Arguments are of the wrong type, are out of acceptable range, or are in conflict with one another.
/assistenten.asp, line 278
Jag skickar ett värde till ett form som finns i en server.execute...
<% if request.querystring("do") = "sokning" then
Connect.Open "driver={Microsoft Access Driver (*.mdb)};dbq=" &Server.MapPath("addemalmbergadmin/tubsockan.mdb")
SQL2 = "select * from sockrates where rubrik like '%" & request.form("search1") & "%' ORDER BY ID DESC"
RecSet.Open SQL2, Connect, adOpenStatic, adLockOptimistic <---rad278
do until recset.EOF
<%=recset("ID")%> <%=recset("Rubrik")%><br>
recset.Movenext
Loop
recset.Close
går det inte eftersom den ligger i en server.execute eller? Hur kan jag göra?
If request.querystring("do") = "sokning" then
Connect.Open "Provider=Microsoft.Jet.OLEDB.4.0;Data Source=" &Server.MapPath("addemalmbergadmin/tubsockan.mdb")
Set RecSet = Connect.Execute(SQL2)
Do until recset.EOF
Response.Write(RecSet("id") & " " & RecSet("rubrik") & "<br>")
RecSet.Movenext
Loop
RecSet.Close : Set RecSet = Nothing
Connect.Close : Set Connect = Nothing
End if
253 ms totalt · 4 externa anrop · v20260731065814-full.e96017d9
