döe få End If?
16 svar · 429 visningar · startad av plelkes
Medlem sedan mars 2002823 inlägg
Nu har jag provat på "möblera om " en fungerande sida:
If Request.QueryString("type") = "" Then
  intType = 1
Else
  intType = CInt(Request.QueryString("type"))
Set objConn = Server.CreateObject("ADODB.Connection")
objConn.Open "Provider=Microsoft.Jet.OLEDB.4.0;Data Source=" & Server.MapPath("\vatskebalans\db\vbalans.mdb")
	<table width="800" border="1">
		<tr>
			<td>&nbsp;</td>
			<td colspan="3"><%strSQL = "SELECT tblFluids.FluidNamn, ft.TypeNamn, ft.TypeID FROM tblFluidRelat, tblFluids, tblFluidTypes WHERE tblFluidRelat.FluidID = tblFluids.FluidID AND tblFluidRelat.typeID = tblFluidTypes.typeID AND tblFluidTypes.TypeID = " & intType & " ORDER by tblFluidTypes.typeID"
							Set objRS = objConn.Execute(strSQL)
							If NOT objRS.EOF Then
  							Response.WriteobjRS("TypeNamn")%>
		</td>
		</tr>
  			<tr>
    			<td><%intLast = objConn.Execute("SELECT Max(TypeID) FROM tblFluidTypes")(0)
						For i = 1 To intLast
  					 Set objRS = objConn.Execute("SELECT TypeNamn FROM tblFluidTypes WHERE TypeID = " & i)
					 	If NOT i = intType Then
    						Response.Write("<a href=""?type=" & i & """>" & objRS("TypeNamn") & "</a><BR> ")
  								Else
						Next%>
				</td>
    				<td>%strSQL = "SELECT tblFluids.FluidNamn, tblFluidTypes.TypeNamn, tblFluidTypes.TypeID FROM tblFluidRelat, tblFluids, tblFluidTypes  WHERE tblFluidRelat.FluidID = tblFluids.FluidID AND tblFluidRelat.typeID =tblFluidTypes.typeID AND tblFluidTypes.TypeID = " & intType & " ORDER by tblFluidTypes.typeID"
						Do Until objRS.EOF
    						Response.Write("<INPUT NAME=""leggatill"" TYPE=""checkbox"" VALUE="""& objRS("FluidNamn") &""">" )
					     %></td>
    			<td><%Response.Write objRS("FluidNamn") %></td>
    			<td><%Response.Write "<INPUT NAME=""volym"" TYPE=""text""><br>"%></td>
	     objRS.MoveNext
  Loop
 Else
  Response.Write("Det finns inga av den typen.")
Response.Write("<br>")
Set objRS = Nothing
		</tr>
	</table>
Response.Write "<INPUT TYPE=""submit"" VALUE=""Lägg till Vätskebalansen"">"
Set objRS = Nothing
objConn.Close : Set objConn = Nothing
Men jag verkar ha för få End IF, för jag får
Microsoft VBScript compilation error '800a03f4'
Expected 'If'
/vatskebalans/listainnehollet31.asp, line 55
End
Lägger jag till ett End IF
får jag ändå fel
Snälla ni hjälp mig innan jag blir alldeles flint...
Jag ser inget End... städa koden och markera raden som ger felet.
for  ...
loop
No good-
Medlem sedan aug. 20021 752 inlägg
Kan det kanske vara detta som spökar
Else
Next%>
Där har du en Else utan något i, sedan kommer end if. Prova att ta bort Else.
/Viktor
  intType = 1
Else
    <tr>
      <td> </td>
      <td colspan="3">
strSQL = "SELECT tblFluids.FluidNamn, ft.TypeNamn, ft.TypeID " & _
         "FROM tblFluidRelat, tblFluids, tblFluidTypes " & _
         "WHERE tblFluidRelat.FluidID = tblFluids.FluidID " &_
         "  AND tblFluidRelat.typeID = tblFluidTypes.typeID " & _
         "  AND tblFluidTypes.TypeID = " & intType & _
      </td>
    </tr>
    <tr>
      <td>
  Next
      </td>
      <td>
<% [blue]'Här kan ett fel ha varit. Ingen kråka före %[/blue]
  strSQL = "SELECT tblFluids.FluidNamn, tblFluidTypes.TypeNamn, tblFluidTypes.TypeID " & _
  Do Until objRS.EOF
      </td>
      <td>
      </td>
      <td>
      </td>
<% [blue]'Mera fel... ingen contextswitch...[/blue]
    objRS.MoveNext
  Loop
Else
Set objRS = Nothing
    </tr>
  </table>
Set objRS = Nothing [blue]' En gång till...[/blue]
Denna kod är ett rätt bra exempel på hur man inte ska göra ;)
Dela upp sidan i två block istället. Lägg VBScript-delen först och HTML-biten sist. Gör om dom delar du har mitt i HTML-koden till funktioner och sub:ar. Tydlighet i kod är ett stort steg på vägen för att kunna felsöka och förstå vad det är som händer.
<% 'Mera fel... ingen contextswitch...
objRS.MoveNext
Loop
Vad menar du med ingen contextswitch???
Funktioer och sub:ar en fortfarande mina S T O R A brister x( x( x( x(
Kan jag få exempel på hur jag borde lösa???
Det mest konstiga är att det funkar innan ommöbleringen, med följande kod
  intType = 1
Else
strSQL = "SELECT f.FluidNamn, ft.TypeNamn, ft.TypeID FROM tblFluidRelat fr, tblFluids f, tblFluidTypes ft WHERE fr.FluidID = f.FluidID AND fr.typeID = ft.typeID AND ft.TypeID = " & intType & " ORDER by ft.typeID"
  Response.Write(objRS("TypeNamn") & "<p>")
<table width="500" border="1">
  <tr>
  Else
Next
%></td>
    <td>&nbsp;</td>
    <td><%strSQL = "SELECT f.FluidNamn, ft.TypeNamn, ft.TypeID FROM tblFluidRelat fr, tblFluids f, tblFluidTypes ft WHERE fr.FluidID = f.FluidID AND fr.typeID = ft.typeID AND ft.TypeID = " & intType & " ORDER by ft.typeID"
Do Until objRS.EOF
    Response.Write("<INPUT NAME=""leggatill"" TYPE=""checkbox"" VALUE="""& objRS("FluidNamn") &""">" & objRS("FluidNamn") & "&nbsp;&nbsp;&nbsp;<INPUT NAME=""volym"" TYPE=""text""><br>")
     objRS.MoveNext
  Loop
 Else
Set objRS = Nothing
%></td>
  </tr>
</table>
Set objRS = Nothing
</BODY>
</HTML>
objRS.MoveNext
Loop
Du saknade <% där eller så såg jag fel då jag städade i din kod.
Svårt att dela upp det här i fler än en funktion. Det finns ingen logik för det, eftersom dom sakerna här bara ska utföras en gång.
Men jag kan ju givetvis pilla lite mer i din kod :)
Function CreateFluidTable()
  strDbPath = Server.MapPath("\vatskebalans\db\vbalans.mdb")
  objConn.Provider = "Microsoft.Jet.OleDb.4.0"
  objConn.Open strDbPath
  objRS.Open strSQL, objConn, 1, 3
  If Not objRS.EOF Then
    strHtml = objRS("TypeNamn")
    objRS.Close
    strHtml = strHtml & "</td></tr><tr><td>"
      If Not i = intType Then
        objRS.Open  "SELECT TypeNamn FROM tblFluidTypes WHERE TypeID = " & i, objConn, 1, 3
        strHtml = strHtml & "<a href=""?type=" & i & "">" & objRS("TypeNamn") & "</a><br>")
        objRS.Close
    Next
    strHtml = strHtml & "</td><td>"
    Do Until objRS.EOF
      strHtml = strHtml & "<input name=""leggatill"" type=""checkbox"" value=""" & objRS("FluidNamn") & """>"
      strHtml = strHtml & "</td><td>" & objRS("FluidNamn") & "</td><td>"
      strHtml = strHtml & "<input name=""volym"" type=""text""><br></td>"
      objRS.MoveNext
    Loop
    objRS.Close
  Else
    strHtml = "Det finns inga av den typen."
  Set objRS = Nothing
  objConn.Close
  CreateFluidTable = strHtml
End Function
  intType = 1
Else
  <tr>
    <td></td>
    <td colspan="3">
  Response.Write CreateFluidTable
    </td>
  </tr>
</table>
<input type="submit" value="Lägg till Vätskebalansen">
Jag tyckte du sa att det inte fungerade... eller var det innan du blev flint :q :)
Va+ nu fattar jag inget...
Länken jag skickade var ju innan mitt försök till ommöblering.
Håller du inte med om att det funkar?
Nu har jag läst och begrundat din kod. Rätt elegant lösning, :birp,
som dock jag själv aldrig skulle komma på :x
  • Du öppnar och stänger rs i varje tabellcell, eller hur?
  • Men connectionen stänger du bara på slutet, eller?
Du öppnar väl conn med
Men ändå har du med i varje tabellcell:
eller
Med en dåres envishet har jag fortsatt på mitt inslagna väg, dvs utan funktioner - eftersom jag är övertygad att jag aldrig skulle klara av att komma på det själv.
Har lag till contextswitch som Engine^ skrev...
Nu får jag felutskriften:
Microsoft JET Database Engine error '80040e10'
No value given for one or more required parameters.
/vatskebalans/listainnehollet31.asp, line 20
Koden i området:
16: <table width="800" border="1">
17: <tr>
18: <td>&nbsp;</td>
19:<td colspan="3"><%strSQL = "SELECT tblFluids.FluidNamn, ft.TypeNamn, ft.TypeID FROM tblFluidRelat, tblFluids, tblFluidTypes WHERE tblFluidRelat.FluidID = tblFluids.FluidID AND tblFluidRelat.typeID = tblFluidTypes.typeID AND tblFluidTypes.TypeID = " & intType & " ORDER by tblFluidTypes.typeID"
20: Set objRS = objConn.Execute(strSQL)
21: If NOT objRS.EOF Then
22: Response.WriteobjRS("TypeNamn")%>
Medlem sedan juni 20003 076 inlägg
Betyder att variabeln: intType förmodligen är tomt.
Kolla så alla tabell- och fältnamn är rättstavade.
dela upp strSQL på flera rader
nedanstående vii jag dela upp på flera rader:
Vilket är rätt:
1)
strSQL = "SELECT f.FluidNamn, ft.TypeNamn, ft._
TypeID FROM tblFluidRelat fr, tblFluids f, tblFluidTypes ft WHERE fr.-
eller 2)
strSQL = "SELECT f.FluidNamn, ft.TypeNamn, ft.TypeID " &_
"FROM tblFluidRelat fr, tblFluids f, tblFluidTypes ft WHERE" & _
" fr.FluidID = f.FluidID AND fr.typeID = ft.typeID AND ft.TypeID = " & intType & " ORDER by ft.typeID"
Alternativ två är korrekt.
Nu har jag nästan lyckats....
<%@LANGUAGE="VBSCRIPT" "%>
<HTML>
<HEAD>
<TITLE>Untitled Document</TITLE>
</HEAD>
  intType = 1
Else
strSQL = "SELECT tblFluids.FluidNamn, tblFluidTypes.TypeNamn, tblFluidTypes.TypeID FROM " & _
         "tblFluidRelat, tblFluids, tblFluidTypes WHERE tblFluidRelat.FluidID = tblFluids.FluidID AND" & _
		 " tblFluidRelat.typeID = tblFluidTypes.typeID AND tblFluidTypes.TypeID = " & intType & " ORDER by tblFluidTypes.typeID"
		<tr>
		   <td>&nbsp;</td>
		   <td colspan="3"><%
			                Response.Write objRS("TypeNamn")
							objRS.Close
		    </td>
		 </tr>
  				<tr>
    				<td><%
						  objRS.Close
						  Next
				     </td>
    					<td><%
                              Do Until objRS.EOF
						</td>
						</td>
    						<td><%Response.Write "<INPUT NAME=""volym"" TYPE=""text"">"%>
	    					<% objRS.MoveNext
  									Loop
 								objRS.Close
 									Else
						Set objRS = Nothing
						objConn.Close
	</table>
</BODY>
</HTML>
Men som ni ser blir det inte rätt:
Första lopen stämmer (kryssruta -> namnet -> textruta).
Men de andra varven blir det snett.
Min avsikt är att andr kryssrutan skall hamna i 2:a tblradens 2:a kolumn, namnet i 2:a tblradens 3:e kolumn ...
Tredje kryssrutan under de övriga i 2:a tblradens 2:a kolumn osv...
Hoppas och tror att ni förstår!.
Har nu utan framgång fösökt i 4 timmar att få fason på det hela.
124 ms — deklarationer (db)
123 ms — ändringar (db)
