hjälp med global.asa
1 svar · 161 visningar · startad av mikael_a
Medlem sedan mars 2000475 inlägg
Hej, kan jag inte göra på detta sätt? får ett "odentifierat fel i rad 7, i min räknare.
hits.asp
'= ASP Tracker =
Strconn = "DRIVER={Microsoft Access Driver (*.mdb)}; DBQ=" & server.mappath("\databas\tracker.mdb")
set conn = Server.CreateObject("ADODB.Connection")
set RS = Server.CreateObject("ADODB.Recordset")
conn.open Strconn
rad 7 = conn.open Strconn
den fungerar om jag tar bort följande: (i från min global.asa)
<SCRIPT LANGUAGE=VBScript RUNAT=Server>
Sub Application_OnStart
On Error Resume Next
Set Application("Pages") = Server.CreateObject("Scripting.Dictionary")
Set Application("Host") = Server.CreateObject("Scripting.Dictionary")
Set Application("Agent") = Server.CreateObject("Scripting.Dictionary")
Set Application("Starttime") = Server.CreateObject("Scripting.Dictionary")
End Sub
Sub Session_OnStart
Application("Starttime").Item(Session.SessionID) = Now
Application("Host").Item(Session.SessionID) = Request.ServerVariables("HTTP_HOST")
Application("Agent").Item(Session.SessionID) = Request.ServerVariables("HTTP_USER_AGENT")
End Sub
Sub Session_OnEnd
If Application("Pages").Exists(Session.SessionID) Then
Application.Lock
Application("Pages").Remove(Session.SessionID)
Application("Host").Remove(Session.SessionID)
Application("Agent").Remove(Session.SessionID)
Application("starttime").Remove(Session.SessionID)
Application.Unlock
End Sub
</SCRIPT>
min global.asa ser ut så här:
Global.asa
End Sub
Sub Session_OnStart
End Sub
Sub Session_OnEnd
Application.Lock
Application.Unlock
End Sub
</SCRIPT>
Sub Session_OnStart
'Add one to Application("SessionCount")
  IF IsNumeric(Application("SessionCount")) THEN
    Application("SessionCount") = Application("SessionCount") + 1
  ELSE
    Application("SessionCount") = 1
  END IF
End Sub
</SCRIPT>
Sub Session_OnEnd
'Subtract one from Application("SessionCount")
    Application("SessionCount") = Application("SessionCount") - 1
  ELSE
    Application("SessionCount") = 0
  END IF
End Sub
</SCRIPT>
Micke & Annas Sajt
micke@micke-anna.nu
[Redigerat av mikael_a den 13 sep 2000]
Hmmm... skumt.
Men, du har två Session_OnEnd och två Session_OnStart. Det ska man inte ha. Slå ihop dem.
Gunnar Liljas - webbutvecklare
Leon Reklambyrå AB
275 ms totalt · 4 externa anrop · v20260731065814-full.a51de22e
131 ms — deklarationer (db)
132 ms — ändringar (db)
