Forumkod till emission
8 svar · 197 visningar · startad av Ricki
Medlem sedan juni 2000373 inlägg
Hej Emission,
Här kommer koden på forumet... :) :) :)
		' Öppna databasen
		password = "xxx"
		databas = "xxx.mdb"
		DBPath = Server.Mappath(mid(Request.ServerVariables("PATH_INFO"),1,instrrev(Request.ServerVariables("PATH_INFO"), "\")) & databas)
		Set MinCon=Server.CreateObject("ADODB.Connection")
		MinCon.Open "Driver={Microsoft Access Driver (*.mdb)}; DBQ=" & DBPath & ";uid=;pwd=" & password & ";"
		Sub VisaBarnMeddelanden(Forelder,Niva)
			' Kolla vilken sida man befinner sig på
			minSida = Request.Querystring("vilkenSida")
			If minSida = "" Then
				minSida = 1
			minSidaSize = 20
			' Skapa recorsetet
			Dim databas
			Set databas = Server.CreateObject("ADODB.Recordset")
			' Ändra några värden i recorst
			databas.cursorlocation = 3
			databas.cachesize = 1
			' Öppna sql, recordset
			SQL = "SELECT * From FORUM WHERE Forelder=" & Forelder & " ORDER BY Datum DESC"
			databas.Open SQL, MinCon, 1, 2
				' Fler värden i recordset
				databas.MoveFirst
				databas.PageSize = minSidaSize
				Maxcount = Cint(databas.PageCount)
				databas.AbsolutePage = minSida
				howmanyrecs = 0
				howmanyfields = databas.Fields.Count-1
			Do While Not databas.EOF And howmanyrecs < databas.pagesize
				Response.Write "<tr>"
				Response.Write "<td>"
				For slinga = 1 to Niva
					Response.Write "&nbsp;&nbsp;"
				Next
				Response.Write "<a href='forum.asp?id=lasa&nr=" & databas("MeddelandeID") & "'>" & databas("Amne") & "</a>"
				Response.Write "</td>"
				Response.Write "<td nowrap>" & databas("Postare") & "</td>"
				Response.Write "<td nowrap>" & FormatDateTime(databas("Datum"),2) & "</td>"
				Response.Write "</tr>"
				VisaBarnMeddelanden databas("MeddelandeID"),Niva+1
				databas.MoveNext
				howmanyrecs = howmanyrecs + 1
			Loop
			databas.Close
			Set databas = nothing
		End Sub
		<table border="0" width="99%" cellpadding="0" cellspacing="0">
		  <tr>
		    <td width="60%"><strong>Meddelanden</strong></td>
		    <td width="20%"><strong>Postat av</strong></td>
		    <td width="20%"><strong>Datum</strong></td>
		  </tr>
		' Anropa subben
		VisaBarnMeddelanden 0,0
		</table>
		' Skriv ut navigeringsmenyn för vilken sida man e på
		If MaxCount <> 0 Then
			Response.Write "Du befinner dig på sida <b>" & minSida & "</b> av <b>" & maxcount & "</b> - Till: "
			Pad = "0"
			Scriptname = Request.Servervariables("script_name")
			For Counter = 1 To maxcount
				If Counter => 10 Then
					Pad = ""
				Ref = "<a href=" & Scriptname & "?vilkenSida=" & Counter & "&pagesize=" & minSidaSize & "&id=main>" & Counter & "</a>"
				If Not cStr(minSida) = cStr(Counter) Then
					Response.Write "<b>" & Ref & "</b> "
				Else
					Response.Write "<b>" & minSida & "</b> "
				If Counter Mod 10 = 0 Then
					Response.Write "<br>"
			Next
Tack på förhand!! ;)
Hälsningar Ricki
www.ricki.nu
Jag får detta felmeddelande:
ADODB.Recordset fel '800a0bcd'
Antingen är BOF eller EOF satt till True, eller så har aktuell post raderats; åtgärden som programmet begärt kräver en aktuell post.
/Rickard/ricki2/forum.asp, rad 113
Hälsningar Ricki
www.ricki.nu
Är rad 113 denna: databas.MoveFirst?
Bädda in detta i:
If NOT databas.EOF then
PC-älskare prasslar i säven, och har malt i ryggen
www.webeye.nu
Vilken kategori spel tycker du mest om?
Jag tror inte det, men jag ska testa... :)
Hälsningar Ricki
www.ricki.nu
När nånting är EOF när du kör en .MoveFirst så betyder ju det att det inte finns några poster som matchar din sökning... vad innehåller variabeln foralder???
www.webeye.nu
Det var den raden, du hade rätt,m :)
Jag testade att lägga den innanför do while not databas.EOF, men funkar ändå ej....
Hälsningar Ricki
www.ricki.nu
Nje, nej... movefirst gör ju så att markören till recordsettet lägger sig på första posten, och den måste ju ligga före det att du börjar loopa igenom posterna...
Vad innehåller variabeln foralder?
www.webeye.nu
I loopen gör man ju detta:
Så forelder innehåller ett id, typ 64, 36, 28 mm.
Hälsningar Ricki
www.ricki.nu
1. Gör om skriptet så att de avancerade "paging"-funktionerna bara aktiveras på 0-nivån, dvs. när det är ett rotmeddelande.
2. Variabeln "databas" är redan utnyttjad utanför subben. Byt namn på någon av dem.
265 ms totalt · 4 externa anrop · v20260731065814-full.6fe65c25
128 ms — deklarationer (db)
133 ms — ändringar (db)
