html & asp
ASPur ASP
14 svar · 320 visningar · startad av antar
antarMedlem sedan dec. 2001289 inlägg
blir knas med tabellerna
så här ser det ut i html:
<table border="0" cellspacing="1" style="border:1px solid #000000; border-collapse: collapse" width="100%">
<tr><td width="100%">
<table border="0" cellpadding="0" cellspacing="0" style="border-collapse: collapse" width="100%">
  <tr>
    <td width="100%"><b><font size="1" face="Tahoma">
    Gifta.</font></b></td>
  </tr>
  <tr>
    <td width="100%"><font size="1" face="Tahoma">antar2.</font></td>
</table>
</table><br>
  <tr>
    Kompanjoner.</font></b></td>
  </tr>
  <tr>
    <td width="100%"><font size="1" face="Tahoma">antarnet.</font></td>
[b]</table></tr>[/b]
  <tr>
    <td width="100%"><font size="1" face="Tahoma">antar.</font></td>
</table>
</table><br>
  <tr>
    Kompisar.</font></b></td>
  </tr>
  <tr>
    <td width="100%"><font size="1" face="Tahoma">fisen.</font></td>
</table>
</table><br>
  <tr>
    Tvillingar.</font></b></td>
  </tr>
  <tr>
    <td width="100%"><font size="1" face="Tahoma">test.</font></td>
</table>
</table><br>
  <tr>
    Älskling.</font></b></td>
  </tr>
  <tr>
  <tr>
</table>
ASP:
first = "yes"
Connect.Open "Provider=Microsoft.Jet.OLEDB.4.0;Data Source=" & Server.MapPath("database/kompisar.mdb")&""
Addera = "Select * From Kompisar Where not accepterad=false and Kompis1 = 'antar' or kompis2 = 'antar' and not accepterad=false order by relation,Kompis1 ASC"
RecSet.Open Addera, Connect, 3, 3
do until recset.eof
Set Connect2 = Server.CreateObject("ADODB.Connection")
Connect2.Open "Provider=Microsoft.Jet.OLEDB.4.0;Data Source=" & Server.MapPath("Database/Medlemmar.mdb")&""
Set RecSet2 = Server.CreateObject("ADODB.Recordset")
if recset("kompis1") = "antar" then
Addera = "Select * From Medlemmar Where Anvandarnamn = '"&recset("kompis2")&"'"
if recset("kompis2") = "antar" then
Addera = "Select * From Medlemmar Where Anvandarnamn = '"&recset("kompis1")&"' "
RecSet2.Open Addera, Connect2, 3, 3
if recset("Relation") <> strRelation then
	strRelation = recset("Relation")
	If first <> "yes" then%>
</table><br>
<%End If%>
  <tr>
    <%=recset("Relation")%>.</font></b></td>
  <%End if%></tr>
  <tr>
    <td width="100%"><font size="1" face="Tahoma"><%=recset2("Anvandarnamn")%>.</font></td>
response.write "</table>"
first = "no"
RecSet.MoveNext
Loop
RecSet.Close
set recset = nothing
Connect.Close
set connect = nothing
recset2.Close
set recset2 = nothing
Connect2.Close
set connect2 = nothing
roadyMedlem sedan jan. 2002473 inlägg
vad exakt blir knas???
kanske vid kompanjoner och älskling eller???
så nu har jag redigerat inlägget där det är fetmarkerad e det fel på?
Finns iofs fler fel tror jag.
Kanske att detta kan vara bättre:
first = "yes"
do until recset.eof
</td></tr></table><br>
<%End If%>
  <tr>
  <%End if%></tr>
  <tr>
    <td width="100%"><font size="1" face="Tahoma"><%=recset2("Anvandarnamn")%>.</font></td></tr>
first = "no"
RecSet.MoveNext
Loop
RecSet.Close
Connect.Close
recset2.Close
Connect2.Close
näe funkar inte med
det blir så här nu!
  <tr>
    <td width="100%"><font size="1" face="Tahoma">antar.</font></td></tr>
</table>
Hm, hur ska det partiet se ut egentligen?
så här ska det se ut!
<tr>
</table><br>
<tr>
</table><br>
</tr> ska väl in också?
<tr>
</tr>
<tr>
<td width="100%"><font size="1" face="Tahoma">antar1.</font></td></tr>
<tr>
<td width="100%"><font size="1" face="Tahoma">antar2.</font></td></tr></table>
</tr>
</table><br>
Ytterligare ett försök :)
first = "yes"
do until recset.eof
</table><br>
<%End If%>
  <tr>
  <%End if%></tr>
  <tr>
first = "no"
RecSet.MoveNext
Loop
response.write "</table><br>"
RecSet.Close
Connect.Close
recset2.Close
Connect2.Close
nope blir helt fel!
storsuck :(
Sista försöket, sen får du sluta bry dig om allt jag någonsin skriver:
first = "yes"
do until recset.eof
</table><br>
<%End If%>
  <tr>
  <%End if%></tr>
  <tr>
first = "no"
RecSet.MoveNext
Loop
response.write "</table><br></td></tr></table><br>"
RecSet.Close
Connect.Close
recset2.Close
Connect2.Close
nope funkar inte
huller om buller hehe
CoolDudeMedlem sedan aug. 2000304 inlägg
first = "yes"
do until recset.eof
[b]</table><br>[/b]
<%End If%>
  <tr>
  <%End if%></tr>
  <tr>
first = "no"
RecSet.MoveNext
Loop
RecSet.Close
Connect.Close
recset2.Close
Connect2.Close
Vad e det? (fetmarkerat)
136 ms totalt · 3 externa anrop · v20260731065814-full.29ac60f6
