Microsoft VBScript compilation error '800a0400'
1 svar · 283 visningar · startad av plelkes
plelkesMedlem sedan mars 2002823 inlägg
Får inte nedanstående fungera
<%@LANGUAGE="VBSCRIPT" "%>
<HTML>
<HEAD>
<TITLE>kryss lista</TITLE>
</HEAD>
If Request.QueryString("type") = "" Then
  intType = 1
Else
  intType = CInt(Request.QueryString("type"))
Set objConn = Server.CreateObject("ADODB.Connection")
objConn.Open "Provider=Microsoft.Jet.OLEDB.4.0;Data Source=" & Server.MapPath("\vatskebalans\db\vbalans.mdb")
<table width="342" border="1">
  <tr>
    <td width="103">&nbsp;</td>
    <td colspan="3"><%strSQL = "SELECT f.FluidNamn, ft.TypeNamn, ft.TypeID FROM tblFluidRelat fr, tblFluids f, tblFluidTypes ft WHERE fr.FluidID = f.FluidID AND fr.typeID = ft.typeID AND ft.TypeID = " & intType & " ORDER by ft.typeID"
Set objRS = objConn.Execute(strSQL)
If NOT objRS.EOF Then
  Response.Write("<center>" & objRS("TypeNamn") & "</center>")%></td>
  </tr>
  <tr>
    <td>><%intLast = objConn.Execute("SELECT Max(TypeID) FROM tblFluidTypes")(0)
For i = 1 To intLast
  Set objRS = objConn.Execute("SELECT TypeNamn FROM tblFluidTypes WHERE TypeID = " & i)
  If NOT i = intType Then
    Response.Write("<a href=""?type=" & i & """>" & objRS("TypeNamn") & "</a><BR> ")
  Else
Next
%></td>
    <td width="21"><INPUT NAME=""leggatill"" TYPE=""checkbox"" VALUE="""& objRS("FluidNamn") &"""></td>
    <td width="124"><%strSQL = "SELECT f.FluidNamn, ft.TypeNamn, ft.TypeID FROM tblFluidRelat fr, tblFluids f, tblFluidTypes ft WHERE fr.FluidID = f.FluidID AND fr.typeID = ft.typeID AND ft.TypeID = " & intType & " ORDER by ft.typeID"
Do Until objRS.EOF
    Response.Write objRS("FluidNamn")
     objRS.MoveNext
  Loop
 Else
  Response.Write("Det finns inga av den typen.")
</td><td width="66"><%strSQL = "SELECT f.FluidNamn, ft.TypeNamn, ft.TypeID FROM tblFluidRelat fr, tblFluids f, tblFluidTypes ft WHERE fr.FluidID = f.FluidID AND fr.typeID = ft.typeID AND ft.TypeID = " & intType & " ORDER by ft.typeID"
Do Until objRS.EOF
   <INPUT NAME=""volym"" TYPE=""text""><br>"
     objRS.MoveNext
  Loop
 Else
Response.Write("<br>")</td>
  </tr>
</table>
Response.Write "<INPUT TYPE=""submit"" VALUE=""Lägg till Vätskebalansen"">"
Set objRS = Nothing
objConn.Close : Set objConn = Nothing
</BODY>
</HTML>
Hela tiden samma fel mess
Expected statement
/vatskebalans/kryss.asp, line 53
</td>
rad 51 - 61
Do Until objRS.EOF
     objRS.MoveNext
  Loop
 Else
Det verkar som om du glömmer avsluta dina asp-block med %> ibland, vilket innebär att asp-tolken försöker tolka dina HTML-taggar som asp.
Genererad på 403 ms · cache AV · v20260730165559-full.f96bc7eb
