funktionen fungera sådär..
21 svar · 784 visningar · startad av voigtann1
jag kör denna funktion:
function layer(id,hidden,src,tal,name,bild,left,top,height,width)
response.write "<div id=""" &id& """ style=""position:absolute; width:" & width & "px; height:" & height & "px; z-index:1; left: "&left&"; top: "&top&";visibility: " &hidden& ";"" onMouseDown=""MM_dragLayer('" &id&"','',19,10,277,20,true,false,-1,-1,-1,-1,false,false,0,'',true,'')"">" &_
"<table width="""& width &""" height="""& height &""" border=""0"" cellpadding=""0"" cellspacing=""0"">" &_
"<tr>" &_
"<td colspan=""3"" valign=""top""  background=""gfx/transph.gif"" height=""9""></td>" &_
"</tr>" &_
"<tr>" &_
"<td valign=""top"" background=""gfx/transpv.gif"" width=""9""></td>" &_
"<td>" &_
"<table width="""& width-18 &""" height="""& width-18 &""" border=""0"" cellpadding=""0"" cellspacing=""11"" bgcolor=""#FFFFFF"">" &_
"<tr>" &_
"<td valign=""top"">" &_
"<table width="""& width-41 &""" height=""" & height-40 &""" border=""0"" cellpadding=""0"" cellspacing=""0"" bgcolor=""#FFFFFF"">" &_
"<tr>" &_
"<td><img src=""gfx/top_"&bild&".gif"" width=""277"" height=""11""><a href=""javascript:mimze('" &id& "')""><img src=""gfx/pil.gif"" name=""pil_"&tal&""" border=""0"" onmouseover=""byt('pil_on.gif','pil_"&tal&"');"" onmouseout=""byt('pil.gif','pil_"&tal&"');""></a><img src=""gfx/rad.gif""><a href=""javascript:showhide('"&id&"')""><img src=""gfx/kryss.gif"" name=""kryss_"&tal&""" onmouseover=""byt('kryss_on.gif','kryss_"&tal&"');"" onmouseout=""byt('kryss.gif','kryss_"&tal&"');"" border=""0""></a></td>" &_
"</tr>" &_
"<tr>" &_
"<td valign=""top"">"&_
"<iframe src="""&src&""" border=""0"" frameborder=""0"" width="""& width-41 &""" height=""" & height-40 &""" name="""&name&"""></iframe></td>" &_
"</tr>" &_
"</table>" &_
"</td>" &_
"</tr>" &_
"</table>" &_
"</td>" &_
"<td valign=""top"" background=""gfx/transpv.gif"" width=""9"">" &_
"</td>" &_
"</tr>" &_
"<tr>" &_
"<td colspan=""3"" valign=""top"" background=""gfx/transph.gif"" height=""9"">" &_
"</td>" &_
"</tr>" &_
"</table>" &_
"</div>"
end function
på vissa av mina rutor fungera detta perfekt.. eftersom jag använde denna mall på vissa av mina layers innan.. men nu ville jag har en funktion där man själv kunde reglera höjd och bredd på mina lager.. problemen är:
om jag kör mindre än 200 tror jag så försvinner vänster och höger mallen runt hela lagret.. störigt.. och om jag skriver höjden ex 50 så blir den inte 50 pixlar utan SOOOORT.. vad är felet?
Jag kan fundera på att läsa igenom koden om du ändrar till en Sub. En funktion skall alltid returnera något.
okey... då ändra jag det till en sub :e men hjälper det då?
Nej, resultatet blir detsamma.
Men, är du säker på att problemet är i asp:n? På mig låter det som att det är html-koden som inte är korrekt?
det är det nog...
response.write layer("drinkar","visible","drinks.asp?drink=random",1,"drink","rec",355,15,407,341)
response.write layer("drinklist","visible","listdrinks.asp",2,"listall","ref",10,15,407,341)
response.write layer("news","visible","nyheter.asp",3,"ne","ne",10,430,233,461)
De 2 översta har samma "area" medans news inte har det... news iframe och "sidornas" ramar försvinner... kan det vara att jag inte ha (height-40) isället för height-40... tror knappt att det är () är det men detta är störigt att det inte fungera
hur fungera SUB då? blir tokig varför inte den inte gör som jag vill.
sub layer(id,hidden,src,tal,name,bild,left,top,height,width)
    ' allt skräp
end sub
call layer ("drinkar","visible","drinks.asp?drink=random",1,"drink","rec",355,15,407,341)
Wass ist die Problem?
får error
Feltyp:
Kompileringsfel i Microsoft VBScript (0x800A03EA)
Syntaxfel
/bar2/main.asp, line 17, column 15
response.write call layer ("drinkar","visible","drinks.asp?drink=random",1,"drink","rec",355,15,407,341)
Du har ju response-write i sub-rutinen, du kan ju inte skriva response.write response.write "blah!".
Titta på mitt exempel.
nu fungera sub:en men fattar inte varför den blir som det blir.. "rutan" blir nog som det ska men iframen blir typ 20 pixlar.. ser konstigt ut.. har lagt upp: http://bar.voigtan.cjb.net
Iframen är 100px bred, och det är också vad det står i html-koden. (Om du menar nyhets-iframen?)
Anropar du suben rätt för den iframen?
jepp.. nyhets iframen.. den ser inte bra ut
kan det vara stylesheeten?
Vad menar du att problemet är?
att "left" och "right" "bordern" försvinner om jag kör det jag kör nu.. och att iframen ser hemsk ut...
Hur anropar du suben vid de olika tillfällena? Har du kollat html-källan för att se vad som saknas?
'layer(id,hidden,src,tal,name,bild,left,top,height,width)
call layer ("news","visible","nyheter.asp",3,"ne","ne",10,430,207,141)
och visst.. den fyller i 100 där på det stället där height-41 men jag anser att det inte stämmer alls.. ser mer ut som typ 30 eller 40 pixlar..
Hur lätt som helst att avgöra om den är 10, 30, 40 eller vilken bredd den nu har. Ta en skärmdump och klistra in i tex PhotoShop, plocka fram linjalen mec ctrl+r (om du inte får linjalen i pixlar får du ändra enhet för linjalen i Preferences i PS).
btw ... den är EXAKT 100 px bred :e
cya,
PatrikB
*argh* varför fungera inte det som jag vill då? hur ska jag lösa mitt dilema då? width="100%" tycks inte fungera eller height="100%" :(
Medlem sedan aug. 2001226 inlägg
Bara en fråga?
du kör:
[RED]
[/RED]
men suben/funktionen skriver juh redan...
ändra då kanske till
[RED]
call layer("drinkar","visible","drinks.asp?drink=random",1,"drink","rec",355,15,407,341)
call layer("drinklist","visible","listdrinks.asp",2,"listall","ref",10,15,407,341)
call layer("news","visible","nyheter.asp",3,"ne","ne",10,430,233,461)
[/RED]
borde kanske fungera?
testa iaf ;P
Over and Out
Pirro
279 ms totalt · 4 externa anrop · v20260731065814-full.a51de22e
138 ms — deklarationer (db)
123 ms — ändringar (db)
