radera "pagin" ur kod
7 svar · 181 visningar · startad av tank82
Medlem sedan feb. 2003210 inlägg
Hejsan!
Kan någon vänlig själ hjälpa mig med att ta bort "sida pagin" i denna kod? Det skulle vara kanon! (och även snygga till den ;) )
<table cellpadding="1" cellspacing="0" width="100%" border="0">
<%Set Conn = Server.CreateObject("ADODB.Connection")
Conn.Open "Provider=Microsoft.Jet.OLEDB.4.0;Data Source=" & Server.MapPath("db.mdb")
If Request.QueryString("ID") = "" Then
Sidan = Request.QueryString("sida")
If Sidan = "" then
     sida = 1
Else
     sida = Sidan
With RecSet
    .CursorLocation = 3
    .CacheSize = 999
End With
SQL = "SELECT * FROM nyhetartikel Order By id desc"
RecSet.Open SQL, Conn
If RecSet.EOF Then%>
     <tr>
        <td>Här var det tomt..</td>
     </tr>
<%Else
With RecSet
  .MoveFirst
  .PageSize = 999
  .AbsolutePage = sida
End With
Sidor =  RecSet.PageCount
x = 0
Do While Not RecSet.EOF And x < RecSet.PageSize%>
     <tr>
        <td width="100%" valign="top"><%=RecSet("rubrik")%>td>
     </tr>
<%x=x+1
RecSet.MoveNext
Loop
RecSet.Close
If Sidor > 1 Then%>
  <tr>
     <td valign="top" colspan="2" style="border-top: 1px solid #000000">
       <%For Sid = 1 To Sidor
               If (Int(Sid)) = (Int(sida)) Then%><b><%=Sid%></b><%Else%> <a href="index.asp?page=page&sida=<%=Sid%>"><%=Sid%></a> <%End If
         Next%>
    </td>
  </tr>
<%End If
If Request.QueryString("ID") <> "" Then
Set RS=Conn.Execute("Select * From nyhetartikel Where id=" & Request.QueryString("ID"))%>
     <tr>
        <td><font color="#000000"><%=RS("rubrik")%></td>
     </tr>
     <tr>
        <td height="20"></td>
     <tr>
        <td colspan="2"><%=Replace(RS("texten"),vbCrLf, "<br>")%></td>
     </tr>
     <tr>
        <td height="5"></td>
     <tr>
  <tr>
  </tr>
  <tr>
    <td height="20" valign="top"><%=FormatDateTime(RS("datum"),1)%></td>
  </tr>
<%End If%>
</table>
Dim Conn, SQL1, SQL2, NewsID, Rs1, Rs2
NewsID = Request.QueryString("ID")
If len(trim(NewsID)) = 0 Then
	SQL1 = "SELECT rubrik FROM nyhetartikel Order By id desc"
	Set Rs1 = Conn.Execute(SQL1)
	If Rs1.Eof Then
		response.write("<tr><td>Här var det tomt..</td></tr>")
	Else
		do until Rs1.Eof
			response.write("<tr><td width='100%' valign='top'>" & Rs1("rubrik") & "</td></tr>")
		Rs1.MoveNext
		Loop
	Set Rs1 = nothing
If len(trim(NewsID)) > 0 AND IsNumeric(NewsID) Then
	SQL2 = "SELECT rubrik, texten, datum FROM nyhetartikel WHERE id=" & NewsID
	Set Rs2 = Conn.Execute(SQL2)
	if Rs2.Eof then
		response.write("<tr><td><font color='#000000'>" & Rs2("rubrik") & "</td></tr>")
		response.write("<tr><td height='20'></td></tr>")
		response.write("<tr><td colspan='2'>" & Replace(Rs2("texten"), chr(10), "<br>") & "</td></tr>")
		response.write("<tr><td height='5'></td><tr>")
		response.write("<tr><td height='20' valign='top'>" & FormatDateTime(Rs2("datum"),1) & "</td></tr>")
	End if
</table>
hmm nu får jag detta meddelande, men för en annan sida? (nämligen sok.asp):
Microsoft VBScript compilation error '800a0411'
Name redefined
sok.asp, line 14
Dim Conn
Sen undrar jag vad detta betyder:
tex "NewsID" vad är det, jag har inget i min DB som heter så, endast ID.
Dim = "Dimma" = Dimensionera. Du deklarerar de variabler du använder dig av i sidan/koden.
Mao gör plats i minnet = det går fortare.
Felet får du eftersom att just den variabeln tydligen deklareras två gånger, ta bort den ena förekomsten av: Dim Conn
Just NewsID är ju en variabel som i alla fall cyprys använder i den kod han skrivit till dig.
Hur då ta bort, ska jag radera hela denna rad? :)
Plocka bara bort Conn ur den raden:
Dim SQL1, SQL2, NewsID, Rs1, Rs2
Du kan radera den ja.
Det hela är väldigt enkelt egentligen.
Varje gång du skall använda en variabel så är det bra praxis att i början på varje sida säga till servern:
"Den här variabeln har jag skapat, bara så du vet"
Detta gör du med Dim.
ex. Dim Conn
Du kan inte skapa samma variabel två gånger, och det är därför den skriker.
Byt bara ut
till
eftersom du redan "dimmat" eller deklarerat variabeln Conn en gång tidigare.
De övriga variabelnamnen som finns där är sådana jag själv skapat bara för att få en bättre överblick av koden och vad den gör.
Du ville att vi skulle "snygga till koden" ;) , så det har jag gjort. :)
OK! nu är jag med, TACK! ;)
261 ms totalt · 4 externa anrop · v20260731065814-full.1dc6f849
128 ms — deklarationer (db)
124 ms — ändringar (db)
