Sökningsproblem via ASP i MS SQL 7.0
ASPur ASP
2 svar · 165 visningar · startad av Jahappz
JahappzMedlem sedan nov. 200013 inlägg
vad = Request.form("vad")
sok = Request.form("sok")
Set Connection = Server.CreateObject("ADODB.Connection")
Connection.Open("server=servernamn;driver={SQL Server};uid=sa;pwd=;database=Quedata")
Set RS = Server.CreateObject("ADODB.Recordset")
If (vad = "0") then
SQLFRAGA = "SELECT IDnr, Artist, Lat, Ripper, Format FROM MusicVideos WHERE Artist LIKE'%" & sok & "%' OR Ripper LIKE'%" & sok & "%' OR Format LIKE'%" & sok & "%' OR Lat LIKE'%" & sok & "%' ORDER BY Artist ASC"
RS.open SQLFRAGA,Connection,3,1,1
IDnr = RS("Idnr")
Artist = RS("Artist")
Lat = RS("Lat")
Ripper = RS("Ripper")
Format = RS("Format")
SQLFRAGA = "SELECT IDnr, Artist FROM MusicVideos WHERE Artist LIKE'%" & sok & "%' ORDER BY Artist ASC"
IDnr = RS("Idnr")
<html>
<meta http-equiv="Content-Type" content="text/html; charset=windows-1252">
<title>MusicVideos Search 0.1 Beta 4 & utveckling</title>
<body>
<table border="0" width="100%" cellspacing="0" cellpadding="0">
<tr>
<td width="100%" class="normal" bgcolor="#6A8B60"><font color="#FFFFFF">Du
sökte på <b><%=sok%></b> och fick <b><%=RS.RecordCount%></b>
träffar</font></td>
</tr>
<tr>
<td width="100%" class="normal"> </td>
</tr>
</table>
If RS.RecordCount = 0 or RS.RecordCount = null Then
Response.Write "Hittade inga!!"
Else
Do While not RS.EOF
If (vad = "0") then %>
<tr>
<td width="7%" class="normal" valign="top"><a
href="view.asp?ID=<%=ID%>"><img border="0" src="images/result_art.gif" WIDTH="16" HEIGHT="16"></a></td>
<td width="93%" class="normal"><b><a
href="view.asp?ID=<%=ID%>"><%=Artist%></a></b><br>
<%=Lat%><br><br></td>
</tr>
<%ELSE%>
<tr>
<td width="7%" class="normal" valign="top"><a href="router.asp?lank=<%=ID%>"
target="_new"><img border="0" src="images/result_lank.gif" ALT="<%=url%>"
<td width="93%" class="normal"><b><a href="router.asp?lank=<%=ID%>"
target="_new"><%=Artist%></a></b><br>
<%=lat%><br><br></td>
</tr>
END IF
RS.MoveNext
Loop
END IF
RS.Close
set RS = nothing
Connection.close
set connection = nothing
</table>
</html>
när man kör aspn däremot o söker på en "Ripper" som har gjort flera låtar så skriver den ut rätt antal som han gjort men den skriver bara ut den artist som står längst upp i databasen... nån som vet hur man får ordning på detta?
PatrikBMedlem sedan mars 20002 836 inlägg
Hello,
den söker och hämtar alla recset, men .... direkt när du öppnat recsetet, dvs innan du loopar igenom det så lägger du in det första recsetet i variabler vilket gör att de kommer att ha samma värde hela tiden.
En sak du kan göra är att "flytta" upp loopen inne i if satsen, så att du får en loop om vad = 0 och en annan loop om vad <> 0 eller så flyttar du ned variablerna till den andra if satsen
cya,
Response.Write("PatrikB")
Response.End
[Redigerat av PatrikB den 16 nov 2000]
okej.. men hur ska koden se ut isåfall?
137 ms totalt · 3 externa anrop · v20260731065814-full.29ac60f6
