Jaha, nu är det jag som ska fråga. :)
Jag håller på med ett sänkaskepp spel, och nu har jag kommit fram till när man ska placera ut sina båtar. Det är ju så att man måste sätta dom ("prickarna") på en rad, lodrätt eller vågrätt. Jag har den här koden för att kolla om de ("prickarna") är på rad:
arrNum = Array("A1","A2","A3","A4","A5","A6","A7","A8","A9","A10","B1","B2","B3","B4","B5","B6","B7","B8","B9","B10","C1","C2","C3","C4","C5","C6","C7","C8","C9","C10","D1","D2","D3","D4","D5","D6","D7","D8","D9","D10","E1","E2","E3","E4","E5","E6","E7","E8","E9","E10","F1","F2","F3","F4","F5","F6","F7","F8","F9","F10","G1","G2","G3","G4","G5","G6","G7","G8","G9","G10","H1","H2","H3","H4","H5","H6","H7","H8","H9","H10","I1","I2","I3","I4","I5","I6","I7","I8","I9","I10","J1","J2","J3","J4","J5","J6","J7","J8","J9","J10")
arrBok = Array("A1","B1","C1","D1","E1","F1","G1","H1","I1","J1","A2","B2","C2","D2","E2","F2","G2","H2","I2","J2","A3","B3","C3","D3","E3","F3","G3","H3","I3","J3","A4","B4","C4","D4","E4","F4","G4","H4","I4","J4","A5","B5","C5","D5","E5","F5","G5","H5","I5","J5","A6","B6","C6","D6","E6","F6","G6","H6","I6","J6","A7","B7","C7","D7","E7","F7","G7","H7","I7","J7","A8","B8","C8","D8","E8","F8","G8","H8","I8","J8","A9","B9","C9","D9","E9","F9","G9","H9","I9","J9","A10","B10","C10","D10","E10","F10","G10","H10","I10","J10")
j = 0
l = 0
For Each str In Request.Form
If Request.Form(str) = 1 Then
If j = 0 Then
For i = 0 To UBound(arrNum)
If arrNum(i) = str Then
intNum = i
Exit For
Next
For i = 0 To UBound(arrBok)
If arrBok(i) = str Then
intBok = i
Exit For
Next
j = 1
Else
If str = arrBok(intBok + 1) OR str = arrNum(intNum + 1) Then
For k = 0 To UBound(arrNum)
If arrNum(k) = str Then
intNum = k
Exit For
l = 1
Next
If l = 0 Then
For k = 0 To UBound(arrBok)
If arrBok(k) = str Then
intBok = k
Exit For
Next
Else
Server.Transfer("fel.asp")
intSt = intSt + 1
Next
Nu till problemet: När jag skriver ut vilka checkboxar jag klickade i skrivs de ut i oordning; t.ex: A3, A1, A2, A5, A4. På så sätt är det ju omöjligt för arrayen att veta att de är i ordning, fasstän de är det.
Det jag undrar är om det finns något sätt att ordna resultaten på, så att de listas: A1, A2, A3, A4, A5?
