Får felet
Current Recordset does not support bookmarks. This may be a limitation of the provider or of the selected cursortype.
på Line 139 vilket är
.AbsolutePage = VarSerial
VarContactID = Request.QueryString("ID")
VarSerial = Request.QueryString("Serial")
If VarSerial = "" Then VarSerial = 1
Sub PageNavigation(nPage, nTotPages)
Dim strScriptName ' AS String
Dim I ' AS Integer
strScriptName = Request.ServerVariables("SCRIPT_NAME")
' If not first page, then show previous
If CInt(nPage) <> 1 Then
Response.Write("<td align=""right"" width=""29""><a href=""" & strScriptName & "?" & _
"Serial=" & nPage - 1 & """><img src=""images/main/dartleft.jpg"" border=""0"" WIDTH=""19"" HEIGHT=""21""></a></td>")
End If ' end previous
If CInt(nPage) <> CInt(nTotPages) Then
Response.Write("<td align=""right"" width=""25""><a href=""" & strScriptName & "?" & _
"Serial=" & nPage + 1 & """><img src=""images/main/dartright.jpg"" border=""0"" WIDTH=""19"" HEIGHT=""21""></a></td>")
End If ' end next page
End Sub
Function DisplayData()
Dim ObjConn
Dim ObjRs
Set ObjConn = Server.CreateObject("ADODB.Connection")
Set ObjRs = Server.CreateObject("ADODB.RecordSet")
ObjConn.Open Connect_String()
If VarSerial = "" then
VarSerial = "0"
If VarContactID = "" then
VarContactID = "0"
With objRS
.CacheSize = 5
.PageSize = 1
.Open "spPostlistUser_Data " & VarContactID & "," & VarSerial, ObjConn, 3, 1
.PageSize = 1
End With
intCount = objRS.RecordCount
intTotPages = objRS.PageCount
IF Not ObjRs.EOF then
VarClient = Trim(ObjRs("OrgShortName"))
VarSerialNumber = Trim(ObjRs("SerialNumber"))
VarReceivedDate = Trim(ObjRs("ReceivedDate"))
VarSentDate = Trim(ObjRs("SentDate"))
VarSender = Trim(ObjRs("Sender"))
VarSentFrom = Trim(ObjRs("SentFrom"))
VarSentTitle = Trim(ObjRs("SentTitle"))
VarNotes = Trim(ObjRs("Notes"))
VarDescription = Trim(ObjRs("Description"))
If VarReceivedDate = "" then
Else
VarReceivedDate = Formatdatetime(VarReceivedDate,1)
If VarSentDate = "" then
VarSentDate = ""
Else
VarSentDate = Formatdatetime(VarSentDate,1)
Do Until objRS.EOF or nRecCount >= objRS.PageSize
nRecCount = nRecCount + 1
ObjRs.MoveNext
Loop
End IF
End Function
