Går det inte att uppdatera fler poster samtidigt? Får följande fel:
Feltyp:
Microsoft JET Database Engine (0x80040E14)
Syntaxfel i UPDATE-uttryck.
/edit_insert.asp, line 37
på följande Kod:
SQL2 = "UPDATE mPlanering SET "
For Each Item In Request.Form
If Item <> "mVecka" And Item <> "mId" And Item <> "mGrupp" And Item <> "mAntal" And Item <> "mNotering" And Item <> "Submit" And Item <> "xMark" And Item <> "grpId"Then
If IsDate(Request.Form(Item)) And InStr(Request.Form(Item), "-") Then
SQL2 = SQL2 & Item & "= #" & Request.Form(Item) & "#, "
Else
SQL2 = SQL2 & Item & "= '" & Request.Form(Item) & "', "
Next
SQL2 = SQL2 & " WHERE grpId = '" & Request.Form("grpId") & "'"
Response.Write SQL2
[b]ConnDb1.Execute(SQL2)[/b]
När jag skriver ut SQLen ser den ut så här:
UPDATE mPlanering SET grpEmk= 'Kaffe, te', grpDatum= '2002-10-24, 2002-10-25', grpAnkomst= 'Kaffe, te', grpFmk= 'KAffe, te', grpMiddag= 'Kaffe, te', grpLunch= 'Kaffe, te', grpVickning= 'Kaffe, te', grpNotering= 'Kaffe, te', WHERE grpId = '3, 4'
