Skicka meddelanden med Flash & ASP (ASP relaterat!!!)
0 svar · 138 visningar · startad av MickeA.com
Hej.
Har en liten Community, Flash & ASP
Nu har jag fixat en grejj, för att medlemmar skall kunna skicka SMÅ, korta mess till varann.
Men det funakr inte-...
För att skicka:
Response.Expires = -1000
anv = Request.Querystring("anv")
Dim pm_fran
Dim pm_till
Dim pm
pm_fran = Request.Form("pm_fran")
pm_till = Request.Form("pm_till")
pm = Request.Form("pm")
pm_datum = now()
pm_last = "0"
Dim oConn
Dim oRec
Dim strSQL
Set oConn = Server.CreateObject("ADODB.Connection")
oConn.Open("DRIVER={Microsoft Access Driver (*.mdb)}; DBQ=" & Server.MapPath("../../hemsida_db/db_forum.mdb"))
strSQL = "SELECT Anv_Namn FROM anv_data WHERE Anv_Namn = '" & anv & "'"
Set oRec = oConn.Execute(strSQL)
If oRec.EOF Then
	Response.Write("&finns=inte")
Else
	strSQL= "INSERT INTO pm_data (Pm, Pm_Till, Pm_Fran, Pm_Datum, Pm_Last) VALUES ('" & Replace(Replace(pm, "'", "''"), "&", "och") & "', '" & Replace(Replace(pm_till, "'", "''"), "&", "och") & "', '" & Replace(Replace(pm_fran, "'", "''"), "&", "och") & "', '" & Replace(datum, "'", "''") & "', '" & Replace(pm_last, "'", "''") & "');"
	Response.Write("&finns=ja")
Set oConn = NOTHING
Set oRec = NOTHING
Set strSQL = NOTHING
Response.Write("&loaded=true")
Och för att ta emot:
Dim pm_fran
Dim pm_till
Dim pm
Dim oConn
Dim oRec
Dim strSQL
strSQL= "SELECT * FROM pm_data WHERE Pm_Last = 0 AND Pm_Till = '" & anv & "'"
If Not oRec.EOF Then
	pm_fran = oRec("Pm_Fran")
	pm_till = oRec("Pm_Till")
	pm = oRec("Pm")
	pm_datum = oRec("Pm_Datum")
		Response.Write("&datum=" & pm_datum)
		Response.Write("&pm_fran=<b>" & pm_fran & "</b> säger:")
		Response.Write("&pm_svar_fran=" & pm_fran)
		Response.Write("&pm=" & pm)
		Response.Write("&stat=skickat")
			strSQL = "UPDATE pm_data SET Pm_Last = 1 WHERE Pm_Last = 0 AND Pm_Till = '" & anv & "'"
Else
	Response.Write("Inget Nytt PM")
strSQL = ""
Set oConn = NOTHING
Set oRec = NOTHING
In Flash I got a Frameloop, which check:
if (stat == "skickat" && loaded == "true") {
	gotoAndStop(_currentframe+2);
MEN...
Det funakr inte alls. Man kan skicka till db'n, har kollat, men kolla-delen funkar inte...
Hjälp !
268 ms totalt · 4 externa anrop · v20260731065814-full.6fe65c25
125 ms — deklarationer (db)
129 ms — ändringar (db)
