Vad ska man skriva istället för Request() när man ska hämta värden från ett formulär som skickas med enctype="multipart/form-data"?
Jag har testat med SmartUpload.Form.Item("name").Name men då får jag felmeddelanden för att det inte finns något värde.
ElseIf Request("page") = "addpic" Then
'######################################## FORMULÄR FÖR ATT LADDA UPP BILDER
Response.Write("<form method=""post"" action=""admin_pictures.latmask?page=picupload"" enctype=""multipart/form-data"">")
Response.Write("640x480px-bild: <input type=""file"" name=""pic""><br>")
Response.Write("Namn: <input type=""text"" name=""name""><br>")
Response.Write("Datum då bilden togs: <input type=""text"" name=""date_tooked""><br>")
Response.Write("Beskrivning:<br><textarea name=""desc"" style=""width: 250px; height: 75px;""></textarea><br>")
SQL = "SELECT cat FROM picture_cats ORDER BY cat"
Set rs = Connection.Execute(SQL)
If NOT rs.EOF Then
Response.Write("Kategori: <select name=""cat"">")
Do Until rs.EOF
Response.Write("<option value=" & rs("cat") & ">" & rs("cat") & "</option>")
rs.MoveNext
Loop
Response.Write("</select><br><br style=""line-height: 4px;"">")
rs.Close
Set rs = Nothing
Response.Write("<input type=""submit"" value="" Ladda upp! "">")
Response.Write("</form>")
ElseIf Request("page") = "picupload" Then
'######################################## LADDA UPP BILDERNA
Dim SmartUpload
Dim S
Set SmartUpload = CreateObject("aspSmartUpload.SmartUpload")
name = SmartUpload.Form.Item("name").Name
desc = Trim(Request("desc"))
date_tooked = Trim(Request("date_tooked"))
date_upload = date()
cat = Trim(Request("cat"))
SQL = "INSERT INTO pictures([name],[desc],date_tooked,date_upload,cat) VALUES('" & name & "','" & desc & "','" & date_tooked & "'," & date_upload & ",'" & cat & "')"
Set rs = Connection.Execute("SELECT @@IDENTITY")
id = rs(0)
filename = id+".jpg"
SmartUpload.Upload
S = SmartUpload.Save(Server.MapPath("../gallery/" & filename))
Set J = Server.CreateObject("JpegLib.cJpeg")
J.Load(Server.MapPath("../gallery/" & filename))
If J.Width > 0 then
'File loaded correctly
J.SaveModified 90,0,Server.MapPath("../gallery/thumbnails/t_" & filename),68
Set J = Nothing
Upload = Nothing
rs.Close
Set rs = Nothing
SmartUpload = Nothing
Response.Write("weeeeeee")
Nu får jag felmeddelandet:
aspSmartUpload (0x800A005B)
Object variable or With block variable not set
Dim SmartUpload
Dim S
[blue]SmartUpload.Upload 'Här ska det tydligen vara fel[/blue]
name = SmartUpload.Form("name")
id = rs(0)
If J.Width > 0 then
Set J = Nothing
Upload = Nothing
rs.Close
Set rs = Nothing
Jag antar att det är för att jag inte har S = SmartUpload.Save(Server.MapPath("../gallery/" & filename)) direkt efter, men jag måste ju få in allt i databasen först för jag ska ju spara bilden med det idt som posten i databasen har...
Är du säker på att du är i rätt mapp? Skriv ut sökvägen. Sen undrar jag varför du tilldelar variabeln S värdet som returneras av .Save-metoden, måste du det och returnerar den verkligen något?
Har du sett till att IUSR_xxx har rättighet att skapa filer och skriva i mappen?
Rättigheterna ska vara rätt. :)
OveRRide skrev:
Är du säker på att du är i rätt mapp? Skriv ut sökvägen. Sen undrar jag varför du tilldelar variabeln S värdet som returneras av .Save-metoden, måste du det?
Mappen är rätt. :)
S skrev jag istället för intCount som det stod i exempelkoden...
Måste verkligen säga att det med största sannolikhet ÄR ett rättighetsproblem.
Jo, jag är nästan villig att sätta en peng på det också. Jag har jobbat en hel del med aspsmartupload, och har endast fått det felmeddelandet när jag glömt sätta rättigheter på uploadmappen till IUSR_xxx. Så jag och solbulle beordrar en dubbelkoll! :)
I admin-mappen har jag filerna som jag ska spara ner bilden med(admin_pictures.asp) i mappen gallery.
Rättigheterna är satta så här på huvudmappen:
Läsbehörighet
Skrivbehörighet
Script och körbara filer
Utdelad i nätverket
Är inte dom inställningarna rätt? :o
Såg att wF inte ville skriva ut "mappkartan" på rätt sätt så ni får fantisera. ;)
Hmm. Har du aldrig gjort inställningar för Accessdatabaser? Oh well... Prova:
@nders_har_skrivit_tusen_gånger_förut skrev:
Om du använder Windows XP, måste du se till att avaktivera Förenklad fildelning. Det gör du genom att i windows-utforskaren gå till menyn Verktyg -> Mappalternativ och sedan till fliken Visning. I listan finns alternativet ”Använd förenklad fildelning”. Se till att rutan inte är förbockad. Klicka OK.
I utforskaren, högerklicka på mappen där filen ligger, välj Egenskaper, och sedan fliken Säkerhet. Om inte användarkontot IUSR_datornamn finns med i listan, klicka på knappen Lägg till och fyll i det i rutan. Är det bara en fil det handlar om kan du göra det direkt på den filen istället för på mappen.
Markera användarkontot IUSR_datornamn i listan och se till så följande rättigheter är markerade: Ändra, Läsa och köra, Läsa, och Skriva.
Detta är visserligen skrivet för att se till att du har rätt inställningar för att kunna använda databaser fullt ut.
Nu har jag försökt att göra så som du skrev och har nu lagt till IUSR_mk och har gett den Full behörighet men det fungerar inte, samma felmeddelande. :l
Jag har även testat med full behörighet på alla andra konton...
142 ms totalt · 3 externa anrop · v20260731065814-full.4bcf49fe
