Uppdatera databasen
48 svar · 1 088 visningar · startad av plelkes
plelkesMedlem sedan mars 2002823 inlägg
Hej jag listar innehållet i en databas med koden
<%@LANGUAGE="VBSCRIPT" "%>
<HTML>
<HEAD>
<TITLE>Untitled Document</TITLE>
</HEAD>
If Request.QueryString("type") = "" Then
  intType = 1
Else
  intType = CInt(Request.QueryString("type"))
Set objConn = Server.CreateObject("ADODB.Connection")
objConn.Open "Provider=Microsoft.Jet.OLEDB.4.0;Data Source=" & Server.MapPath("\vatskebalans\db\vbalans.mdb")
strSQL = "SELECT tblFluids.FluidNamn, tblFluidTypes.TypeNamn, tblFluidTypes.TypeID, tblFluids.FluidID FROM " & _
         "tblFluidRelat, tblFluids, tblFluidTypes WHERE tblFluidRelat.FluidID = tblFluids.FluidID AND" & _
		 " tblFluidRelat.typeID = tblFluidTypes.typeID AND tblFluidTypes.TypeID = " & intType & " ORDER by tblFluidTypes.typeID"
Set objRS = objConn.Execute(strSQL)
If NOT objRS.EOF Then
<table width="800" border="1">
		<tr>
		   <td>&nbsp;</td>
		   <td colspan="3"><%
			                Response.Write objRS("TypeNamn")
							objRS.Close
		    </td>
		 </tr>
  				<tr>
    				<td><%
					      intLast = objConn.Execute("SELECT Max(TypeID) FROM tblFluidTypes")(0)
							For i = 1 To intLast
  						  Set objRS = objConn.Execute("SELECT TypeNamn FROM tblFluidTypes WHERE TypeID = " & i)
							If NOT i = intType Then
    							Response.Write("<a href=""?type=" & i & """>" & objRS("TypeNamn") & "</a><BR> ")
						  objRS.Close
						  Next
				     </td>
    					<td><% strSQL = "SELECT f.FluidNamn, ft.TypeNamn, ft.TypeID, f.FluidID FROM tblFluidRelat fr, tblFluids f, tblFluidTypes ft WHERE fr.FluidID = f.FluidID AND fr.typeID = ft.typeID AND ft.TypeID = " & intType & " ORDER by ft.typeID"
<table width="400" border="1">
<form name="fylla" method="post" action="uppdatera.asp">
Do While Not objRS.EOF
     Response.Write "<TR><TD><INPUT NAME=""leggatill"" TYPE=""checkbox"" VALUE="""& objRS("FluidID") &"""></TD>"
     Response.Write "<TD>" & objRS("FluidNamn") & "</TD>"
	 Response.Write "<TD><INPUT NAME=""volym"" TYPE=""text""></TD></TR>"
       objRS.MoveNext
    Loop
    objRS.Close
    Set objRS = Nothing
    objConn.Close
    Set objConn = Nothing
	</form></table>
<input type="submit" value="Lägg till Vätskebalansen">
</BODY>
</HTML>
Själva uppdateringssidan (uppdatera.asp)
sort = Request.Form("FluidID")
mgd = Request.Form("volym")
strSQL = "INSERT INTO tblVetskebalans(Dag, FluidID, Volym) VALUES('" & now() & "','" & sort & "','" & mgd & "' )"
vbalans.Execute( strSQL )
Set gbok = Nothing
    objRS.Close
    Set objRS = Nothing
    objConn.Close
	Response.Redirect "knapp_i1.asp"
Men när jag trycker på knappen händer nada...
Det jag vill skall hända:
  1. på sidan knapp_i1.asp skall rutan kryssas i
  2. på sidan knapp_i1.asp skall txtrutan fyllas i
  3. tablelen tblVetskebalans skall fyllas i
  4. tillbaka till sidan knapp_i1.asp
  5. möjlighet att välja nästa vtske-sort
Börja med att lägga submit-knappen inanför form-taggarna. ;)
Nu har jag gjort detta.
Men får fel
Microsoft JET Database Engine error '80040e07'
Data type mismatch in criteria expression.
/vatskebalans/uppdatera.asp, line 11
	[B]Set objRS = objConn.Execute(strSQL)[/B]
    objRS.Close
    Set objRS = Nothing
    objConn.Close
rad 11 är fet-markerad
Vad har du för enheter/datatyper i databasen?
förstår inte riktigt frågan...
Skickar därför med databasen
strSQL = "INSERT INTO tblVetskebalans(Dag, FluidID, Volym) VALUES('" & now() & "'," & sort & "," & mgd & " )"
Microsoft JET Database Engine error '80040e14'
Syntax error in INSERT INTO statement.
Passa på och ändra även dessa:
sort = cInt(Request.Form("FluidID"))
mgd = cInt(Request.Form("volym"))
Jag ser att dina fält har samma namn, jag föreslår att du skapar någon slags loop för du kommer ju absolut att få fel om du lägger in olika värden i de olika fälten.
Det har en mindre betydelse, eftersom värdena ändå blir strängar när de läggs till SQL-frågan.
Har man syntaxfel i SQL-frågor finns det alltid två saker man kan göra:
  1. Se till att du inte använt något reserverat ord som tabell- eller fältnamn. Kontrollera på exempelvis http://aspfaq.com/show.asp?id=2080 .
  2. Skriv ut den färdiga SQL-frågan med response.write istället för att exekvera. Det är mycket lättare att felsöka då.
Se till att du inte använt något reserverat ord som tabell- eller fältnamn. Kontrollera...
Hittar inte att jag skulle ha använt reserverat namn
Menar du
Response.Write strSQL
Japp, med ett litet tillägg.
Response.end
Inte jag heller. Det var mest ett generellt tips, det händer alldeles för ofta att folk får massor med problem för att de använder reserverade ord som tabell- eller fältnamn.
Menar ni att sidan bör se ut:
strSQL = "INSERT INTO tblVetskebalans(Dag, FluidID, Volym) VALUES('" & now() & "'," & sort & "," & mgd & " ')"
Response.end
    objConn.Close
Om jag kryssar i och fyller i 222
så blir resultatet:
INSERT INTO tblVetskebalans(Dag, FluidID, Volym) VALUES('11/17/2003 1:53:22 PM',0,222, , , ')
FluidID blir ju fel...
Försökt ändra i uppdateringssidan:
Set vatskeb = Server.CreateObject( "Adodb.Connection" )
vatskeb.Provider = "Microsoft.Jet.OLEDB.4.0"
MdbFilePath = Server.MapPath("\vatskebalans\db\vbalans.mdb")
vatskeb.ConnectionString = "Data Source='" & MdbFilePath & "'"
vatskeb.open
strSQL = "INSERT INTO tblVetskebalans(Dag, FluidID, Volym) VALUES('" & now() & "','" & sort & "','" & mgd & "')"
vatskeb.Execute( strSQL )
Set vatskeb = Nothing
Får dock
fel på kodningen av kryssruta?
Nu ser jag, förutom att jag måste ändra i strSQL, även att FluidID hela tiden blir det samma och fel, nämligen 0....
Prova gärna själv :l
Kan det vara fel i kodningen av kryssrutan??
<form name="fylla" method="post" action="uppdatera1.asp">
       objRS.MoveNext
    Loop
    objRS.Close
    Set objRS = Nothing
    objConn.Close
 %><input type="submit" value="Lägg till Vätskebalansen">
	</form></table>
Dina checkboxar heter leggatill, men du anger namnet FluidID när du ska hämta värdena med request.
Men, jag förstår inte riktigt hur dina requests kan fungera överhuvudtaget, då du har flera värden som tillhör varje fältnamn i formuläret, eftersom fälten finns flera gånger. Hur vet asp-koden vilket av värdena som kommer som den skall använda? Det är även anledningen till alla extra kommatecken du noterar på slutet av din SQL-fråga.
När det gäller uppdatering / insättning av flera olika poster samtidigt, tycker jag nog att det är bäst att alla formulärfält har olika namn, så man kan avgöra vilka värden som hör till samma post. Jag brukar låta alla fält sluta på något lämpligt räknarvärde.
Jag ska se om jag kan få ihop ett fungerande exempel.
När du loopar ut formuläret:
     Response.Write "<TR><TD><INPUT NAME=""leggatill" & objRS("FluidID") & """ TYPE=""checkbox"" VALUE="""& objRS("FluidID") &"""></TD>"
     Response.Write "<TD><INPUT NAME=""volym" & objRS("FluidID") & """ TYPE=""text""></TD></TR>"
     objRS.MoveNext
Loop
När du ska göra insert:
vatskeb.open
For each formObj in Request.Form
     If left(Request.Form(formObj),9) = "leggatill" Then
            lngFluidID = Replace(Request.Form(formObj), "leggatill", "")
            strSQL = "INSERT INTO tblVetskebalans(Dag, FluidID, Volym) VALUES('" & now() & "','" & lngFluidID & "','" & Request.Form("volym" & lngFluidID) & "')"
            vatskeb.Execute strSQL, , 128
     End if
Next
vatskeb.close
Något sådant hade jag försökt mig på i alla fall.
Tack @nders för ditt hjälp :bire
MEN
  1. varför lägger du till objRS("FluidID") i INPUT NAME?
  2. vad betyder
    på svenska?
  3. i
    ersätter du leggatill med tomrum. Rätt? Vad är tanken bakom detta?
  4. vad betyder 128?
tyvärr så fungerar ej koden jag fick av @nders, eller så fattar jag fel :x
Det som inte funkar är att det skrivs inget till databasen
prova gärna själv
knapp_i3.asp
  intType = 1
Else
		<tr>
		   <td>&nbsp;</td>
		   <td colspan="3"><%
							objRS.Close
		    </td>
		 </tr>
  				<tr>
    				<td><%
						  objRS.Close
						  Next
				     </td>
<form name="fylla" method="post" action="uppdatera2.asp">
     objRS.MoveNext
Loop
    objRS.Close
    Set objRS = Nothing
    objConn.Close
	</form></table>
<br><br>
<br>
<a href="http://www12.brinkster.com/vatskebalans/tblvetskebalans.asp">Lista tblV&auml;tskebalans inneh&aring;ll</a>
uppdatera2.asp
vatskeb.open
     End if
Next
vatskeb.close
Response.Redirect "knapp_i3.asp"
143 ms totalt · 3 externa anrop · v20260731065814-full.fb544a5a
