Skickar iväg denna kod
Response.write "<TD>"
Response.write "<input type='checkbox' name='Alla_fastighets_slag' value='0' checked>Alla"
Response.write "</TD>"
Response.write "<input type='checkbox' name='Hyreshus' value='1'>Hyreshus<br>"
Response.write "<input type='checkbox' name='Fabrik' value='2'>Fabrik"
Response.write "<input type='checkbox' name='Affar' value='3'>Affär<br>"
Response.write "<input type='checkbox' name='Kopcentrum' value='4'>Köpcentrum"
tar emot denna kod
Alla_fastighets_slag = Request.Form ("Alla_fastighets_slag")
Hyreshus = Request.Form ("Hyreshus")
Fabrik = Request.Form ("Fabrik")
Affar = Request.Form ("Affar")
Kopcentrum = Request.Form ("Kopcentrum")
if Hyreshus = "" then
Hyreshus = 0
if Fabrik = "" then
Fabrik = 0
if Affar = "" then
Affar = 0
if Kopcentrum = "" then
Kopcentrum = 0
stad = Request.Form ("stad")
if stad = 0 then
MySQL1 = "SELECT zhops_fastighet_tillsalu.fastighet_id, zhops_fastighet_tillsalu.Pris, zhops_fastighet_tillsalu.Datum, zhops_fastighet_tillsalu.fosaljnings_text, zhops_fastighet_tillsalu.kund_id, zhops_fastighets_slag.fastighets_slag_id, zhops_stad.Stad_id, zhops_stad.stad_namn, zhops_fastighets_slag.fastighets_slag, zhops_fastighet.Fastighets_namn FROM zhops_stad INNER JOIN ((zhops_fastighets_slag INNER JOIN zhops_fastighet ON zhops_fastighets_slag.fastighets_slag_id = zhops_fastighet.Fastighet_slag_id) INNER JOIN zhops_fastighet_tillsalu ON zhops_fastighet.Fastighet_id = zhops_fastighet_tillsalu.fastighet_id) ON zhops_stad.Stad_id = zhops_fastighet.stad_id"
MySQL1 = "SELECT zhops_fastighet_tillsalu.fastighet_id, zhops_fastighet_tillsalu.Pris, zhops_fastighet_tillsalu.Datum, zhops_fastighet_tillsalu.fosaljnings_text, zhops_fastighet_tillsalu.kund_id, zhops_fastighets_slag.fastighets_slag_id, zhops_stad.Stad_id, zhops_stad.stad_namn, zhops_fastighets_slag.fastighets_slag, zhops_fastighet.Fastighets_namn FROM zhops_stad INNER JOIN ((zhops_fastighets_slag INNER JOIN zhops_fastighet ON zhops_fastighets_slag.fastighets_slag_id = zhops_fastighet.Fastighet_slag_id) INNER JOIN zhops_fastighet_tillsalu ON zhops_fastighet.Fastighet_id = zhops_fastighet_tillsalu.fastighet_id) ON zhops_stad.Stad_id = zhops_fastighet.stad_id WHERE zhops_stad.Stad_id="&stad
if Alla_fastighets_slag = 0 then
MySQL1 = MySQL1 & ";"
MySQL1 = MySQL1 & " AND fastighets_slag_id="&Hyreshus&" OR fastighets_slag_id="&Fabrik&" OR fastighets_slag_id="&Affar&" OR fastighets_slag_id="&Kopcentrum&";"
Set objRecordset1 = Server.CreateObject("ADODB.Recordset")
Tror att jag har krånglat till det mer än vad som behövs är det någon som har förslag hur man ska göra det effektivare.
