Har fått ett litet problem! hoppas nån kan hjälpa mig
Felmeddelande:
ADODB.Connection.1 error '800a0bb9'
The application is using arguments that are of the wrong type, are out of acceptable range, or are in conflict with one another.
/booking/check_bokning.asp, line 13
på koden:
[B]<RAD 13>[/B] Connect.Open ("DRIVER={Microsoft Access Driver (*.mdb)}; DBQ=" & Server.MapPath("/db/lundin.mdb"))
list = "Select * from boka where stuga = '"&Request.QueryString("stuga")&"' and bokad = 2 order by artal,week"
RecSet.Open list, Connect, 1, 2
<table width="50%" border="0" align="center" cellpadding="0" cellspacing="0">
<tr>
<td width="30%" height="20"><div align="left"><strong><font size="-3" face="Verdana, Arial, Helvetica, sans-serif">Årtal</font></strong></div></td>
<td width="32%"><div align="right"><strong><font size="-3" face="Verdana, Arial, Helvetica, sans-serif">Vecka</font></strong></div></td>
<td> <div align="right"><strong><font size="-3" face="Verdana, Arial, Helvetica, sans-serif">Stuga</font></strong></div></td>
</tr>
</table>
<hr width="450" />
if RecSet.Eof then
Response.Write "Just nu finns det 52 veckor lediga"
Do Until RecSet.EOF %>
<tr>
<td width="31%"><font size="-3" face="Verdana, Arial, Helvetica, sans-serif"><%=RecSet("artal")%>
</font> <div align="center"></div>
<div align="center"></div></td>
<td width="27%"><div align="right"><font size="-3" face="Verdana, Arial, Helvetica, sans-serif"><%=RecSet("week")%>
</font> </div>
<td> <div align="right"><font size="-3" face="Verdana, Arial, Helvetica, sans-serif"><%=RecSet("stuga")%>
</font> </div>
<div align="right"></div></td>
</tr>
RecSet.MoveNext
Loop
RecSet.Close
Connect.Close
Set RecSet = Nothing
Set Connect = Nothing
