Töm databasen (vote.mdb)
Har ett röstningssystem på sidan, men vet ej hur man nollställer scriptet.???
Så här ser koden ut:
' Här skapar vi en dsn-less connection mot vote.asp
Set Connect=server.CreateObject("adodb.connection")
DSNtemp="DRIVER={Microsoft Access Driver (*.mdb)}; "
DSNtemp=dsntemp & "DBQ=" & server.mappath("vote.mdb")
Connect.Open DSNtemp
'Two varibles are passed into the db
'u_input is the value if the user entered a response to
'the vote/poll question....IP is the address of the user
u_input=request.form("u_input")
u_ip=request.servervariables("remote_addr")
' if the user did not enter anything in the poll on this visit
' then display the poll question and possible choices
if u_input = "" then
<form method="post" action="<%= request.servervariables("script_name") %>">
' if the user did input a choice on the vote/ballot
' check to see if their ip address is already in the db
accessdb="votes_db"
cn="driver={Microsoft Access Driver (*.mdb)};"
cn=cn & "dbq=" & server.mappath(accessdb)
set rs = server.createobject("ADODB.Recordset")
sql = "select ip from ballot where ip ='" & u_ip & "'"
rs.Open sql, cn
if rs.eof then
' if the user has not voted previously indicate it
been_here_before="No"
rs.close
if been_here_before = "No" then
' Since the user has not voted previously their input
' their vote will be added to the db
sql = "insert into ballot (ip, selection" & u_input &") "
sql = sql & "values ('" & u_ip & "',1)"
rs.Open sql, cn
'This will summerize and count the records in the db
sql= "select distinctrow sum(selection1) as sum_selection1, "
sql= sql & "sum(selection2) AS sum_selection2, sum(selection3) AS sum_selection3, "
sql= sql & "sum(selection4) AS sum_selection4, count(*) AS total_votes "
sql= sql & "FROM ballot;"
rs.Open sql, cn
total1=rs ("sum_selection1")
total2=rs ("sum_selection2")
total3=rs ("sum_selection3")
total4=rs ("sum_selection4")
count=rs ("total_votes")
A<img src="red.jpg" height="10" width="<%= (total1/count)*100 %>">
<%= formatnumber((total1/count)*100,1) %>%<br>
B<img src="yellow.jpg" height="10" width="<%= (total2/count)*100 %>">
<%= formatnumber((total2/count)*100,1) %>%<br>
C<img src="green.jpg" height="10" width="<%= (total3/count)*100 %>">
<%= formatnumber((total3/count)*100,1) %>%<br>
D<img src="blue.jpg" height="10" width="<%= (total4/count)*100 %>">
<%= formatnumber((total4/count)*100,1) %>%<br>
Totalt har: <%= formatnumber(count,0,0) %>st röstat.<br>
<% if been_here_before <> "No" then %>
OBS! du har röstat förut så den här rösten räknades <u>inte</u>
<% else %>
Din röst har laggts till....
<% end if %>
<br>
Din IP address <%= u_ip %>
<% end if %>
Tacksam för hjälp.
