Problem med paging från valt kategori
12 svar · 254 visningar · startad av Tik
Medlem sedan juli 2002108 inlägg
Koden ser så här ut:
sql = "select * from Annonser where 1 = 1 and accepterad = true"
if not Request.Form("annonstyp") = checked then
sql = sql & " and annonstyp LIKE '%" & Request.Form("annonstyp") & "%' "
if LEN(Request.Form("sok")) > 0 then
sql = sql & " and Rubrik LIKE '%" & Request.Form("sok") & "%' "
if not Request.Form("kategori") = "0" then
sql = sql & " and kategori LIKE '%" & Request.Form("kategori") & "%' "
if not Request.Form("region") = "0" then
sql = sql & " and region LIKE '%" & Request.Form("region") & "%' "
sql = sql & " order by datum DESC "
Set recset = Server.Createobject("ADODB.Recordset")
Const perSida = 20
If Request.QueryString("page") = "" then
page = 1
Else
page = Request.QueryString("page")
RecSet.CursorLocation = 3
RecSet.CacheSize = perSida
recset.open SQL, "Driver={Microsoft Access Driver (*.mdb)}; DBQ=" & Server.MapPath("Database/Annonser.mdb")&""
<%RecSet.MoveFirst
RecSet.PageSize = perSida
TotalPages = RecSet.PageCount
RecSet.AbsolutePage = page
Count = 0
Do While Not RecSet.EOF And Count < RecSet.PageSize %>
<td width="80" height="18"><font size="2" face="Tahoma"> <%=left(recset("Datum"),10)%></font></td>
<td width="44" height="18"><font size="2" face="Tahoma"> <%=mid(recset("Datum"),12,5)%></font></td>
<td width="21" height="18"><%if not recset("bild") = "" then%><font size="2" face="Tahoma"> <img src="Bilder/bild.gif"><%end if%></font></td>
<td width="234" height="18"><font face="Tahoma"><font size="2"> </font><a href="javascript:Annons('visa_annons.asp?annonsid=<%=recset("annonsid")%>','<%=recset("annonsid")%>','scrollbars=yes,width=600,height=550,top=50')"><font size="2"><%=recset("Rubrik")%></font></a></font></td>
<td width="54" height="18"><font size="2" face="Tahoma"> <%if not recset("Pris") = "" then%><%=recset("Pris")%> kr<%end if%></font></td>
<td width="165" height="18"><font size="2" face="Tahoma"> <b><%=recset("kategori")%></b><br>
 <%=recset("region")%></font></td>
      \</tr\>\<%
      Count = Count + 1
      recset.movenext
        loop
    \</table\>
<img border="0" src="Bilder/genom.gif" width="1" height="6"><%If TotalPages <> 1 Then%>
<tr>
<b><table border="1" cellpadding="0" cellspacing="0" style="border-collapse: collapse" bordercolor="#111111" width="590" id="AutoNumber9">
<tr>
<td width="100%" bgcolor="#FFFFFF"><b><font size="2" face="Tahoma" COLOR="#000000"> Sida:</font><font size="1" face="Tahoma">
If (Int(page)) <> 1 Then
</font>
<font face="Tahoma" COLOR="#006699">
<a href="sok_annons_visa.asp?page=<%=(Int(page)-1)%>" onFocus="this.blur()">
<font size="1">«
Bakåt</font></a><font size="1"> |
<%Else%><%End If%>
For Pages = 1 To TotalPages
<%If (Int(Pages)) = (Int(page)) Then%> <%=Pages%>
<%Else%>
<a href="sok_annons_visa.asp?page=<%=Pages%>" onFocus="this.blur()"><%=Pages%></a>
<%End If%>
<%Next%>
<%End If%>
If (Int(page)) <> (Int(TotalPages)) Then
|<a onFocus="this.blur()" href="sok_annons_visa.asp?page=<%=(Int(page)+1)%>" COLOR="#FFFFFF"> Framåt »</a>
<%Else%>
<% end if %> </font></td>
</tr>
</table>
<%end if%>
<img border="0" src="Bilder/genom.gif" width="1" height="6"><%else%><table border="1" cellpadding="0" cellspacing="0" style="border-collapse: collapse" bordercolor="#111111" width="590" id="AutoNumber10">
<tr>
<td width="100%"><center>
<p><b><font face="Tahoma" >Din sökning gav inga träffar</font></b></p>
</center></td>
</tr>
</table>
<%end if%>
Och jag vill att när man väljer en viss kategori ska det gå att bläddra mellan sidor och titta på ENDAST annonser i denna kategori.
Vad som skal ändras/läggas till ?
Vad får du för felmeddelande då?
Ta bort 1 = 1 i SQL-satsen
inget.Utan den bläddrar annonser från alla kategorier.Inte från den utvalda tex bilar.
Jag tog bort men det hjälper inte.
Är alla dina formulärfält textfält? Annars om en del av dom är selectlistor är det onödigt att ha med "Like" i sqlfrågan.
Typ:
sql = sql & " and kategori  ='" & Request.Form("kategori") & "' "
Är det text eller tal i databasfälten?
Vad skulle jag i så fall skriva ? Ta bort dem ?
Funkar ej utan LIKE.
Någon som kan detta ?
Vad är det jag skall ändra ?
Fungerar alltså det hela när du postat formuläret och du kommer till sidan för första gången?
Om det är så och det inte fungerar när du går vidare är det nog för att din sqlfråga blir fel på nästa sida. - Du får inte med dig dina värden från formuläret då.
Jag skulle tro att du måste fixa länken till nästa sida.
Nästa sida är:
sok_annons_visa.asp
Vad skall jag ändra/fixa ?Den ser likadant ut som koden hjag skrev här på sidan.
Någon som kan och vill fixa detta ?
Jo som Solbulle säger:
"felet är vad jag förstår att när du klickar på länken till nästa sida kör ditt script din sql-fråga igen och då har du inte med dig informationen att det bara ska vara en viss kategori.
Du måste ändra dina länkar i din paging så att de fakta som ursprungligen kommer från formuläret kommer med i länkarna. "
Men min fråga: vad är det som skall ändras ? vad skall jag skriva ?
124 ms — deklarationer (db)
127 ms — ändringar (db)
