Denna kod?
11 svar · 328 visningar · startad av oGGo
oGGoMedlem sedan apr. 2003120 inlägg
Hej, jag har eftersökt ett ASP script som listar filer i bokstavsordning nu i X antal månader, efter en felsökning hittade jag dock det.
Nu är det dock så att den inte visar mappar när den listar en mapp, utan bara filerna i mappen.
Dessutom undrar jag om det e möjligt att browsra mapparna som listas direkt på sidan ex. listfiles.asp?browse=txt/a/apa/
om ni nu förstår vad jag menar.
<%@ language = VBScript %>
Option Explicit
On Error Resume Next
Response.buffer = true
DIM objFSO, objFolder, objFilesInFolder
DIM arrFiles(), mFileCount, mPageSize, mPageNo, mPageCount
DIM mDirPath, mFileSpec, mFile, mTemp
DIM mServerName
DIM i, j, k, s0, s1
DIM mformPage, mformCtl, mformCtlVal
Dim mDownloadDir, mHttpPath
' Change as appropriate to your needs
mPageSize = 999
' Change to the actual directory name you have
mDownloadDir = " "
' mDownloadDir should be one subdirectory down from where this page resides, e.g.
' if this page is on C:\InetPub\Wwwroot, your dir is C:\InetPub\Wwwroot\Downloads.
' The page should of course be in a directory that is defined as the home
' or a virtual directory.
mDirPath = server.mapPath(".") & "\" & mDownloadDir
' Following the earlier remarks, if C:\Inetpub\wwwroot is home directory,
'and this page is in C:\InetPub\Wwwroot, the URL should be
mHttpPath = mDownloadDir & "/webs/ackord2/"
' but if this page is not in the home or a virtual directory
'(e.g,. on PWS, the page may be in C:\InetPub\Webpub but C:\Inetpub\wwwroot is
'defined as the home directory), then you need to adjust:
' mHttpPath = "/WebPub/" & mDownloadDir & "/"
' Instances of object
Set objFSO = CreateObject("Scripting.FileSystemObject")
Set objFolder = objFSO.GetFolder(mDirPath)
Set objFilesInFolder = objFolder.Files
mFileCount = objFilesInFolder.Count
IF mFileCount = 0 Then
Response.write "Det finns inga ackord av denna artisten än."
Set objFSO = Nothing
Set objFolder = Nothing
Set objFilesInFolder = Nothing
Response.End
mPageCount = INT(mFileCount \ mPageSize)
IF ( mFileCount Mod mPageSize) > 0 THEN
mPageCount = mPageCount + 1
' Test the existence of a control on form. If exists, its name should
' have been wrapped up in HTTP header, since our form uses POST method.
mformPage = Request.Form("HiddenPage")
If mformPage <> "" Then
IF mPageCount > 1 Then
mPageNo = Cint(mformPage)
' Test the values returned. The unselected ones would have
' the pattern of "xxx" and the selected one "xxx, xxx".
For Each mformCtl In Request.Form
mformCtlVal = Request.Form(mformCtl)
IF mformCtlVal = "First, First" Then
mPageNo = 1
Exit For
ElseIf mformCtlVal = "Previous, Previous" Then
mPageNo = mPageNo - 1
Exit For
ElseIf mformCtlVal = "Next, Next" Then
mPageNo = mPageNo + 1
Exit For
ElseIf mformCtlVal = "Last, Last" Then
mPageNo = mPageCount
Exit For
End if
Next
Else
mPageNo = 1
Else ' First run
mPageNo = 1
' Two dimension array, for File Name and Size columns (entry for Description
' column not provided here)
ReDim arrFiles(mFileCount-1, 1)
' Store file name, size info to array
i = 0
For Each mFile In objFilesInFolder
' First char upper, rest lower case, for display purposes only
mTemp=UCASE(LEFT(mFile.Name,1)) & LCASE((RIGHT(mFile.Name, LEN(mFile.Name) -1)))
arrFiles(i, 0) = mTemp
' Fill file size
arrFiles(i, 1) = mFile.Size
i = i + 1
Next
' Sort array by file name
For i = 0 To UBOUND(arrFiles)-1
k = i
s0 = arrFiles(i, 0)
s1 = arrFiles(i, 1)
For j = i + 1 To UBound(arrFiles)
If StrComp(arrFiles(j, 0), s0, vbTextCompare) < 0 Then
s0 = arrFiles(j, 0)
s1 = arrFiles(j, 1)
k = j
Next
arrFiles(k, 0) = arrFiles(i, 0)
arrFiles(k, 1) = arrFiles(i, 1)
arrFiles(i, 0) = s0
arrFiles(i, 1) = s1
Next
<html>
<meta http-equiv="Content-Type"; Content="text/html; Charset=iso-8859-1">
<body>
<%'<IMAGE SRC="LisFiles.gif" VSPACE=2 HSPACE=15 ALIGN=LEFT> %>
<b>
<font face="arial" size="4">Filer:</font>
</b>
<font color="black" face="arial" size="4"></font>
<br>
<br>
<font face="arial" size="1"> <b> Totalt:<%= cStr(mFileCount) %> filer</b></font>
<br>
<table cellpadding=6 cellspacing=0 border=0 style="border-collapse: collapse" bordercolor="#111111">
k = (mPageNo - 1) * mPageSize
j = 0
FOR i = k To mFileCount -1
' To form an URL which will be used as an anchor tag for file name
mTemp = mHttpPath & arrFiles(i, 0)
<TR><TD><A HREF="<%=mTemp%>"> <%=arrFiles(i,0)%> </A> <BR></TD>
j = j + 1 ' Count to control the max
IF j = mPageSize then ' j is zero-based
Exit For
Next
' Fill up one page with blanks
DO WHILE j < mPageSize
j = j + 1
LOOP
</TABLE>
<FORM NAME="UpdPage" ACTION="LisFiles.asp" METHOD="POST">
<INPUT TYPE="HIDDEN" NAME="HiddenPage" VALUE="<%=cstr(mPageNo)%>">
<INPUT TYPE="HIDDEN" NAME="OfFirst" VALUE="First" STYLE="POSITION: RELATIVE;LEFT=10; WIDTH=70; COLOR=MAROON;">
<INPUT TYPE="HIDDEN" NAME="OfPrevious" VALUE="Previous" STYLE="POSITION:RELATIVE;LEFT=10; WIDTH=70; COLOR=MAROON;">
<INPUT TYPE="HIDDEN" NAME="OfNext" VALUE="Next" STYLE="POSITION:RELATIVE; LEFT=10; WIDTH=70; COLOR=MAROON;">
<INPUT TYPE="HIDDEN" NAME="OfLast" VALUE="Last" STYLE="POSITION:RELATIVE; LEFT=10; WIDTH=70; COLOR=MAROON;">
<% IF mPageCount>1 Then %>
<% If mPageNo=1 Then %>
<INPUT TYPE="SUBMIT" NAME="OfNext" VALUE="Next" STYLE="POSITION:RELATIVE; LEFT=10; WIDTH=70; COLOR=MAROON;">
<% If mPageCount>2 Then %>
<INPUT TYPE="SUBMIT" NAME="OfLast" VALUE="Last" STYLE="POSITION:RELATIVE; LEFT=10; WIDTH=70; COLOR=MAROON;">
<% End If %>
<% ElseIf mPageNo=mPageCount Then %>
<INPUT TYPE="SUBMIT" NAME="OfFirst" VALUE="First" STYLE="POSITION: RELATIVE;LEFT=10; WIDTH=70; COLOR=MAROON;">
<% End If %>
<INPUT TYPE="SUBMIT" NAME="OfPrevious" VALUE="Previous" STYLE="POSITION:RELATIVE;LEFT=10; WIDTH=70; COLOR=MAROON;">
<% ElseIf mPageNo>1 And mPageNo<mPageCount Then %>
<% End If %>
<% End If %>
<% End If %>
<% End If %>
</FORM>
</BODY>
</HTML>
Response.End
Detta är koden jag hittade!!!
Snälla hjälp, ni anar inte hur glad jag skulle bli :)
Testa med att lägga till detta innan du loopar filerna:
For each Item in objFolder.SubFolders
Response.write Item.Name
next
Det händer inte ett jota...
Om du menade att jag skulle plocka in dom såhär:
next
j = j + 1
LOOP
Men det viktigaste är nog ändå att man skall kunna browsra genom att få sidan att bli såhär:
listfiles.asp?browse=txt/w/ ...osv
näää förresten :) ... båda är lika viktiga :)
om någon har ett annat script som listar alla filer + mappar i bokstavsordning (viktigt) så skulle det också vara nice förstås !!!
Du kan starta med att radera: "On Error Resume Next" med den raden kvar lär du få svårt att fixa till ditt script.
Testa detta, det ger dig mappnamnen:
Option Explicit
'On Error Resume Next
DIM mServerName
DIM i, j, k, s0, s1
Dim mDownloadDir, mHttpPath, SubFolders, item
mPageSize = 999
mDownloadDir = " "
Set subFolders = objFolder.SubFolders
Response.End
mPageNo = 1
Exit For
Exit For
Exit For
Exit For
End if
Next
Else
mPageNo = 1
Else ' First run
mPageNo = 1
i = 0
For each Item in SubFolders
Response.write Item.Name & "<BR>"
next
' Fill file size
i = i + 1
Next
k = i
s0 = arrFiles(i, 0)
s1 = arrFiles(i, 1)
s0 = arrFiles(j, 0)
s1 = arrFiles(j, 1)
k = j
Next
arrFiles(i, 0) = s0
arrFiles(i, 1) = s1
Next
<html>
<body>
<b>
</b>
<br>
<br>
<br>
j = 0
Exit For
Next
j = j + 1
LOOP
</TABLE>
<% End If %>
<% End If %>
<% End If %>
<% End If %>
<% End If %>
<% End If %>
</FORM>
</BODY>
</HTML>
Response.End
tack så mycket...bara dock en grej...mapparna vart inte listade i bokstavsordning :)
Kan man inte istället bryta ut från denna kod, det som gör att allt blir i bokstavsordning och slänga in det i en annan kod som är lite kortare och mindre komplicerad & där funktionen sidan.asp?browse=w/wreeswijk cornelis/ också finns ?????
alltså, ni anar inte hur glad jag skulle bli om det funkade till slut !!!
Den här vet jag funkar bra...
strUser = ""
Dim strFolder, Whichfolder, strParent
strFolder = Request.Querystring("folder")
If Len(strFolder) = 0 Then
strParent = ""
ElseIf Len(strFolder) = 1 Then
strParent = ""
Else
intPos = InStrRev(strFolder, "\")-1
If intPos = 0 Then
strParent = ""
Else
strParent = Left(strFolder, intPos)
Whichfolder = Server.MapPath("\") & strFolder & "\"
Dim fs, f, f1, fc
Set fs = CreateObject("Scripting.FileSystemObject")
Set f = fs.GetFolder(Whichfolder)
Set fc = f.subfolders
For Each f1 in fc
Response.write "<A href='default.asp?folder=" & strFolder & "\" & f1.name & "'>" & f1.name & "</A><BR>"
Next
'----------------------------------V€LJ FIL----------------------------------
Set fc = f.files
For Each f1 in fc
Response.write "<A href='" & Replace(strFolder & "\", "\", "/") & f1.name & "'>" & f1.name & "</A><BR>"
Next
Set fc = nothing
Set f = nothing
Set fs = nothing
Kanske en bit på väg... Iofs är ju det bästa, precis som du skriver, att göra en funktion av det hela.
Option Explicit
DIM mServerName
DIM i, j, k, s0, s1
Dim mDownloadDir, mHttpPath, SubFolders, item, arrFilesf, mFolderCount
mPageSize = 999
mDownloadDir = " "
mFolderCount = subFolders.Count
Response.End
mPageNo = 1
Exit For
Exit For
Exit For
Exit For
End if
Next
Else
mPageNo = 1
Else ' First run
mPageNo = 1
'### MAPPAR
i = 0
ReDim arrFilesf(mFolderCount-1, 1)
mTemp=UCASE(LEFT(Item.Name,1)) & LCASE((RIGHT(Item.Name, LEN(Item.Name) -1)))
arrFilesf(i, 0) = mTemp
' Fill file size
arrFilesf(i, 1) = Item.Size
i = i + 1
Next
For i = 0 To UBOUND(arrFilesf)-1
k = i
s0 = arrFilesf(i, 0)
s1 = arrFilesf(i, 1)
For j = i + 1 To UBound(arrFilesf)
If StrComp(arrFilesf(j, 0), s0, vbTextCompare) < 0 Then
s0 = arrFilesf(j, 0)
s1 = arrFilesf(j, 1)
k = j
Next
arrFilesf(k, 0) = arrFilesf(i, 0)
arrFilesf(k, 1) = arrFilesf(i, 1)
arrFilesf(i, 0) = s0
arrFilesf(i, 1) = s1
Next
'### FILER
i = 0
' Fill file size
i = i + 1
Next
k = i
s0 = arrFiles(i, 0)
s1 = arrFiles(i, 1)
s0 = arrFiles(j, 0)
s1 = arrFiles(j, 1)
k = j
Next
arrFiles(i, 0) = s0
arrFiles(i, 1) = s1
Next
<html>
<body>
<b>
</b>
<br>
<br>
<font face="arial" size="1"> <b> Totalt:<%= cStr(mFolderCount) %> mappar</b></font>
<br>
j = 0
FOR i = k To mFolderCount -1
mTemp = mHttpPath & arrFilesf(i, 0)
<TR><TD><A HREF="<%=mTemp%>"> <%=arrFilesf(i,0)%> </A> <BR></TD>
Exit For
Next
j = j + 1
LOOP
</TABLE>
<br>
j = 0
Exit For
Next
j = j + 1
LOOP
</TABLE>
<% End If %>
<% End If %>
<% End If %>
<% End If %>
<% End If %>
<% End If %>
</FORM>
</BODY>
</HTML>
Response.End
nice nice...nu till frågan om det går med någon enkel funktion att få in så man browsrar på sidan?
annars blir det lite jobbigt att sitta och trycka in en av varje av dessa sidor i varje mapp (400 st) på servern + att gå in i koden och fixa till vilken mapp filen ligger i
Testa sökfunktionen, det du efterfrågar har varit upp relativt nyligen. Eller/och börja knåpa. Du har ju alla namn på mappar och filer, lägg dom i en querystring som du sen tar ner och använder i "funktionen" som listar filerna.
144 ms totalt · 3 externa anrop · v20260731065814-full.beb2e261
