Redirect
12 svar · 1 364 visningar · startad av WebbisNet
WebbisNetMedlem sedan feb. 20032 027 inlägg
Var någonstans lägger man in en redirect till en annan sida, har testat och testat och testat men inget verkar fungera
<form name="write" action="write.asp?gastbok=spara" method="post">
<table class=Text1 width="400" height="270" border="0" cellpadding="0" cellspacing="0" summary="">
	<tr>
		<td>
		<center>
		<table width="350" border="0" cellpadding="0" cellspacing="0" summary="">
	<tr>
		<td class=Front width="120">Namn</td>
		<td>
		<input type="text" class=input name="Namn" value="" size="20" maxlength="40"></td>
	</tr>
	<tr>
		<td class=Front width="120">E-post</td>
		<td><input type="text" class=input name="Epost" value=""  size="30" maxlength="40"></td>
	</tr>
	<tr>
		<td class=Front width="120">Hemsida</td>
		<td><input type="text" class=input name="Hemsida" value="Http://"  size="35" maxlength="40"></td>
	</tr>
	<tr>
		<td class=Front valign="top" width="120">Meddelande</td>
		<td><textarea class=input name="Meddelande" value=""  cols=33 rows=5></textarea></td>
	</tr>
	<tr>
		<td><input type="hidden" value="<%=DATE%>"  name="Datum" size="20" maxlength="40"></td>
	</tr>
	<tr>
		<td><input type="hidden" value="<%=Request.ServerVariables("REMOTE_ADDR")%>" name="IP" size="20" maxlength="40"></td>
	</tr>
	<tr>
		<td align="center" colspan="2">
		<input type="submit" class=input value="Skicka inlägget">
		</td>
	</tr>
</table>
</center>
		</td>
	</tr>
</table>
</td>
</tr>
</table>
</td>
	</tr>
</table>
		<!-- End of main table -->
		</center>
		</td>
	</tr>
</table>
</html>
	If Request.Querystring("gastbok") = "spara" Then
		Namn = Request.Form("Namn")
		Epost = Request.Form("Epost")
		Hemsida = Request.Form("Hemsida")
		Meddelande = Request.Form("Meddelande")
		Datum = Request.Form("Datum")
		IP = Request.Form("IP")
	Set conn = Server.CreateObject("ADODB.Connection")
	conn.Open connstr
	SQL = "INSERT INTO gastbok "
	SQL = SQL & "(Namn, Epost, Hemsida, Meddelande, Datum, IP) "
	SQL = SQL & "VALUES('"& Namn &"','"& Epost &"','"& Hemsida &"','"& Meddelande &"','"& Datum &"','"& IP &"')"
	conn.Execute(SQL)
	conn.Close
<% End if %>
PoffeMedlem sedan apr. 20022 743 inlägg
	conn.Open connstr
	conn.Execute(SQL)
	conn.Close
	[B]Response.Redirect("sida.asp")[/B]
	conn.Open connstr
	conn.Execute(SQL)
	conn.Close
jag la in Response.Redirect("default.asp?View=read") efter conn.Close och innan End If men jag kommer bara tillbaka till samma sida.....det blir ingen redirect
Säker du att du sparar och uppdatera filen på servern (om du kör på någon annan server än din egen)?
Annars vet jag tyvärr inte vad det kan vara.. Lägger den till posterna då?
Jag uppdaterar direkt via ftp till servern och posten syns när man läser gästboken på servern
hmm.. ja du.. ingen aning vad det kan vara då :/
Ser att du ligger på b-one och eftersom de inte har riktig asp gissar jag på Chilli!Soft.. Testa att ta bort parantes-teknen, har för mig att chilli kan ha problem med dessa.
det är rätt att det är chilliasp men jag hade "" innan jag testade (""), men inget av dem hjälper
men tack för förslaget
Då vet jag tyvärr inte. Enligt chillis hjälpfiler är det iallafall utan paranteser.
Response.Redirect URL
Det måste ha nåt med att jag kör defaultfilen, filen för att läsa inlägg och filen för att skriva inlägg i en och samma fil......styr de tre sidorna med querystrings
Som du märker så behöver jag en paging.....men hittar inte kod som passar till chilliasp eller hur man implementerar den
PatrikB har gjort ett pagingscript som fungerar med ChiliASP. I scriptarkivet finner man detta.
atraMedlem sedan nov. 200355 inlägg
skriv response.redirect "default.asp?do=kolla_rad" <---ASP 3.0
skriv en response sådär istället för
response.redirect ("default.asp?do=kolla_rad") eftersom dethära
är ASP 2.0
290 ms totalt · 3 externa anrop · v20260731065814-full.30151723
141 ms — hämta forumlista (db)
145 ms — hämta statistik (db)
