     .AbsolutePage = sida
End With
Sidor =  RecSet.PageCount
Count = 0
Do While Not RecSet.EOF And Count < RecSet.PageSize%>
  <tr>
    <td width="150"><%If RecSet("svarsid") = 0 Then%><%Else%> - <%End If%><b><%If Len(RecSet("rubrik")) > 20 Then%><%=Left(RecSet("rubrik"),20)%>...<%Else%><%=RecSet("rubrik")%><%End If%></td>
    <td width="95"><%=FormatDateTime(RecSet("Datum"),2)%></b></td>
    <td width="90"><%=RecSet("namn")%></b></td>
    <td align="right" width="50"><a href="admin.asp?do=inne&action=change&id=<%=RecSet("id")%>"><img src="bilder/update.gif" border="0" alt="Ändra"></a> &nbsp; <a href="javascript:del('admin.asp?do=inne&action=delete&id=<%=RecSet("id")%>&uid=<%=RecSet("svarsid")%>')"><img src="bilder/trash.gif" border="0" alt="Ta bort"></a></td>
  </tr>
Count = Count + 1
RecSet.MoveNext
Loop
If Sidor > 1 Then%>
    <tr>
    </tr>
     <tr>
        <td colspan="4"><b>
     <%If Sidor <> 1 Then
     For Sid = 1 To Sidor
     If (Int(Sid)) = (Int(sida)) Then%><font color="#ff0000"><%=Sid%></font><%Else%> <a href="admin.asp?do=inne&sida=<%=Sid%>"><%=Sid%></a> <%End If%>
     <%Next%></b></font>
       </td>
     </tr>
<%End If
End If%>
     <%If Session("mess") <> "" Then%>
  <tr>
  </tr>
     <tr>
        <td colspan="4" align="center"><b>
       Response.Write Session("mess")
       Session("mess") = ""
     %></b>
       </td>
     </tr>
     <%End If%>
</table>
RecSet.Close
Set RecSet = Nothing
If Request.Querystring("action")= "change" AND Session("admin") = "ok" Then
Set RecSet = Conn.Execute("Select * From forum Where id="& Request.Querystring("id"))%>
<form method="post" action="admin.asp?do=inne&action=andrat&id=<%=Request.Querystring("id")%>" name="change">
<%If RecSet("email") <> "" Then%>
  <tr>
    <td>Postat av: <a href="mailto:<%=RecSet("email")%>"><b><%=RecSet("namn")%></b></a> | <%=RecSet("datum")%></td>
  </tr>
<%Else%>
  <tr>
    <td>Postat av: <b><%=RecSet("namn")%></b> | <%=RecSet("datum")%></td>
  </tr>
<%End If%>
  <tr>
    <td><b>Rubrik:</b><br><input type="text" name="rubrik" size="55" value="<%=RecSet("rubrik")%>"></td>
  </tr>
  <tr>
    <td><b>Inlägg:</b><br><textarea cols="75" rows="10" name="inlagg" size="45"><%=RecSet("inlagg")%></textarea>
    </td>
  </tr>
  <tr>
    <td>
      <input type="Submit" name="andra" value="Ändra">
    </td>
  </tr>
</table>
<%RecSet.Close
If Request.Querystring("action") = "andrat" AND Session("admin") = "ok" Then
Rubrik      = Request.Form("rubrik")
Inlagg       = FixaTecken(Request.Form("inlagg"))
Conn.execute("Update forum Set rubrik='" & Rubrik & "', inlagg='" & Inlagg & "'  Where id = "& Request.Querystring("id"))
Session("mess") = "Inlägget är ändrat!"
If Request.Querystring("action") = "delete" AND Session("admin") = "ok" Then
Set RS = Conn.Execute("Select * From forum Where id="& Request.Querystring("id"))
If RS("svarsid") = 0 Then
  Conn.Execute("Delete * From forum Where id=" & Request.Querystring("id"))
  Conn.Execute("Delete * From forum Where svarsid="& Request.Querystring("id"))
Else
 Conn.Execute("Update forum Set Svar=Svar-1 Where id ="& Request.Querystring("uid"))
Session("mess") = "Inlägget är borttaget och alla svar om du raderat ett huvudinlägg!"
End If%>
       <tr>
        </tr>
 </table>
<%End If
If Request.Querystring("do") = "logut" Then
   Session.Abandon
   Response.Redirect "index.asp"
Conn.Close
Set Conn = Nothing%>
kan nån komma på problemet??
//Webmaster på silentworld :q
skriv
Response.buffer = true
överst i koden
tack så väldigt med hjälpen det funka!!!
Medlem sedan nov. 200355 inlägg
prcis som beeer sa adda response.buffer = true längst upp
och sdan kan du alltid skriva
On Error Resumse Next
testa det så får du se
Varför i hela friden ska han använda On Error Resume Next? Då hade man ju inte haft en aning om vad som hade varit fel, eftersom det gör så att exekveringen av sidan fortsätter om något fel hittas, och inget felmeddelande skrivs ut.
Eller nåt sånt... :OO
är inte att rekommendera om man vill kunna felsöka. Vet man däremot att sidan fungerar som den ska kan man ju lägga till det (men det gör varken till eller från). Bättre att ha en egen felhanterare då
On Error Goto HandleError
[blue]'kodhirr...[/blue]
ExitPage:
  Response.End
  Goto PageEOF
HandleError:
  Dim objErr
  Set objErr = Server.GetLastError
  strErr = "Feltyp: " & objErr.Description & "<br>Felkod: " & objErr.Number & "<br><br>Rad: " & objErr.Line
  strErr = strErr & "<br>Fil: " & objErr.File
  Response.Write strErr
  Resume ExitPage
PageEOF:
573 ms totalt · 4 externa anrop · v20260731065814-full.1dc6f849
434 ms — deklarationer (db)
433 ms — ändringar (db)
