upload????
2 svar · 125 visningar · startad av crisse6
crisse6Medlem sedan dec. 20002 526 inlägg
what´s wrong?
funkar perfekt i PWS...men ej på nätet...???? :x
får detta mess:
Server object error 'ASP 0177 : 800401f3'
Server.CreateObject Failed
/groda/scripts.asp, line 62
Invalid class string
och koden... (har markerat rad 62 med fetstil)
<!-- #include file="adovbs.inc" -->
<!-- #include file="checkb.inc" -->
<html>
<meta http-equiv="content-type" content="text/html; charset=iso-8859-1">
<title>kolla in.</title>
<meta name="generator" content="Namo WebEditor v3.0">
<body bgcolor="#FFAE22" text="white" link="white" vlink="purple" alink="red">
<p>&nbsp;
<div align="center"><table border="0" cellpadding="0" cellspacing="4" width="98%">
    <tr>
        <td width="159" valign="top"><p class="leading150">&nbsp;</p>
            <p class="leading150"><font face="Verdana" size="1" color="white"><b>kolla
            in...</b></font></p>
            <p class="leading150"><font face="Verdana" size="1" color="white"><b>>></b></font><a href="chat.asp"><font
             face="Verdana" size="1" color="white"><b>chatten</b></font></a><font
             face="Verdana" size="1" color="white"><b><br> >></b></font><a href="melodier.asp"><font
             face="Verdana" size="1" color="white"><b>ringsignaler</b></font></a><font
             face="Verdana" size="1" color="white"><b><br> >></b></font><a href="top10.asp"><font
             face="Verdana" size="1" color="white"><b>top 10</b></font></a><font
             face="Verdana" size="1" color="white"><b><br> >></b></font><a href="lankar.asp"><font
             face="Verdana" size="1" color="white"><b>l&auml;nktips</b></font></a><font
             face="Verdana" size="1" color="white"><b><br> >></b></font><a href="albumet.asp"><font
             face="Verdana" size="1" color="white"><b>fotoalbumet</b></font></a><font
             face="Verdana" size="1" color="white"><b><br> >></b></font><a href="scripts.asp"><font
             face="Verdana" size="1" color="white"><b>scripts</b></font></a><font
             face="Verdana" size="1" color="white"><b><br> >></b></font><a href="help.asp"><font
             face="Verdana" size="1" color="white"><b>eller hj&auml;lpen</b></font></a><font
             face="Verdana" size="1" color="white"><b><br> >></b></font><a href="logout.asp"
             target="_parent"><font face="Verdana" size="1" color="white"><b>logga
            ut</b></font></a></p>
            <p class="leading150">&nbsp;</td>
        <td width="10" valign="top" background="vert.jpg"><p class="leading150">&nbsp;&nbsp;</td>
        <td width="769" valign="top"><p class="leading150">&nbsp;</p>
            <p class="leading150"><font face="Verdana" size="4">Scripts</font></p>
            <p><font face="Verdana" size="1" color="black">Aha, beh&ouml;ver
            du lite scrits f&ouml;r hemsidan? Hopp d&aring; kan du g&ouml;ra
            n&aring;gra fynd h&auml;r,<br> f&ouml;r jag har lagt ut n&aring;gra
            f&aring; scripts, men &auml;nd&aring; dom jag tycker mest om och
            som <br> &auml;r n&ouml;dv&auml;ndiga. Scripten laddas ner i zip-format,
            d&auml;r det ocks&aring; f&ouml;ljer med en<br> &quot;Readme&quot;
            fil med hj&auml;lp om hur du ska g&aring; till v&auml;ga f&ouml;r
            att det ska fungera helt <br> och h&aring;llet. Som du ser i tabellen
            nedanf&ouml;r finns det scripts som bes&ouml;kare har laddat upp....
            <br> det kan du ocks&aring; g&ouml;ra l&auml;ngst ner p&aring; sidan.</font></p>
            <p><B><font face="Verdana" size="1" color"black">Dessa script finns för tillfället:</B></font><BR><BR>
<font face="Verdana" size="1" color="black"><TABLE BORDER=0 CELLPADDING=3 CELLSPACING=0>
<TR BGCOLOR="White"><TD><font face="Verdana" size="1" color="black"><B>Scriptnamn:</B></FONT></TD><TD><font face="Verdana" size="1" color="black"><B>Storlek:</B></FONT></TD><TD><font face="Verdana" size="1" color="black"><B>Filtyp:</B></FONT></TD><TD><font face="Verdana" size="1" color="black"><B>Filen laddades upp:</B></FONT></TD>
' Create an instance of the FileSystemObject
[b]Set MyFileObject=Server.CreateObject("Scripting.FileSystemObject")[/b]
' Create Folder Object
Set MyFolder=MyFileObject.GetFolder(Server.MapPath("files"))
'Loop trough the files in the folder
FOR EACH thing in MyFolder.Files
<TR BGCOLOR="#F7F7E7"><TD><font face="Verdana" size="1" color="black"><A HREF="files/<%=thing.Name%>"><font face="Verdana" size="1" color="black"><%=thing.Name%></A></TD></font><font face="Verdana" size="1" color="black"><TD ALIGN=RIGHT><font face="Verdana" size="1" color="black"><%=thing.Size%>bytes</TD></font><TD><font face="Verdana" size="1" color="black"><%=thing.Type%></TD><font face="Verdana" size="1" color="black"><TD><font face="Verdana" size="1"><font face="Verdana" size="1" color="black"><%=thing.DateCreated%></TD></font>
NEXT
</TABLE></font></td>
    </tr>
</table></div>
<font face="Verdana" size="1" color="black"><a href="upload.asp">ladda upp</a>
<!-- #include file="checkb2.inc" -->
</html>
RossifumiMedlem sedan okt. 20001 558 inlägg
Kanske inte har rättigheter att köra det?
"I have to return some video tapes" - Patrick Bateman, American Psycho
hur vet man det då?
