hmm... varför har du skrivit:
if not rst.eof then
ska de inte vara:
if rst.eof then
bara en tanke...
MVH
nakoz :)
8 svar · 185 visningar · startad av aleborg
Har en kod som ser ut så här:
Dim mySmartUpload
dim Conn
' Variables
' Object creation
Set mySmartUpload = Server.CreateObject("aspSmartUpload.SmartUpload")
SQL2="SELECT * From Master, Kunder WHERE Master.Username='"& mySmartUpload.Form("Username") &"' Or Kunder.Username='"& mySmartUpload.Form("Username") &"'"
set rst=conn.execute(SQL2)
if not rst.eof then
response.write "Användarnamnet är upptaget, gå tillbaka och försök igen </tr></table></td></tr></table>"
Dim intCount
' Upload
mySmartUpload.Upload
' Save the files with their original names in a virtual path of the web server
intCount = mySmartUpload.Save("../upload/kunder")
' sample with a physical path
' intCount = mySmartUpload.Save("c:\temp\")
' Display the number of files uploaded
Response.Write(intCount & " <font class=iebla>filer upladdade.</font>")
<!--#include virtual="unisafe\admin\anders.inc"-->
set rs= Server.CreateObject("ADODB.Recordset")
SQL= "SELECT * FROM Kunder WHERE 1=2"
rs.Open SQL,Conn,1,2
rs.AddNew
For each file In mySmartUpload.Files
rs(file.name)=file.filename
next
rs("Namn")=mySmartUpload.Form("Namn")
rs("Webadress") =mySmartUpload.Form("Webadress")
rs("Username") =mySmartUpload.Form("Username")
rs("Password") =mySmartUpload.Form("Password")
rs("Foretag") =mySmartUpload.Form("Foretag")
rs("Adress") =mySmartUpload.Form("Adress")
rs("Postnr") =mySmartUpload.Form("Postnr")
rs("Ort") =mySmartUpload.Form("Ort")
rs("Land") =mySmartUpload.Form("Land")
rs("Tel") =mySmartUpload.Form("Tel")
rs("Fax") =mySmartUpload.Form("Fax")
rs("Mobil") =mySmartUpload.Form("Mobil")
rs("Email") =mySmartUpload.Form("Email")
rs("Ovrigt") =mySmartUpload.Form("Ovrigt")
rs("Rabatt") =mySmartUpload.Form("Rabatt")
rs("Valkom") =mySmartUpload.Form("Valkom")
rs("Ovrigt2") =mySmartUpload.Form("Ovrigt2")
rs("Ovrigt3") =mySmartUpload.Form("Ovrigt3")
rs("Accessgroup") =mySmartUpload.Form("Accessgroup")
rs("Saljare") =mySmartUpload.Form("Saljare")
rs("Fil1")=mySmartUpload.Files(1).Filename
rs("Fil1namn") =mySmartUpload.Form("Fil1namn")
rs("Fil2")=mySmartUpload.Files(2).Filename
rs("Fil2namn") =mySmartUpload.Form("Fil2namn")
rs("Fil3")=mySmartUpload.Files(3).Filename
rs("Fil3namn") =mySmartUpload.Form("Fil3namn")
rs("Fil4")=mySmartUpload.Files(4).Filename
rs("Fil4namn") =mySmartUpload.Form("Fil4namn")
rs("Fil5")=mySmartUpload.Files(5).Filename
rs("Fil5namn") =mySmartUpload.Form("Fil5namn")
rs.Update
<%End If %>
Får fel när man försöker lägga till ett Username som redan finns!
Error Type:
Microsoft OLE DB Provider for ODBC Drivers (0x80040E2F)
[Microsoft][Drivrutin för ODBC Microsoft Access]Fel i rad
/unisafe/admin/kund2.asp, line 90
Line 90:
rs.Update
Men den koden ska ju inte köras om namnet redan finns!?
[Redigerat av aleborg den 04 mar 2001]
if not rst.eof then
ska de inte vara:
if rst.eof then
bara en tanke...
MVH
nakoz :)
Det trodde jag också, men det funkar på andra sidor!
Nä, den biten är helt rätt... .eof får du ju om du inte har några poster... och har du inga poster så finns inte användarnamnet... alltså, NOT .eof är om användarnamnet redan finns...
Mvh, Vide
Jourhavande @e SweQuake.com
Men vad är felet?
När du gör din select för att undersöka om namnet finns så använder du mySmartUpload.Form("Username") . Var sätts det värdet? Du har ju bara skapat själva objektet innan. Om det värdet är odefinierat så kommer din select aldrig att hitta någon post.
Hur menar du att jag ska göra då?
Jag kan ingenting om smartupload men jag gissar att värdena fylls i när man gör detta anrop:
Om det är så så får du lägga din kontroll, om användaren finns, efter detta anrop.
Japp det stämde, tack! :)
