Orättvisa !!!!
ASPur ASP
4 svar · 237 visningar · startad av Gaski
GaskiMedlem sedan juni 2000310 inlägg
Jag använder följande kod:
<!--#include file="conn.asp" -->
  Dim SQLquery
  Dim rsNoje
  Dim strStad, strDatum, strEven
  Dim strOldStad, strOldDatum, strOldEven
  Dim strToDo
  strStad = request("stad")
  strDatum = request("datum")
  strEven = request("even")
  strOldStad = request("oldstad")
  strOldDatum = request("olddatum")
  strOldEven = request("oldeven")
  strToDo = request("todo")
  if strToDo = "delete" then
    Call DeleteInfo
  elseif strToDo = "add" then
    Call AddInfo
  elseif strToDo = "edit" then
    Call EditInfo
    Call UnknownInfo
  End if
Sub DeleteInfo
  SQLquery = "DELETE FROM data WHERE stad = '" & strStad & "' AND datum = '" & strDatum & "' AND even = '" & strEven & "'"
  set rsNoje = conn.Execute(SQLquery)
  response.write("Evenemanget deletades utan fel. <a href='admin.html'>Tillbaka</a>.")
End Sub
Sub AddInfo
  SQLquery = "INSERT INTO data (stad, datum, even) VALUES  ('" & strStad & "', '" & strDatum & "', '" & strEven & "')"
  response.write("Evenemanget lades till utan fel. <a href='admin.html'>Tillbaka</a>.")
End Sub
Sub UnknownInfo
  response.write("Something went wrong, please try again <a href='admin.html'>here</a>.")
End Sub
Sub EditInfo
  SQLquery = "UPDATE data SET stad = '" & strStad & "', datum = '" & strDatum & "', even = '" & strEven & "' WHERE stad = '" & strOldStad & "' AND datum = '" & strOldDatum & "' AND even = '" & strOldEven & "'"
  response.write("Evenemanget ändrades utan fel. <a href='admin.html'>Tillbaka</a>.")
End Sub
rsNoje.close
set rsNoje = nothing
HTML filen ser ut så här:
<FORM METHOD="POST" ACTION="admin.asp" NAME="AddEven">
Stad:<BR><INPUT TYPE="text" NAME="stad"><BR>
Datum:<BR><INPUT TYPE="text" NAME="datum"><BR>
Evenemang:<BR><INPUT TYPE="text" NAME="even"><BR>
<INPUT TYPE="hidden" NAME="todo" VALUE="add">
<INPUT TYPE="SUBMIT" VALUE="Lägg till" NAME="skickarl">
Och jag får följande fel medelande:
Körningsfel i Microsoft VBScript fel '800a01a8'
Objekt krävs.: ''
/asp/linus/admin.asp, rad 56
Nä du! Det behövs inte alls något sådant tecken på rad 56!
Jag kräver rättvisa!
Gaski: Viktig IT-profil!!!
var har du skapat conn? kan det vara så att du glömt det?
don't follow your friends -- inflate them
conn.asp finns med och fungerar perfekt, har testat den med annan kod.
Ser ut så här:
<%	option explicit
	Dim conn    'connesione al database access
    Set conn = Server.CreateObject("ADODB.Connection")
	'DSN-less connection to access
    conn.open "DRIVER={Microsoft Access Driver (*.mdb)};DBQ=" & Server.Mappath("databas.mdb") & ";"
Du kan inte stänga rsNoje
rsNoje.close
om den inte skapats, och den skapas aldrig....fastän det kan se ut så....
cfMedlem sedan maj 2000376 inlägg
Ja, du skulle väl rent av kunna låta bli att använda rsNoje. Ett recordset har du väl knappast något behov av eftersom du inte gör någon utsökning.
130 ms totalt · 3 externa anrop · v20260731065814-full.29ac60f6
