Två databastabeller i samma asp fil
5 svar · 164 visningar · startad av Jacob
Medlem sedan dec. 2000503 inlägg
Det blir något fel här är koden
<%	Set Connect = Server.CreateObject("ADODB.Connection")
	Connect.Open "driver={Microsoft Access Driver (*.mdb)};dbq=c:\inetpub\wwwroot\videomonitor\adressbok.mdb"
Set RS = Server.CreateObject("ADODB.Recordset")
strselectmode = request.querystring("nyheter")
select case strselectmode
case "alla"
Addera = "SELECT * FROM filmnyheter ORDER BY [Datum] DESC"
Addera1 = "SELECT TOP 10 * FROM dvdnyheter ORDER BY [Datum] DESC"
case "start"
Addera = "SELECT TOP 10 * FROM filmnyheter ORDER BY [Datum] DESC"
end select
RecSet.Open Addera, Connect, adOpenStatic, adLockOptimistic
RS.Open Addera1, Connect, adOpenStatic, adLockOptimistic %>
<%Function Radbryt(rfix)
rfix = "<P>" & Replace(rfix, vbCrLf, "<br>") & "</P>"
Radbryt = rfix
End Function%>
<link rel="stylesheet" href="main_css.css">
<%	Do Until RecSet.EOF
	Do Until RS.EOF %>
<table width="95%" border="0" cellspacing="10">
  <tr>
    <td width="50%">
      <h2 class="rubrik">
        <% =RecSet("rubrik") %>
      </h2>
      <p><font face="Verdana" size="1">(<i>
        <% =RecSet("datum") %>
        </i> )</font> <font face="Verdana" size="2">
        <%If Len(RecSet("texten")) > 200 Then
		Response.write Left(RecSet("texten"), 200) & "..."%>
        <a href="id.asp?id=<% =RecSet("id")%>">Läs hela artiklen</a>
        <%Else
		Response.write RecSet("texten")
		End If%>
        </font></p>
      <p align="right"><font face="Verdana" size="1">
        <% =RecSet("forfattare") %>
        </font><font face="Verdana" size="2"> </font> </p>
    </td>
    <td width="50%">
      <h2 class="rubrik">
        <% =RS("rubrik") %>
      </h2>
        <% =RS("datum") %>
		If Len(RS("texten")) > 200 Then
		Response.write Left(RS("texten"), 200) & "..."%>
        <a href="dvdnyheter.asp?id=<% =RS("id")%>">Läs hela artiklen</a>
        <%Else
Response.write RS("texten")
End If%>
        </font></p>
        <% =RS("forfattare") %>
    </td>
  </tr>
</table>
<%	RecSet.MoveNext
	Loop
	RecSet.Close
	RS.MoveNext
	Loop
	RS.Close
	Connect.Close	%>
Ursäkta att det blevlite långt men det var ända sättet.
Felmedelnadet jag får är:
Feltyp:
ADODB.Field (0x80020009)
Antingen är BOF eller EOF satt till True, eller så har aktuell post raderats. Den begärda åtgärden kräver en aktuell post.
ja©ob
vilken rad pekar felmeddelandet på, och vilket case är aktivt?
let's look for treasure!</A>
Det står tyvärr inte pekat på någon rad
& när man kör case start
ja©ob
Det spela iofs ingen roll vilken case man kör det blir samma fel.
ja©ob
varför loopar du rs inne i recset, du loopar lite galet då eftersom du loopar igenom hela rs för varje post i recset...
Ja varför gör jag det, dumma mig.
jag har nästan löst det nu tack ansers.
ja©ob
259 ms totalt · 4 externa anrop · v20260731065814-full.1dc6f849
124 ms — deklarationer (db)
127 ms — ändringar (db)
