Mailinglista fungerar ej
1 svar · 158 visningar · startad av kristoffer
kristofferMedlem sedan juni 20001 257 inlägg
Jag får felmeddelandet
[Microsoft][ODBC Microsoft Access Driver] Operation must use an updateable query.
mail_ac.asp, line 18
, när jag försöker lägga till en post i databasen. Koden ser ut så här:
mail.htm
<html>
<head></head>
<body>
<form action="mail_ac.asp" method="post">
<input type="text" name="email" size="11">
<input type="submit" value="submit">
</html>
mail_ac.asp
   Dim email, con, data_source, sql_insert, sql_check, rs
   email = Request.Form("email")
   If Len(email) Then
   Set con = Server.CreateObject("ADODB.Connection")
   con.Open("DRIVER={Microsoft Access Driver (*.mdb)};DBQ=" & Server.MapPath("mail.mdb"))
   sql_check = "select email from users where email = '" & email & "'"
   sql_insert = "insert into users ( email )"
   sql_insert = sql_insert & " values ('" & email & "')"
   Set rs = con.Execute (sql_check, , 1)
   If rs.EOF Then
   con.execute(sql_insert)
   Response.Write "Thank you. Your email address <b>" & email & _
               "</b> was successfully entered into the database"
   Else
   Response.Write "Your email address " & email & _
               " is already present in the database. Thank you."
   con.Close
   Set con = Nothing
   Else
   Response.Redirect "mail.htm"
Vad beror det på?
sgtpepperMedlem sedan apr. 20007 588 inlägg
Använd sökfunktionen, den där frågan har ställts flera gånger förut.
Kolla här:
http://cgi.webforum.nu/wf/Forum11/HTML/000602.html
http://cgi.webforum.nu/wf/Forum11/HTML/000254.html
http://cgi.webforum.nu/wf/Forum11/HTML/000659.html
http://cgi.webforum.nu/wf/Forum11/HTML/001109.html
http://cgi.webforum.nu/wf/Forum11/HTML/001402.html
"Common sense is the collection of prejudices acquired by age 18" - Albert Einstein
[Redigerat av sgtpepper den 01 nov 2000]
