Hur gör man så att sidorna står så här:
[1-10] [11-20] [21-30]
Min kod ser ut så här:
<%Set Conn = Server.CreateObject("ADODB.Connection")
Conn.Open "Provider=Microsoft.Jet.OLEDB.4.0;Data Source=" & Server.MapPath("db/galleri.mdb")
perSida = 3 'Bilder per sida
Sidan = Request.QueryString("sida")
If Sidan = "" then
sida = 1
Else
sida = Sidan
With RecSet
.CursorLocation = 3
.CacheSize = perSida
End With
SQL = "Select * From bilder"
RecSet.Open SQL, Conn
If RecSet.EOF Then%>
Tomt
<%Else
With RecSet
.MoveFirst
.PageSize = perSida
.AbsolutePage = sida
End With
Sidor = RecSet.PageCount
X = 0
If Request.QueryString("Z") <> "" then
Z=Request.QueryString("Z")
Else
Z=1
Do While Not RecSet.EOF And X < RecSet.PageSize%>
Plats: <%=z%> - <%=RecSet("namn")%><br>
<%Z = Z + 1
X = X + 1
Recset.MoveNext
Loop
Recset.Close
Set Recset = Nothing
Else
Z=1
If Request.QueryString("sida") <> "" then
sida = Request.QueryString("sida")
Else
sida = 1
End If%>
<br>
<%If Sidor <> 1 Then
If (Int(sida)) <> 1 Then%>
<a href="visa2.asp?sida=<%=(Int(sida)-1)%>&z=<%=Z-perSida%>"><b>«</b></a>
<%Else
Response.Write ""
For Sid = 1 To Sidor
If (Int(Sid)) = (Int(sida)) Then%><%=Sid%> <%Else%> <a href="visa2.asp?sida=<%=Sid%>&z=<%=persida*Sid-perSida+1%>"><%=Sid%></a> <%End If
Next
If (Int(sida)) <> (Int(Sidor)) AND X > 0 Then%>
<a href="visa2.asp?sida=<%=(Int(sida)+1)%>&z=<%=Z+perSida%>"><b>»</b></a>
<%Else
Conn.Close
Set Conn = Nothing%>
