Byta ikoner till filhanterare - WebExplorer
0 svar · 181 visningar · startad av JPS
Medlem sedan nov. 2001101 inlägg
Jag sitter och testar filhanteraren WebExplorer och jag vill byta ut ikoner till dokument men jag får inte koden att fungera. Jag vill ha samma kod som i ArgoBrowse
for each BrowsedFile in BrowseContents.Files
	FileExtBegPos = InStrRev(BrowsedFile.Name, ".")
	FileExtTotal = len(BrowsedFile.Name)
	FileExt = Right(BrowsedFile.Name, FileExtTotal - FileExtBegPos)
	select case FileExt
	case "asp"
	FileIcon = "aspicon.gif"
	case "htm", "html", "shtm", "shtml"
	FileIcon = "htmlicon.gif"
	case "jpg", "jpeg", "gif", "png", "bmp"
	FileIcon = "imgicon.gif"
	case "zip", "rar", "tar", "gz"
	FileIcon = "zipicon.gif"
	case "exe"
	FileIcon = "exeicon.gif"
	case "mp3", "wav", "rm", "wmv"
	FileIcon = "mp3icon.gif"
	case else
	FileIcon = "icon.gif"
	end select
Jag kan få ut filändelsen men sen är det stopp!
		For each item in objFolder.files
			If showHiddenItems or not item.Attributes and 2 Then
				listed = listed + 1
	dim a,n
	a= item.name
	a = split(a,".")
	n = a(ubound(a))
N	<% = n %>
<%	select case n
	case "doc"
	FileIcon = "Icon_Prog_Word.gif"
	case "xls"
	FileIcon = "Icon_Prog_Excel.gif"
	case "pdf"
	FileIcon = "Icon_Prog_Acrobat.gif"
	case htm, html, shtm, shtml
	FileIcon = "Icon_Prog_htm.gif"
	case "jpg", "jpeg", "png", "bmp"
	FileIcon = "Icon_Prog_Jpg.gif"
	case "gif"
	FileIcon = "Icon_Prog_Gif.gif"
	case else
	end select
	<img src="images/<% = FileIcon%>">
	<tr>
		<td class="list01">&nbsp;<img src="Images/Icon_Prog_Gif.gif"><%=GetIcon(item.Name, false)%>&nbsp;<a href="<%=scriptName & "?precommand=Download&folder=" & Server.URLEncode(folder) & "&file=" & Server.URLEncode(item.Name)%>" title="Ladda ner fil"><%=item.Name%></a></td>
		<td class="list01" align="right">&nbsp;<%=FormatSize(item.Size)%></td>
		<td class="list01">&nbsp;<%=item.Type%></td>
<td  class="list01" nowrap><%= FormatDateTime(item.DateLastModified, 2)%> &nbsp;<%= FormatDateTime(item.DateLastModified, 4)%></td>
			<a href="javascript:Command('RenameFile', &#34;<%=item.Name%>&#34;);"><img src="images/Andra.gif" alt=" Byt namn " width="13" height="12" border="0"></a>
			<a href="javascript:Command('DeleteFile', &#34;<%=item.Name%>&#34;);"><img src="images/Ta_bort.gif" alt=" Ta bort fil " width="13" height="12" border="0"></a>
		</td>
	</tr>
				'If rowType = "darkRow" Then rowType = "lightRow" Else rowType = "darkRow"
		Next
</table>
126 ms — deklarationer (db)
117 ms — ändringar (db)
