nytt fel, connection
5 svar · 216 visningar · startad av Ceeron
Medlem sedan aug. 2000378 inlägg
Detta funkade fint innan jag bytte ut min connection... nån som ser ett fel?
	strNamn = Replace(Request.Form("namn"), "'", "''")
	strSmeknamn = Replace(Request.Form("smeknamn"), "'", "''")
	strAlder = Replace(Request.Form("alder"), "'", "''")
	strBor = Replace(Request.Form("bor"), "'", "''")
	strMusiksmak = Replace(Request.Form("musiksmak"), "'", "''")
	strDricker = Replace(Request.Form("dricker"), "'", "''")
	strMinne = Replace(Request.Form("minne"), "'", "''")
	strDackning = Replace(Request.Form("dackning"), "'", "''")
	strOl = Replace(Request.Form("ol"), "'", "''")
	strDrink = Replace(Request.Form("drink"), "'", "''")
	strSpy = Replace(Request.Form("spy"), "'", "''")
	strEpost = Replace(Request.Form("epost"), "'", "''")
	strNamn = Replace(strNamn, "%", "")
	strSmeknamn = Replace(strSmeknamn, "%", "")
	strAlder = Replace(strAlder, "%", "")
	strBor = Replace(strBor, "%", "")
	strMusiksmak = Replace(strMusiksmak, "%", "")
	strDricker = Replace(strDricker, "%", "")
	strMinne = Replace(strMinne, "%", "")
	strDackning = Replace(strDackning, "%", "")
	strOl = Replace(strOl, "%", "")
	strDrink = Replace(strDrink, "%", "")
	strSpy = Replace(strSpy, "%", "")
	strEpost = Replace(strEpost, "%", "")
	If Request.Form("nyhetsbrev") = "True" Then
		strNyhetsbrev = "True"
	Else
		strNyhetsbrev = "False"
	sql=	"update anv set "&_
		"namn = '" &strNamn& "', "&_
		"smeknamn = '" &strSmeknamn& "', "&_
		"alder = '" &strAlder& "', "&_
		"bor = '" &strBor& "', "&_
		"musiksmak = '" &strMusiksmak& "', "&_
		"dricker = '" &strDricker& "', "&_
		"minne = '" &strMinne& "', "&_
		"dackning = '" &strDackning& "', "&_
		"ol = '" &strOl& "', "&_
		"drink = '" &strDrink& "', "&_
		"spy = '" &strSpy& "', "&_
		"epost = '" &strEpost& "', "&_
		"nyhetsbrev = " &strNyhetsbrev& " "&_
		"where anvID = " &Session("ID")
	'objConnect.Execute(sql),,128
	'Response.Redirect("admin.asp?admin=form")
	write sql
om jag srkiver ut sql så får jag =
update anv set namn = 'Jocke', smeknamn = 'alkis, pungis', alder = '1985-05-18', bor = 'Huddinge', musiksmak = '', dricker = 'allt med alkohol...', minne = 'kommer inte ihåg...', dackning = 'Någon av DE på kräftskivan', ol = 'Spendrups', drink = 'Peach...', spy = 'Whiskey', epost = 'jocke@alkisarna.com', nyhetsbrev = True where anvID = 1
Vad är probelemet?
Får du något felmeddelande?
Om det fungerade fint innan du bytte connection, så ligger felet/problemet inte i den kodbit du visade nu.
får:
Microsoft JET Database Engine error '80040e14'
Syntax error in UPDATE statement
Men alltså jag bytte från DSN till en vanligt koppling. Skrev om det nån annanstans... Undrar om det är nån som ser något fel? Är det något med det där True / False?
Tja... kanske testa använda -1 istället för True och 0 istället för False och kolla om det fungerar bättre då.
fråga mig inte varför men jag klamrade typ allt och skrev det på en rad istället och helt plötsligt så funka det =)
120 ms — deklarationer (db)
121 ms — ändringar (db)
