rs.absolutepage, rs.pagecount -1
3 svar · 265 visningar · startad av LR^evil.sid
Medlem sedan maj 2002560 inlägg
hur kan det komma sig att rs.absolutepage och rs.pagecount har värdet -1
<!-- #include file = 'inc/head.asp' -->
		<table>
	dir = request.querystring("dir")
	sql = "select * from copforum order by postdate desc"
	openPg(sql)
	rs.pageSize = 10
	select case dir
		case "prev"
			if pgNo > 1 then pgNo = pgNo - 1 else pgNo = 1
		case "next"
			if rs.absolutePage < rs.pageCount then pgNo = pgNo + 1 else pgNo = rs.pageCount
		case "choice"
			if rs.absolutePage < pgNo then pgNo = request.querysting("choice") + 1
			if rs.absolutePage > pgNo then pgNo = request.querysting("choice") - 1
		case else
			pgNo = 1
	end select
	response.write _
		"<table>" & _
		"<tr><td>rs.absolutePage</td><td>: " & rs.absolutePage & "</td><tr>" & _
		"<tr><td>rs.pageCount</td><td>: " & rs.pageCount & "</td><tr>" & _
		"<tr><td>pgNo</td><td>: " & pgNo & "</td><tr>" & _
		"</table>"
	if not rs.eof then
[b][line 30]	rs.absolutePage = int(pgNo)[/b]
		response.write _
			"<tr><td><a href = 'administration.asp' title = 'Tillbaka till administrationen'>Administrationen</a> -> polisforum</td></tr>"
		for x = 1 to rs.pagesize
			if rs.eof then
				response.write sql
				exit for
				response.write _
					"<tr><td><a href = 'view.asp?topicid=" & rs("id") & "' title = '" & rs("post") & "'>" & rs("topic") & "</a></td></tr>"
			rs.movenext
		next
		if rs.pageCount > 1 then
				response.write _
					"<tr><td><a href = '?dir=prev'>prev</a></td>"
				for x = 1 to rs.pageCount
					response.write _
						"<td><a href = '?dir=choise&pgNo=" & x & "'>" & x & "</a></td>"
				next
				response.write _
					"<td><a href = '?dir=next'>next</a></td></tr>"
		</table>
<!-- #include file = 'inc/foot.asp' -->
	sub openPg(sql)
		set con = server.createobject("adodb.connection")
		set rs  = server.createobject("adodb.recordset")
		con.open "driver={mysql};option=16386;server=localhost;database=database;uid=uid;pwd=pwd"
		rs.open  sql, con, 3, 3
	end sub
felmeddelande:
ADODB.Recordset error '800a0cb3'
Object or provider is not capable of performing requested operation.
/ampyforum/administration.asp, line 30
Värt att nämna kan vara att det finns 13 poster i databasen för tillfället.
Använder du execute?
nej
	sub openPg(sql)
		con.open " driver={mysql};option=16386;server=localhost;database=databa
se;uid=uid;pwd=pwd"
		[b]rs.open  sql, con, 3, 3[/b]
	end sub
Medlem sedan sep. 2002366 inlägg
Av min erfaranhet så är recordcount och absolutepage inge vidare o använda när man har MySQL ;)
-Eitraz
302 ms totalt · 4 externa anrop · v20260731065814-full.a51de22e
137 ms — deklarationer (db)
161 ms — hämta tråd, inlägg och bilagor (db)
138 ms — ändringar (db)
