Data source name not found and no default driver specified
1 svar · 307 visningar · startad av Eclipse
Exempel från denna sidan: http://www.aspupload.com/manual_db.html
INSERT INTO [files] (bloImage, strFilename, strDescription, intFilesize) VALUES(?, 'Strategi.doc', '', 21504)
Persits.Upload.1 error '800a0018'
[Microsoft][ODBC Driver Manager] Data source name not found and no default driver specified
/files/confirm.asp, line 42
'## OPEN THE DATABASE
'## SELECT SERVER
Conn.Open "Provider=Microsoft.Jet.OLEDB.4.0;Data Source=" & Server.MapPath("\Databas\syscare.mdb")
Set Upload = Server.CreateObject("Persits.Upload")
' Capture files
Upload.Save "d:\www-kunder\syscare.se\files\"
' Obtain file object
Set File = Upload.Files("FILE1")
If Not File Is Nothing Then
-- ' Build SQL INSERT statement
-- SQL = "INSERT INTO [files] (bloImage, strFilename, strDescription, intFilesize) VALUES(?, '"
-- SQL = SQL & File.Filename & "', '"
-- SQL = SQL & Replace(Upload.Form("DESCR"), "'", "''") & "', "
-- SQL = SQL & File.Size & ")"
response.write sql
-- ' Save to database
-- File.ToDatabase Conn, SQL ' <-- rad 42
-- Response.Write "File saved."
Else
-- Response.Write "File not selected."
Engine^Medlem sedan dec. 20003 887 inlägg
Jag undrar om du inte ska ta och kolla på ADO-based File Uploads istället för ODBC-based File Upload.
