Invalid operation on open object...
3 svar · 125 visningar · startad av Hulth
HulthMedlem sedan juni 2001272 inlägg
Jag har stött på ett litet problem.. Det lyder:
ADODB.Recordset.1 error '800a0e79'
/bos/sub_w.asp, line 7
Koden är:
<!--#include file="c.asp"-->
	b	= Request.Querystring("b")
	Function weapon(w_id)
		get_weapon = "SELECT * FROM weapons WHERE ID = " & w_id
		RecSet.Open get_weapon, Connect, AdOpenDynamic ' Rad 7
		If RecSet.EOF Then
			Response.Write "<img src=""error.gif"">"
		Else
			Response.Write "<img src=""" & RecSet("gfx") & """>"
		RecSet.Close
	End Function
<html>
<title><%=c_title%></title>
<%=css%>
function bitch(url)	{window.open(url,'BOSBitch','toolbar=no,location=no,status=no,menubar=no,scrollbars=no,resizable=no,width=500,height=350');}
<body background="gfx/bos/m_bg.jpg">
	If b <> "" Then
	get_bitch_info = "SELECT * FROM bitches WHERE ID = " & b
	RecSet.Open get_bitch_info, Connect, AdOpenDynamic
	' Write headers
	Response.Write "<hr size=""1"" color=""#FFFFFF"" noshade>"
	Response.Write "<table align=""center"" border=""0"" cellpadding=""0"" cellspacing=""0"" width=""100%"">"
	'Check if bitch exists
	If RecSet.EOF Then
		' Bitch don't exist, return error
		Response.Write "<tr><td><font size=""2"" face=""verdana"" color=""#FFFFFF""><b>That bitch dosn't exist!</b></font></td></tr>"
	Else
		' Bitch exists, return information
		Response.Write "<tr><td><font size=""2"">Bitch name</font></td><td><font size=""2"">" & RecSet("name") & "</font></td></tr>"
		Response.Write "<tr><td><font size=""2"">Bitch real name</font></td><td><font size=""2"">" & RecSet("real") & "</font></td></tr>"
		Response.Write "<tr><td><font size=""2"">Bitch age</font></td><td><font size=""2"">" & RecSet("age") & "</font></td></tr>"
		Response.Write "<tr><td><font size=""2"">Bitch city</font></td><td><font size=""2"">" & RecSet("city") & "</font></td></tr>"
		Response.Write "<tr><td><font size=""2"">Bitch favorite map</font></td><td><font size=""2"">" & RecSet("f_map") & "</font></td></tr>"
		Response.Write "<tr><td><font size=""2"">Bitch CT favorite pistol</font></td><td>" & weapon(RecSet("ct_f_pistol")) & "</td></tr>"
		Response.Write "<tr><td><font size=""2"">Bitch CT favorite weapon</font></td><td>" & weapon(RecSet("ct_f_weapon")) & "</td></tr>"
		Response.Write "<tr><td><font size=""2"">Bitch T favorite pistol</font></td><td>" & weapon(RecSet("t_f_pistol")) & "</font></td></tr>"
		Response.Write "<tr><td><font size=""2"">Bitch T favorite weapon</font></td><td>" & weapon(RecSet("t_f_weapon")) & "</font></td></tr>"
	' End the table
	Response.Write "</table>"
</html>
Det är när jag anropar functionen weapon() med ett tal (som hämtas från en db) som det cpar sig.
Någon av nattugglorna som kan hjälpa mig? svara gärna via icq: 124254758 eller msn: wi99dhh@hotmail.com
Du kan inte öppna ett nytt recordset innuti ett redan öppet med samma namn.
Nu öppnar du recordset1 där du skriver ut informationen, sedan öppnar
du ju recordset2 med samma namn i din function. Då är inte recordset1 stängt ännu.
Testa att byta namn på ditt recordset som du öppnar i din funktion..
Det tackar vi för. Nu fungerar det skitbra..
***** Off Topic *****
Min ellärare heter Palle, det är möjligen inte du? :) :p ;)
Senast jag var vaken var jag inte ellärare.. så nej. ;)
