vad för fel?
7 svar · 157 visningar · startad av jwradhe
Medlem sedan juni 2002711 inlägg
<%Function FixaLankar(s)
On error resume next
Set objRE = new RegExp
objRE.IgnoreCase = True : objRE.Global = True
objRE.Pattern = "(http:\/\/|www\.)(\w|\&|\:|\;|\.|\/|\?|\~|\=|-)+"
Set m = objRE.Execute(s)
For Each o In m
If Right(o.Value, 1)="." Or Right(o.Value, 1)="!" Or Right(o.Value, 1)="?" Or Right(o.Value, 1)="," Then
If Left(o.Value, 3) = "www" Then s = Replace(s, o.Value, "<A HREF=""http://" & Left(o.Value, Len(o.Value)-1) & """ target=""_blank"">" & Left(o.Value, Len(o.Value)-1) & "</A>" & Right(o.Value, 1)) Else s = Replace(s, o.Value, "<A HREF=""" & Left(o.Value, Len(o.Value)-1) & """>" & Left(o.Value, Len(o.Value)-1) & "</A>" & Right(o.Value, 1))
Else
If Left(o.Value, 3) = "www" Then s = Replace(s, o.Value, "<A HREF=""http://" & o.Value & """ target=""_blank"">" & o.Value & "</A>") Else s = Replace(s, o.Value, "<A HREF=""" & o.Value & """ target=""_blank"">" & o.Value & "</A>")
Next
Set objRE = Nothing
strText = RecSet("inlagg")
strText = Server.HTMLEncode(strText)
Set objRegExp = New regexp
objRegExp.Global = true
objRegExp.IgnoreCase = true
objRegExp.Pattern = "&lt;"
strText = objRegExp.Replace(strText,"<font color=""#ff0000"">&lt;")
objRegExp.Pattern = "&gt;"
strText = objRegExp.Replace(strText,"&gt;</font>")
	' Tillåten HTML kod
s    = Replace(s,"[f]","<b>")
s    = Replace(s,"[/f]","</b>")
s    = Replace(s,"[k]","<i>")
s    = Replace(s,"[/k]","</i>")
s    = Replace(s,"[KOD]","<font color=#FF0000>")
s    = Replace(s,"
","</font>")
s = Replace(s,"<%","<%")
s = Replace(s,"%>","%>")
s = Replace(s, vbCrLf, "<br>")
s = Replace(s,"","")
FixaLankar = s
End Function%>
Vad för fel?
Hur skall vi kunna veta det. Berätta mer.
det händer inte. eller jo länk saken funkar som den ska.
men nr jag skriver
adasd
så blir det bara vit.
alltså det hnder inget.
Medlem sedan aug. 20021 752 inlägg
Kör du sidan genom IIS? Vad skriver du inte för adress i din browser när du tittar på sidan?
Om du inte kör den genom IIS så bryr den sig inte om att det är ASP, den hoppar över all ASP kod.
/Viktor
jag har den på ett webbhotell....
jwradhe skrev:
adasd
Vad hade du tänkt ska hända? :l
den ska skriva
adsdas
i röd färg då
+ att jag vill att <% ska synas. skriver man det nu hnder inget.
jag vill att om man skriver
asp
så ska den visa
asp
i röd färg.
detta skal jag använda till ett kurs script.
324 ms totalt · 4 externa anrop · v20260731065814-full.a51de22e
193 ms — deklarationer (db)
185 ms — ändringar (db)
