Felmess
23 svar · 421 visningar · startad av sudden
Medlem sedan okt. 2002341 inlägg
Jag får det här meddelandet:
ADODB.Recordset error '800a0bb9'
Arguments are of the wrong type, are out of acceptable range, or are in conflict with one another.
/script1987/spelaroll/check.asp, line 17
På denna kod:
<%@Language = VBScript%>
<html>
<body bgcolor="#7B7875">
Dim Conn, RS, bolFinnRedan
Conn.Open "DRIVER={Microsoft Access Driver (*.mdb)}; DBQ=" & Server.MapPath("\script1987\db\databas.mdb")
If ((Request.Form("namn") = "") OR (Request.Form("efternamn") = "")_
   OR (Request.Form("epost") = "") OR (Request.Form("nick") = "")_
   OR (Request.Form("pass") = "") OR (Request.Form("info") = "")) Then
  Response.Redirect"start.asp?page=REG"
Else
   bolFinnsRedan = false
   Set RS = Server.CreateObject("ADODB.Recordset")
   [B]RS.Open anvandare, Conn, , adLockOptimistic, adCmdTable[/B]
   Do While Not (RS.EOF OR bolFinnsRedan)
    If (StrComp(RS("Epost"), Request.Form("epost"),_
          vbTextCompare) = 0) Then
     Response.Write"Denna epost existerar redan" & "<br>"
     Response.Write"<a href='start.asp?page=REG' target='_top'>Tillbaka</a>"
     bolFinnsRedan = True
    If (StrComp(RS("Nick"), Request.Form("nick"),_
     Response.Write"Användarnamnet finns redan, välj ett annat" & "<br>"
    If (StrComp(RS("Losen"), Request.Form("pass"),_
     Response.Write"Lösenordet är upptaget" & "<br>"
    RS.MoveNext
  Loop
  If Not bolFinnsRedan Then
    RS.AddNew
    RS("ForNamn") = Request.Form("fornamn")
    RS("EfterNamn") = Request.Form("efternamn")
    RS("Epost") = Request.Form("epost")
    RS("City") = Request.Form("city")
    RS("Year") = Request.Form("year")
    RS("Month") = Request.Form("month")
    RS("Day") = Request.Form("day")
    RS("Nick") = Request.Form("nick")
    RS("Losen") = Request.Form("pass")
    RS("Kon") = Request.Form("kon")
    RS("Info") = Request.Form("info")
   RS.Update
   Response.Write"Sådärja =) Nu kan du börja träffa nya vänner!" & "<br>"
   Response.Write"<a href='start.asp' target='_top'>Logga in</a>"
  RS.Close
  Set RS = Nothing
 Conn.Close
 Set Conn = Nothing
  </html>
Vad är det som orsakar felet??
Jag ser ingen SQL-sträng som heter användare... Sedan så måste du väl includera adovbs.inc???
Jag använder ingen SQL sträng i koden!
Scriptet ska kolla om användaren har fyllt i alla uppgifter från formulären...samt kolla om användarnamnet eller lösenordet redan existerar!
Om inte så läggs uppgifterna till i databasen!
Men du måste väl ändå specificera vilken tabell posten skall läggas i???
Hur tänkte du kolla om det finns i databasen om du inte har någon SQL-sträng?
Prova också
RS.Open anvandare, Conn, adLockOptimistic, adCmdTable
Ja precis...och den tabellen heter anvandare.
Prova ändå att ha en SQL:
SELECT * FROM anvandare
Jag ska prova det =)
Den vill ändå inte funka! =(
Här är koden:
<html>
Else
  SQl = "SELECT * FROM anvandare"
   [B]RS.Open SQL, Conn, adLockOptimistic, adCmdTable[/B]
    RS.MoveNext
  Loop
    RS.AddNew
   RS.Update
  RS.Close
  Set RS = Nothing
 Conn.Close
 Set Conn = Nothing
  </html>
Vad kan vara fel?
Vad får du för felmeddelande?
/script1987/spelaroll/check.asp, line 19
Prova att byta ut adLockOptimistic, adCmdTable mot deras egentliga konstanter, eftersom du, vad jag kan se, inte inkluderar adovbs.inc...
Du menar: Const adLockOptimistic och Const adCmdTable?
Nej, till de siffror som de egentligen hänvisar till.
(Tror att det är 3 o 3)
adLockOptimistic har jag för mig är 3, den andra vet jag inte. Kola i adobvs.inc sudden, så förstår du.
Hmm..nu hänger jag inte riktigt med här!
Hur gör jag det?
RS.Open anvandare, Conn, 3, 3
Okej...så det blir ungefär såhär: Const adLockOptimistic = 3 ??
Jaha! =)
Tackar tackar!
adLockOptimistic och adCmdTable är vanliga konstanter, som finns i adobs.inc.
Kolla i adobvs.inc så ser du att det ser ut typ:
osv.
259 ms totalt · 4 externa anrop · v20260731065814-full.e96017d9
120 ms — deklarationer (db)
121 ms — ändringar (db)
