CSS igen!!
7 svar · 232 visningar · startad av Hallgren
HallgrenMedlem sedan dec. 19991 606 inlägg
Vad är det som är fel? :l
->Aarrgghh<-
<%="<font face='verdana' size='1'>"&date&"</font>" & "<br>"%>
Connect.Open "driver={Microsoft Access Driver (*.mdb)};dbq=c:\inetpub\wwwroot\databaser\kallarenkronan\veckans.mdb"
set rs = Connect.execute ("SELECT TOP 1 * FROM Veckans ORDER BY ID DESC")
if not rs.eof then
	response.write "<b>" & "Måndag: " & "</b>" & "<br>" & rs("Mandag1")  & VBCrLf
	response.write "<br>" & rs("Mandag2") & "<p>" & VBCrLf
	response.write "<b>" & "Tisdag: " & "</b>" & "<br>" & rs("Tisdag1")  & VBCrLf
	response.write "<br>" &  rs("Tisdag2") & "<p>" & VBCrLf
	response.write "<b>" & "Onsdag: " & "</b>" & "<br>" & rs("Onsdag1")  & VBCrLf
	response.write "<br>" &  rs("Onsdag2") & "<p>" & VBCrLf
    response.write "<b>" & "Torsdag: " & "</b>" & "<br>" & rs("Torsdag1") & VBCrLf
    response.write "<br>" &  rs("Torsdag2") & "<p>" & VBCrLf
 	response.write "<b>" & "Fredag: " & "</b>" & "<br>" & rs("Fredag1")  & VBCrLf
    response.write "<br>" &  rs("Fredag2") & "<p>" &  VBCrLf
    response.write "<b>" & "Lördag: " & "</b>" & "<br>" & rs("Lordag") & "<p>" & VBCrLf
    response.write "<b>" & "Söndag: " & "</b>" & "<br>" & rs("Sondag") & "<p>" & VBCrLf
    response.write "<b>" & "Pasta: " & "</b>" & "<br>" & rs("Pasta") & "<p>" & VBCrLf
    response.write "<b>" & "Sallad: " & "</b>" & "<br>" & rs("Sallad") & "<p>" & VBCrLf
    response.write "<b>" & "Vegitarisk: " & "</b>" & "<br>" & rs("Veg") & "<p>" & VBCrLf
    response.write "<b>" & "Veckans: " & "</b>" & "<br>" & rs("Veckans") & "<p>" & VBCrLf
	response.write"</font>"
rs=close
Connect.close
set Connect=nothing
Använder Stylesheet. (<link rel="STYLESHEET" href="style.css" type"text/css"> )
A:link { font-family: arial, helvetica, verdana; font-size:9pt; color: #000000; text-decoration: none }
A:visited { font-family: arial, helvetica, verdana; font-size:9pt; color: #000000; text-decoration: none }
A:active { font-family: arial, helvetica, verdana; font-size:9pt; color: #000000; text-decoration: none }
A:hover { font-family: arial, helvetica, verdana; font-size:9pt; color: #000000; text-decoration: underline; }
TD { font-family: ariel, helvetica, verdana; font-size:9pt; color: #000000}
P { font-family: ariel, helvetica, verdana; font-size:9pt; color: #000000}
Forumledare, webForum
[Redigerat av Hallgren den 15 mar 2001]
hur ser den resulterande html-koden ut då?
respect my authoritaah!</A>
<html>
<link rel="STYLESHEET" href="style.css" type="text/css">
<body bgcolor="#FFFFFF" text="#000000" link="#000000" vlink="#000000" alink="#000000" background="bg_2.gif">
<font face='verdana' size='1'>2001-03-15</font><br><b>Måndag: </b><br>Då är det bara css problemet kvar!!
<br>Då är det bara css problemet kvar!!<p>
<b>Tisdag: </b><br>Då är det bara css problemet kvar!!
<b>Onsdag: </b><br>Då är det bara css problemet kvar!!
<b>Torsdag: </b><br>Då är det bara css problemet kvar!!
<b>Fredag: </b><br>Då är det bara css problemet kvar!!
<b>Lördag: </b><br>Då är det bara css problemet kvar!!<p>
<b>Söndag: </b><br>Då är det bara css problemet kvar!!<p>
<b>Pasta: </b><br>Då är det bara css problemet kvar!!<p>
<b>Sallad: </b><br>Då är det bara css problemet kvar!!<p>
<b>Vegitarisk: </b><br>Då är det bara css problemet kvar!!<p>
<b>Veckans: </b><br>Då är det bara css problemet kvar!!<p>
</font>
<p>&nbsp;</p><p>&nbsp;</p></body>
</html>
Vart har du den startande font-taggen som du avslutar sist?
webEye.nu SweQuake.com
du har ju varken P eller TD i Måndags-kolumnen, detta gör att den inteverkas av några formateringar alls...
Men varför funkr det på de andra? Raderna borde vara identiska med varandra (förutom veckodagarna). Håller jag på att gå blind? :l
jonneMedlem sedan jan. 20011 154 inlägg
<html>
<font face="verdana" size="1">2001-03-15</font>
<br>
[b]<p>[/b]
</html>
When people have problems using a design, it's not because they are stupid. It's because the design is too difficult. (Jakob Nielsen)
response.write [b]"<p>"[/b] & "<b>" & "Måndag: " & "</b>" & "<br>" & rs("Mandag1") & VBCrLf
Muhahah!
