hur ska jag få länke på rad 58 att öppnas i "main", använder alltså frames...
<table cellpadding="3" cellspacing="1" width="130">
<tr>
<td align="center" height="15">Senaste foruminlägg</td>
</tr>
<tr>
<td width="33%" align="center" nowrap height="25">
Dim rsLastestPostsMod
Dim adoLastestPostsModCon
Dim strLastestPostsModCon
Dim strSQLLastsPostsMod
Dim strLastestPostsModTopicSubject
Dim strMembersModForumPath
'The path to the forum
strMembersModForumPath = "../forum/"
'Database connection
'Default connection
strLastestPostsModCon = "DRIVER={Microsoft Access Driver (*.mdb)}; DBQ=" & Server.MapPath("admin/database/wwforum.mdb")
'Uncomment for a full phsyical path. Then change the path
'strLastestPostsModCon = "DRIVER={Microsoft Access Driver (*.mdb)}; DBQ=http://www.project15.org/scripts/webwizforum/forum/admin/database/wwforum.mdb"
'Uncomment for a DSN connection
'strLastestPostsModCon = "DSN=DSN_NAME"
Set adoLastestPostsModCon = Server.CreateObject("ADODB.Connection")
adoLastestPostsModCon.Open strLastestPostsModCon
Set rsLastestPostsMod = Server.CreateObject("ADODB.Recordset")
strSQLLastsPostsMod = "SELECT Top 2 tblTopic.Topic_ID, tblTopic.Subject, tblForum.Forum_ID "
strSQLLastsPostsMod = strSQLLastsPostsMod & "FROM tblForum INNER JOIN tblTopic ON tblForum.Forum_ID = tblTopic.Forum_ID "
strSQLLastsPostsMod = strSQLLastsPostsMod & "WHERE ((tblForum.Password) Is Null) "
strSQLLastsPostsMod = strSQLLastsPostsMod & "ORDER BY tblTopic.Last_entry_date DESC;"
rsLastestPostsMod.Open strSQLLastsPostsMod, adoLastestPostsModCon
If rsLastestPostsMod.EOF Then
Response.Write "<span class=""smltext"">No Forum Posts Made</span>"
Else
Do while NOT rsLastestPostsMod.EOF
If len(rsLastestPostsMod("Subject")) > 18 then
strLastestPostsModTopicSubject = left(rsLastestPostsMod("Subject"),18) & "... "
Else
strLastestPostsModTopicSubject = rsLastestPostsMod("Subject")
Response.Write("<a href=""" & strMembersModForumPath & "forum_posts.asp?TID=" & rsLastestPostsMod("Topic_ID") & "&PN=1"">" & strLastestPostsModTopicSubject & "</a>")
rsLastestPostsMod.MoveNext
If NOT rsLastestPostsMod.EOF Then Response.Write("<br>")
Loop
'Reset Server Objects
rsLastestPostsMod.Close
Set rsLastestPostsMod = Nothing
adoLastestPostsModCon.Close
Set adoLastestPostsModCon = Nothing
%></td>
</tr>
</table>
