NextPage
ASPur ASP
3 svar · 164 visningar · startad av costodia
costodiaMedlem sedan aug. 2000864 inlägg
Jag skulle kunna vilja trycka nextpage på min sida http://www.costodia.com/kompis/index.asp?whichpage=11&pagesize=10
hur skulle en sådan kod kunna se ut?
jag använder denna kod:
<table>
mypage = Request("whichpage")
If mypage = "" then
   mypage = 1
mypagesize = 10
SQL = "Select * From tabell Order by fält"
Set rstemp = Server.Createobject("ADODB.Recordset")
rstemp.cursorlocation = 3
rstemp.cachesize = 5
MdbFilePath = Server.MapPath("path/databas.mdb")
rstemp.open SQL, "Driver={Microsoft Access Driver (*.mdb)}; DBQ=" & MdbFilePath & ";"
If rstemp.EOF then
   Response.write "Där fanns det ju inget... " & sok
Else
   rstemp.movefirst
   rstemp.pagesize = mypagesize
   maxcount = Cint(rstemp.pagecount)
   rstemp.absolutepage = mypage
   howmanyrecs = 0
   howmanyfields = rstemp.fields.count -1
   Do While Not RStemp.EOF AND howmanyrecs < rstemp.pagesize
   counter = counter + 1
   If counter mod 2 = 0 then
      color = "CCCC99"
   Else
      color = "CCCC66"
   Response.write "<tr bgcolor='" & color & "'><td>" & RStemp("fält") & "</td></tr>"
   rstemp.movenext
   howmanyrecs = howmanyrecs + 1
   Loop
   rstemp.close
   Set rstemp = nothing
   <tr><td><hr></td></tr>
   <tr><td>
   If maxcount <> 0 then
   response.write "sida " & mypage & " av " & maxcount & "<br>" & sidor:
   pad = "0"
   scriptname = request.Servervariables("script_name")
   for counter = 1 to maxcount
   If counter >= 10 then
      pad = ""
   ref = "<a href='" & scriptname & "?whichpage=" & counter & "&pagesize=" & mypagesize & "'>" & pad & counter & "</a> "
   response.write ref & " "
   if counter mod 10 = 0 then
      response.write "<br>"
   Next
</td></tr>
</table>
Mvh Martin Persson
www.Costodia.com
RossifumiMedlem sedan okt. 20001 558 inlägg
Ta bara och gör en länk:
<a href="index.asp?wichpage=<% = mypage + 1 %>&pagesize=10">Next page</a>
Eller missförstod jag dig?
"I have to return some video tapes" - Patrick Bateman, American Psycho
[Redigerat av Rossifumi den 21 jan 2001]
nej, du förstod mig nog rätt,
men tyvärr verkar inte länken vilja gå till nästa sida utan stannar på sida ett på http://www.costodia.com/kompis/index.asp?wichpage=1&pagesize=10 kan det vara något mellanrum eller något som gör att det inte funkar?
Mvh Martin Persson
www.Costodia.com
Hmm, det var inte bara det att du la in den koden innan du satte "mypage"?
Vad händer annars ifall du skriver
<a href="index.asp?whichpage=<% = Request.QueryString("whichpage") + 1 %>&pagesize=10">Next page</a>
Denna kod har en bugg... du måste kolla ifall du är på sista sidan också... Borde bara gå att jämföra med pagecount ifall du är där (på sista sidan alltså) :)
147 ms totalt · 3 externa anrop · v20260731065814-full.29ac60f6
145 ms — hämta tråd, inlägg och bilagor (db)
