Set objSubFolder = objFolder.SubFolders
For Each objSF In objSubFolder
[blue].
.[/blue]
Next
Jag tror det blir så... du kan ju kolla lite mer här Folders Collection.
5 svar · 368 visningar · startad av Asa
Har denna kod som söker efter filnamn i en mapp. Men nu vill jag att den ska söka igenom alla mappar i strMapp oxå.
<table width="450" border="0">
<form method="post" action="sok.asp?do=sok">
<tr>
<td valign="top">
Skriv sökord:
<input type="text" name="searchtext"> <input type="submit" value="starta sökning">
</td>
</tr>
</table>
<%If Request.QueryString("do") = "sok" Then%>
<b>Sök resultat för: <%=Request("SearchText")%></b><br>
<%Const fsoForReading = 1
strMapp = "MAPPNAMN"
Mappen = Server.MapPath(strMapp)
MappUrl = Mid(Mappen, InStrRev(Mappen, "\") + 1)
strSearchText = Request("SearchText")
Set objFSO = Server.CreateObject("Scripting.FileSystemObject")
Set objFolder = objFSO.GetFolder(Mappen)
bolFileFound = False
For Each objFile in objFolder.Files
If Response.IsClientConnected then
If InStr(1,objFile.Name,strSearchText,1) then
Response.Write "<b>»</b> <a href=" & MappUrl & "/" & objFile.Name & ">" & objFile.Name & "</a><br>"
bolFileFound = True
Next
if Not bolFileFound then Response.Write "Inga sökresultat..."
Set objFolder = Nothing
Set objFSO = Nothing
End If%>
[blue].
.[/blue]
Next
Ska testa! Tack...
Så här? Men det funkar ju ej
<tr>
<td valign="top">
Skriv sökord:
</td>
</tr>
</table>
Response.Write "<b>»</b> <a href=" & Mappen & objFile.Name & " target=""_blank"">" & objFile.Name & "</a><br>"
bolFileFound = True
Next
If InStr(1,objSF.Name,strSearchText,1) then
Response.Write "<b>»</b> <a href=" & Mappen & "/" & objSF.Name & ">" & objSF.Name & "</a><br>"
bolFileFound = True
Next
End If%>
Du måste ju "gå in" in mappen och söka för varje mapp som hittas, typ:
<tr>
<td valign="top">
Skriv sökord:
</td>
</tr>
</table>
bolFileFound = True
Next
For Each objFile in objSF.Files
bolFileFound = True
Next
Next
Set objSubFolder = Nothing
End If%>
GÅr väl iofs att göra smidigare genom att lägga det i en fuktion samt att den då kan söka ännu djupare ner. Nu klarar det ju bara en undernivå.
Nån som vet hur man gör en funktion av detta då?
