Kort fast pa Overrides skript....
7 svar · 315 visningar · startad av crisse6
Medlem sedan dec. 20002 526 inlägg
Antar att jag har kommit in i en brist pa aspkunskaper igen.. hehe... jaja, kanske inte... far iaf Object Required: " pa denna rad:
CatID = UploadRequest.Item("catID").Item("Value") varfor vet jag ej... sa har ser koden ut:
[red]
Response.Expires=0
Response.Clear
'Response.BinaryWrite(Request.BinaryRead(Request.TotalBytes))
byteCount = Request.TotalBytes
'Response.BinaryWrite(Request.BinaryRead(varByteCount))
RequestBin = Request.BinaryRead(byteCount)
Dim UploadRequest
Set UploadRequest = CreateObject("Scripting.Dictionary")
BuildUploadRequest RequestBin
'Exempel på hur man kan 'plocka ner' andra forumlärelement
'email = UploadRequest.Item("email").Item("Value")
contentType = UploadRequest.Item("blob").Item("ContentType")
filepathname = UploadRequest.Item("blob").Item("FileName")
filename = Right(filepathname,Len(filepathname)-InstrRev(filepathname,"\"))
value = UploadRequest.Item("blob").Item("Value")
catID = UploadReqeust.Item("catID").Item("Value")
FileDesc = UploadRequest.Item("desc").Item("Value")
DT = Now()
scriptName = UploadRequest.Item("scriptName").Item("Value")
'Create FileSytemObject Component
Set ScriptObject = Server.CreateObject("Scripting.FileSystemObject")
'Create and Write to a File
pathEnd = Len(Server.mappath(Request.ServerVariables("PATH_INFO")))-14
' Set MyFile = ScriptObject.CreateTextFile(Left(Server.mappath(Request.ServerVariables("PATH_INFO")),pathEnd)&filename)
Set MyFile = ScriptObject.CreateTextFile(Server.mappath("/UploadedSkript/"& filename))
For i = 1 to LenB(value)
MyFile.Write chr(AscB(MidB(value,i,1)))
Next
MyFile.Close
response.write "<b>Filens sökväg:</b> " & Server.mappath(filename) & "<br>"
response.write "<b>Filnamn:</b> " & filename & ""
strInsertFile = "INSERT INTO t_Files ([catID], [scriptName], [fileDesc], [dt], [downloaded], [fileURL], [byUser], [Controlled]) "&_
"VALUES("&catID&",'"&scriptName&"','"&FileDesc&"',#"&DT&"#,'0', "&filename&", 'crisse6',False)"
objConn.Execute(strInsertFile)
[/red]
Finns form-fältet catID ??
Jupp
Medlem sedan sep. 2002104 inlägg
timmen är sen och jag har inte hållit på med asp-upload men,
vad gör egentligen:
BuildUploadRequest
rad 9
I formuläret, har du: enctype="multipart/form-data"?
Annars om du tar bort just den raden, hur går det då?
vad gör egentligen:
BuildUploadRequest
rad 9
den andrar nat med formularen sa det blir ratt eller nat ;), vet bara att man inte kan skriva request.form("namn") nar man kor sant tror jag? jaja, skitsam...
solbulle, har inte mojlighet att testa koden nu, sitter i Chicago... hehe..... men ska gora det nar jag kommer hem, om tva dagar... ville bara kolla om ni visste direkt ;) aterkommer!
sa har ser det ut nu:
[red]
<%@ LANGUAGE=VBSCRIPT %>
<% OPTION EXPLICIT %>
<% Response.Buffer = TRUE %>
<html>
	<title>Laddar upp skript...</title>
<body>
<!--#include file="db_conn.asp" -->
Dim objConn, byteCount, RequestBin, PosBeg, i, char, PosEnd
Dim boundary, boundaryPos, Pos, intCount, Name, PosFile, PosBound
Dim filename, contentType, value, filepathname
Response.Expires=0
Response.Clear
Dim UploadRequest
'catID = UploadReqeust.Item("catID").Item("Value")
DT = Now()
Next
MyFile.Close
<!--#include file="inc_upload.asp"-->
</html>
[/red]
formularet pa sidan innan ser ut sa har:
[red]
<form method="post" action="outputfile.asp" enctype="multipart/form-data">
Välj ditt skript:<br>
<input type="file" name="blob"><br>
Namn på skriptet:<br>
<input type="text" name="scriptName"><br>
En kort beskrivning av skriptet:<br>
<textarea cols="16" rows="4"></textarea><br>
Välj kategori:<br>
<select name="catID">
Do until rs.eof
response.write "<option value="""&rs("catID")&""">"&rs("catName")&"</option>"
rs.movenext
loop
</select><br><br>
<input type="submit" value="Ladda upp, yo!">
[/red]
Inget namn?
Det är många variabler du inte dimmar, tex alla formfält...
128 ms — deklarationer (db)
128 ms — ändringar (db)
