2 st loopar
4 svar · 156 visningar · startad av crisse6
crisse6Medlem sedan dec. 20002 441 inlägg
Nar jag ska skriva ut inlagg och avsandare, antal inlagg osv sa maste jag(?!) kora med tva st loopar verkar det som. Men far inte ihop det.
rs("f_text") ar sjalva inlagget.
rs3..... ar med info om avsandare, "niva", inlagg...
sql satserna ser ut sa har:
set rs = Server.CreateObject("Adodb.Recordset")
	If request.querystring("info") = "ja" then
	sql = "select * from t_viktigt where ForumID = "& request.querystring("forumID") &" and svarID = "& request.querystring("svarID") &""
	sql = "SELECT * from t_threads where ForumID = "& request.querystring("forumID") &" AND svarID = "& request.querystring("svarID") &""
sql3 = "select t_threads.*, t_users.* from t_threads, t_users where t_users.username = t_threads.f_by AND t_threads.f_by = t_threads.f_user"
	set rs3 = objConn.execute(sql3)
och sa har ser loopen ut och utskrivningen ut:
response.write "<table width=""600"" bgcolor=""#AFC2CF"" background=""meny/table_bar.gif"" cellspacing=""2"">"&_
				"<tr><td width=""100""><font face=""Verdana"" size=""1"" color=""#FFFFFF""><b>Inskickad av:</b></font></td>" &_
				"<td width=""600""><font face=""Verdana"" size=""1"" color=""#FFFFFF""><b>Inlägg:</b></font></td></tr></table>"
first = true
do while not rs.eof and intCurrentPost < rs.pagesize
		if bgcolor = "#FFFFFF" then
		bgcolor = "#f5f5f5"
		bgcolor = "#FFFFFF"
		strContents = strContents
if first then
response.write "<table width=""600"" bgcolor="&bgcolor&" cellspacing=""2"">" &_
		"<tr><td width=""100"" valign=""top""><font face=""Verdana"" size=""2"">"& rs3("f_by") &"</font></td><td width=""350""><a href=""#""><img src=""meny/profil.gif"" border=""0""></a><a href=""#""><img src=""meny/hemsida.gif"" border=""0""></a><a href=""#""><img src=""meny/email.gif"" border=""0""></a></td><td width=""100"" align=""right""><a href=""edit_post.asp?id="& rs3("threadID") &"""><img src=""meny/edit.gif"" border=""0""></a></td></tr><tr><td width=""100""><font face=""Verdana"" size=""1"">"& rs3("misc") &"<br>Inlagg: "& rs3("posts") &"</td>"
		first = false
if not isnull(rs("f_text")) then
response.write "<td width=""450""><font face=""Verdana"" size=""2"">"& fixa(rs("f_text")) &"</font></td>" &_
		"</tr></table>"
		intCurrentPost = intCurrentPost +1
rs.movenext
wend
liten julklapp! :e
ingen?
solbulleMedlem sedan mars 20014 998 inlägg
Vad händer/händer inte?
far felmess pa "wend".... hmm.... vill alltsa bara loopa ut tva olika recset men i ett och samma "paket" :)
hur skulle du gora solis?
fick ordning pa det genom en join i min lilla sql :)
Genererad på 378 ms · cache AV · v20260730165559-full.f96bc7eb
