nån som kan komprimera den här åt mig ? den är väldigt trög... sen den sista som fixar om man inte har skrivit i vilket län man bor så kommer en ej bild fram men den sista funkar inte :(
Kod:
Connect.Open "Driver={Microsoft Access Driver (*.mdb)}; DBQ=" & server.mappath("databasen")&";pwd=losenordet"
Set Recset = Server.CreateObject("ADODB.Recordset")
Addera = "SELECT * FROM members where id=" &Request.QueryString("checkid")
RecSet.Open Addera, Connect, 3, 3
if RecSet("lan") = "stockholms" then
Response.Write "<img src=""lan/stockholms.gif"">"
if RecSet("lan") = "vasternorrlands" then
Response.Write "<img src=""lan/vasternorrlands.gif"">"
if RecSet("lan") = "vastermanlands" then
Response.Write "<img src=""lan/vastermanlands.gif"">"
if RecSet("lan") = "vasterbottens" then
Response.Write "<img src=""lan/vasterbottens.gif"">"
if RecSet("lan") = "varmlands" then
Response.Write "<img src=""lan/varmlands.gif"">"
if RecSet("lan") = "uppsala" then
Response.Write "<img src=""lan/uppsala.gif"">"
if RecSet("lan") = "sodermanland" then
Response.Write "<img src=""lan/sodermanland.gif"">"
if RecSet("lan") = "skane" then
Response.Write "<img src=""lan/skane.gif"">"
if RecSet("lan") = "osergotland" then
Response.Write "<img src=""lan/osergotland.gif"">"
if RecSet("lan") = "orebro" then
Response.Write "<img src=""lan/orebro.gif"">"
if RecSet("lan") = "norrbotten" then
Response.Write "<img src=""lan/norrbotten.gif"">"
if RecSet("lan") = "kronobergs" then
Response.Write "<img src=""lan/kronobergs.gif"">"
if RecSet("lan") = "kalmar" then
Response.Write "<img src=""lan/kalmar.gif"">"
if RecSet("lan") = "jamtlands" then
Response.Write "<img src=""lan/jamtlands.gif"">"
if RecSet("lan") = "gotland" then
Response.Write "<img src=""lan/gotland.gif"">"
if RecSet("lan") = "gotalands" then
Response.Write "<img src=""lan/gotalands.gif"">"
if RecSet("lan") = "dalarna" then
Response.Write "<img src=""lan/dalarna.gif"">"
if RecSet("lan") = "blekinge" then
Response.Write "<img src=""lan/blekinge.gif"">"
if RecSet("lan") = "hallands" then
Response.Write "<img src=""lan/hallands.gif"">"
If RecSet("lan") = "" Then
Response.Write("<img src=""lan/ej.gif"">")
Addera = "SELECT lan FROM members where id=" &Request.QueryString("checkid")
lan = RecSet("lan")
'stäng db
If lan = "" Then
lan = "ej"
Response.Write("<img src=""lan/" & lan &".gif"">")
när någon inte har någon bild alltså noll i värde i databasen så blir adressen till bilden lan/.gif
men den ska va lan/ej.gif när man inte har valt en bild
If Len(recset(lan)) = 0 Then
Else
Response.Write("<img src=""lan/" & recset(lan) &".gif"">")
