Plocka fram säljes
24 svar · 365 visningar · startad av costodia
Medlem sedan aug. 2000864 inlägg
Jag har ett radannonssytem som ser ut så här:
<table width="600" border="0" cellpadding="3" cellspacing="0">
mypage = Request("whichpage")
If mypage = "" then
   mypage = 1
mypagesize = 10
SQL = "Select * From Radannonser ORDER By datum DESC"
Set rstemp = Server.Createobject("ADODB.Recordset")
rstemp.cursorlocation = 3
rstemp.cachesize = 5
MdbFilePath = Server.MapPath("../asp/hundbazar.mdb")
rstemp.open SQL, "Driver={Microsoft Access Driver (*.mdb)}; DBQ=" & MdbFilePath & ";"
If rstemp.EOF then
   Response.write "Där fanns det ju inget... " & sok
Else
   rstemp.movefirst
   rstemp.pagesize = mypagesize
   maxcount = Cint(rstemp.pagecount)
   rstemp.absolutepage = mypage
   howmanyrecs = 0
   howmanyfields = rstemp.fields.count -1
   Do While Not RStemp.EOF AND howmanyrecs < rstemp.pagesize
   counter = counter + 1
   If counter mod 2 = 0 then
      color = "#E0D2BF"
   Else
      color = "#FFFFFF"
   Response.write "<tr bgcolor='" & color & "'><td><B>" & RStemp("kategori") & "</B><BR><B>Annonstext:</B><BR>"&RStemp("annonstext")&"<BR><B>Telefon:"&RStemp("telefon")&"</B><BR><B>E-post: </B><A HREF='mailto:" & RStemp("epost") & "'>" & RStemp("epost") & "</A><BR><B>Namn:</B> "&RStemp("namn")&"<BR><B>Rubrik:</B>"&RStemp("rubrik")&"</TD></tr>"
   rstemp.movenext
   howmanyrecs = howmanyrecs + 1
   Loop
   rstemp.close
   Set rstemp = nothing
  <tr>
    <td width="400"><hr class="hundbazarlight" size="1" noshade>
    </td>
    <td></td>
  </tr>
  <tr>
    <td width="400"><%
   If maxcount <> 0 then
   response.write "sida " & mypage & " av " & maxcount & "<br>" & sidor:
   pad = "0"
   scriptname = request.Servervariables("script_name")
   for counter = 1 to maxcount
   If counter >= 10 then
      pad = ""
   ref = "<a href='" & scriptname & "?whichpage=" & counter & "&pagesize=" & mypagesize & "'>" & pad & counter & "</a> "
   response.write ref & " "
   if counter mod 10 = 0 then
      response.write "<br>"
   Next
</td>
    <td></td>
  </tr>
</table>
Nu vill jag kunna plocka fram så att man kan välja att bara se de annonser som finns under säljes.
Går det?
Genom att skriva
SQL = "Select * From Radannonser ORDER By kategori DESC"
http://www.costodia.com/hundbazar/show-only.asp så fick jag de sorterade kategorivis, men nu undrar jag alltså om det finns något sätt att helt och hållet bara visa en av de olika kategorierna, säljes, köper, bytes etc
Mvh Martin Persson
www.Costodia.com
Javisst.
SQL = "Select * From Radannonser WHERE Kategori=den_kategori_du_vill_ha"
det vill inte funka det blir bara
Microsoft OLE DB Provider for ODBC Drivers error '80040e10'
[Microsoft][ODBC Microsoft Access Driver] Too few parameters. Expected 1.
/hundbazar/show-only.asp, line 70
http://costodia.com/hundbazar/show-only.asp när jag skriver
SQL = "Select * From Radannonser WHERE Kategori=Avel"
vad kan detta bero på?
Mvh Martin Persson
www.Costodia.com
Det skall vara
SQL = "Select * From Radannonser WHERE Kategori='Avel'"
Dvs om kolumnen kategori är av typen char så anger man sökvärdet inom ''. Annars kommer man att tolka Avel som ett kolumnnamn
nu skulle jag vilja ha det på en och samma aspsida går det och hur skulle en sådan länk i så fall se ut?
Det blev lite krånglikt att ha det på 7 olika sidor (alltså en för varje kategori)
Tack på förhand,
Mvh Martin Persson
www.Costodia.com
Medlem sedan okt. 20001 558 inlägg
SQL = "Select * From Radannonser WHERE Kategori='" & Request.QueryString("sortera_efter") & "'"
"I have to return some video tapes" - Patrick Bateman, American Psycho
jag gjorde som du sa men när jag skriver in http://costodia.com/hundbazar/showkati.asp?Kategori=Avel
så säger den att:
fast att jag vet att det finns en kategori som heter avel.
finns det något annat sätta anropa på?
Mvh Martin Persson
www.Costodia.com
Hur ser skriptet/databasen ut nu?
scriptet ligger överst på denna sida,
det är hela scriptet,
T ex Avel är ett värde i en av cellerna
jag vet inte om du förstår bättre nu, databasen har en tabell som heter radannonser i den finns bland annat en kolumn som heter Kategori och det är ibland dessa jag nu vill välja,
där bland annat avel, bytes, köpes och säljes finns med.
jag gjorde en screenshot på hela databasen här http://www.costodia.com/finans/hund.gif
Mvh Martin Persson
www.Costodia.com
SQL = "Select * From Radannonser WHERE Kategori='" & request.querystring("kategori") & "' ORDER By datum DESC"
tack så jättemycket än en gång Gunnar!
det funkade
Mvh Martin Persson
www.Costodia.com
företsen hur gör jag för att visa samtiliga kategorier samtidigt?
Mvh Martin Persson
www.Costodia.com
Vad menar du med alla?
Ifall jag inte helt missuppfattar dig så är det väl bara att hämta allt i SQL-satsen. Alltså inget WHERE utan bara SELECT * FROM osv.
då blir det
Microsoft OLE DB Provider for ODBC Drivers error '80040e14'
[Microsoft][ODBC Microsoft Access Driver] Syntax error in FROM clause.
/kompis/index.asp, line 66
Mvh Martin Persson
www.Costodia.com
Detta borde funka...
okej, men om jag jag använder denna koden hur gör jag för att visa alla kategorier efter senast inlägda annan då utan att skriva om
Mvh Martin Persson
www.Costodia.com
Medlem sedan feb. 200131 inlägg
Phew... det tog mig ju nästan hela natten att läsa igenom allt... Har tyvär inget svar på din senaste fråga!
Fråga: Varför läsa onödig matematik?
Svar: Det är bra för den intellektuella stimulansen!
Medlem sedan jan. 2000144 inlägg
Du kan kontroller i ASP'n om request.querystring("kategori")="*" och då göra en SQL där du utesluter WHERE Kategori=...
Du måste skriva om kod, men inte så mycket. :)
nu kom jag på en rätt så smart grej, jag använder fortfarande Vides kod från FAQen om hur man delar upp ett recordset på många sidor.
Problemet är nu att om jag skriver in http://www.costodia.com/hundbazar/default.asp?Kategori=Säljes och använder denna remsa
så lyckas jag plocka ut säljes som jag vill och sedan listar sidan längst ner på sidan länkar till de 26 sidor som finns med säljes till skillnad från de 50 som finns utan kategoriindelning, problemet är att om man trycker på en av dessa 26 länkar längst ner på sidan så så kommer det upp
jag misstänkar att det är något som är fel i anropet men jag kan inte lista ut vad, så om någon kan hjälpa mig skulle jag bli jätteglad.
Mvh Martin Persson
www.Costodia.com
Du måste skicka med alla paramterar i länken också... t.ex kategori.
Jourhavande @e SweQuake.com
262 ms totalt · 4 externa anrop · v20260731065814-full.86ec41c2
118 ms — deklarationer (db)
116 ms — ändringar (db)
