Vad är fel
1 svar · 161 visningar · startad av andreas_lindh
Medlem sedan jan. 20011 140 inlägg
Jag använder det här scriptet för att visa vilka som är inloggade men felet är att den bara skriver ut en person.
Topic = request.form("group")
Application.Lock
If Not IsEmpty(Application.Contents("Users")) Then
Users = Application("Users")
Group = Application("UsersGroup")
NumOfUsers = UBound(Users)
For I = 0 To NumOfUsers
If Topic = Group(I) Then
Response.Write ""
Response.Write " <img align=absmiddle src='images/lips.gif' border=0> <b>" & (Session("User")) & "</b></a><br>"
Next
Application.Unlock
Och Global.asa ser ut så här
<SCRIPT LANGUAGE=VBScript RUNAT=Server>
ReDim TopicName(0)
ReDim TopicDescription(0)
Sub Application_OnStart
 ' set title
 Application("Title") = "ASP Chat"
 ' Create your chat rooms below, do not modify anything else/
 CreateRoom "ASP Joint", "ASP fiends sharing dope"
 CreateRoom "ASP Joint2", "ASP fiends sharing dope"
 CreateRoom "ASP Joint3", "ASP fiends sharing dope"
 'CreateRoom "Room Name", "Room Description"
 Application("TopicNames") = TopicName
 Application("TopicDescriptions") = TopicDescription
 Dim Users()
 Redim Users(1)
 Dim UsersGroup()
 Redim UsersGroup(1)
 Application("Users") = User
 Application("UsersGroup") = UsersGroup
 Dim UsersIP()
 Redim UsersIP(1)
 Dim UsersTimeOn()
 Redim UsersTimeOn(1)
 Dim UsersIdleOn()
 Redim UsersIdleTime(1)
 Application("UsersIP") = UsersIP
 Application("UsersTimeOn") = UsersTimeOn
 Application("UsersIdleTime") = UsersIdleTime
End Sub
Sub Session_OnStart
Session.Timeout=2
End Sub
Sub Session_OnEnd
Topic = Session("Topic")
Name = Session("User")
UsersIP = Application("UsersIP")
UsersTimeOn = Application("UsersTimeOn")
UsersIdleTime = Application("UsersIdleTime")
Match = 1
If IsArray(Users) Then
       UsersGroup = Application("UsersGroup")
       If NumOfUsers = 1 Then
             Set Application("Users") = Nothing
             Set Application("UsersGroup") = Nothing
             Set Application("UsersIP") = Nothing
             Set Application("UsersIdleTime") = Nothing
             Set Application("UsersTimeOn") = Nothing
       Else
          ReDim UpdatedUsers(1)
          ReDim UpdatedUsersGroup(1)
          ReDim UpdatedUsersIP(1)
          ReDim UpdatedUsersTimeOn(1)
          ReDim UpdatedUsersIdleTime(1)
          For I = 1 To NumOfUsers
              If Name \<\> Users(I) Then
                   ReDim Preserve UpdatedUsers(Match)
                   ReDim Preserve UpdatedUsersGroup(Match)
                   UpdatedUsers(Match) = Users(I)
                   UpdatedUsersGroup(Match) = UsersGroup(I)
                   ReDim Preserve UpdatedUsersIP(Match)
                   ReDim Preserve UpdatedUsersTimeOn(Match)
                   ReDim Preserve UpdatedUsersIdleTime(Match)
                   UpdatedUsersIP(Match) = UsersIP(I)
                   UpdatedUsersTimeOn(Match) = UsersTimeOn(I)
                   UpdatedUsersIdleTime(Match) = UsersIdleTime(I)
                   Match = Match + 1
          Next
          Application("Users") = UpdatedUsers
          Application("UsersGroup") = UpdatedUsersGroup
          Application("UsersIP") = UpdatedUsersIP
          Application("UsersTimeOn") = UpdatedUsersTimeOn
          Application("UsersIdleTime") = UpdatedUsersIdleTime
Set fileObject = Server.CreateObject("Scripting.FileSystemObject")
textFile = Application("filebase") & Replace(Topic, "+", "_") & ".txt"
'If fileObject.FileExists(textfile) Then
Set inStream = fileObject.OpenTextFile(textFile,1,TRUE,FALSE)
file = inStream.ReadAll
Set inStream = Nothing
     file = file & "\<FONT SIZE=2 FACE='Vedana,Arial' Color=#808080\>\<b\>\*\*\*\[" &  Name & " has exited (" & Now & ")\]\*\*\*\</b\>\</FONT\>\<br\>"
     Set outStream = fileObject.CreateTextFile(textFile,True)
     outStream.WriteLine(file)
 outStream.Close
     Set outStream = Nothing
'End If
Session("Enter") = True
End Sub
Sub CreateRoom(Name, Description)
nLen = UBound(TopicName)+1
ReDim Preserve TopicName(nLen)
TopicName(nLen) = Name
ReDim Preserve TopicDescription(nLen)
TopicDescription(nLen) = Description
End Sub
Hoppas Att någon kan hjälpa mig även fast det är lite mycket kod
Jag fattar inte riktigt hur det är tänkt.....
Men...
Variabeln I loopar igenom arrayen Users, men används med Group-arrayen. Varför?
Session("User") innehåller bara den inloggade användarens namn. Det är väl användarna i Application("Users")-arrayen du vill åt?
Det ska väl vara Users?
267 ms totalt · 4 externa anrop · v20260731065814-full.a51de22e
126 ms — deklarationer (db)
122 ms — ändringar (db)
