community gb problem
4 svar · 262 visningar · startad av Skatedragon
SkatedragonMedlem sedan juni 200332 inlägg
min gästbok till mitt community slutade idag fungera. Det blir ingen error, utan inlägget visas bara inte, och det förs inte in i databasen heller när jag kollar efter nån som ser vad som kan vara fel???
nextPage = TRIM( Request("nextPage"))
IF nextPage = "" THEN nextPage = 1
Connect.Open "Driver={Microsoft Access Driver (*.mdb)}; DBQ=" & server.mappath ("*****")&";pwd=****"
Addera = "SELECT * FROM gb where gbid='" & request.querystring("id") & "' order by id desc"
rs.Open Addera, Connect, 3, 3
Set rs1 = Server.CreateObject("ADODB.Recordset")
Addera = "SELECT * FROM anv where id='"&request.querystring("id")&"'"
rs1.Open Addera, Connect, 3, 3
if request.querystring("action")="tabort" then
Addera = "SELECT * FROM gb where id = '"&request.querystring("id")&"'
if rs("namn")=session("id") then
response.redirect "gastbok.asp?id="&session("id")
rs.delete
rs.update
if request.querystring("id") = session("id") then
Set rs5 = Server.CreateObject("ADODB.Recordset")
Addera = "SELECT * FROM gb where gbid='"&request.querystring("id")&"' and last=0"
rs5.Open Addera, Connect, 3, 3
if not rs5.eof then
do until rs5.eof
rs5("last")=1
rs5.update
rs5.movenext
loop
if request.querystring("action")="spara" then
if session("id") <> request.querystring("id") then
Connect.Open "Driver={Microsoft Access Driver (*.mdb)}; DBQ=" & server.mappath ("****")&";pwd=****"
rs("namn")= session("anv")
rs("inlagg")=request.form("inlagg")
rs("gbid")= request.querystring("id")
rs("namnid")=session("id")
rs("datum") = now
sql = "Insert Into gb(namn, inlagg, gbid, namnid, [datum])"&"Values('"& session("anv")& "',"&"'"& request.form("inlagg") &"',"&"'"& request.querystring("id") &"',"&"'"& session("id")& "','"& now &"')"
Connect.execute(sql)
Connect.close
Connect.Open "Driver={Microsoft Access Driver (*.mdb)}; DBQ=" & server.mappath ("*******")&";pwd=*******"
Set rs2 = Server.CreateObject("ADODB.Recordset")
sql = "SELECT * FROM anv where id='"&session("id")&"'"
rs2.Open sql, Connect, 3, 3
gast = rs2("gast")
status = rs2("status")
sql="update anv SET status=" &status + poanggastbok&", gast=" &gast + 1&" &nbspwhere id='"&session("id")&"'"
Connect.close
response.redirect "gastbok.asp?id="&request.querystring("id")
rs.PageSize = 10
if not rs.EOF then
rs.AbsolutePage = nextPage
<% END IF %>
StevePMedlem sedan mars 2003772 inlägg
Är datatyperna "Tal" där du använder
Isf ska du inte ha med några enkelfnuttar
Addera = "SELECT * FROM gb where gbid=" & request.querystring("id") & " order by id desc"
Addera = "SELECT * FROM gb where gbid= " & request.querystring("id") & " and last=0"
osv...
Du verkar ha en massa onödiga "&" tecken i ditt insert statement.
Varför har du t ex ett "&" tecken framför "Values" ?
"&"Values
hm..
alla extra "&" är borttagna nu, och det du skrev är ändrat, allt ska funka, men det sparas inte!
Om du skriver ut din sql, hur ser den ut då?
132 ms totalt · 3 externa anrop · v20260731065814-full.beb2e261
